[postgis-tickets] r17078 - Change test conditions to look for empty.
Paul Ramsey
pramsey at cleverelephant.ca
Mon Nov 26 04:14:17 PST 2018
Author: pramsey
Date: 2018-11-26 16:14:17 -0800 (Mon, 26 Nov 2018)
New Revision: 17078
branches/2.5/regress/tickets.sql
branches/2.5/regress/tickets_expected
References #4245
Modified: branches/2.5/regress/tickets.sql
--- branches/2.5/regress/tickets.sql 2018-11-26 16:31:20 UTC (rev 17077)
+++ branches/2.5/regress/tickets.sql 2018-11-27 00:14:17 UTC (rev 17078)
@@ -384,7 +384,7 @@
-- #723 --
SELECT '#723',
- encode(ST_AsEWKB(ST_SnapToGrid( ST_Intersection(a.geog, b.geog)::geometry, 0.00001),'ndr'),'hex')
+ ST_IsEmpty(ST_SnapToGrid( ST_Intersection(a.geog, b.geog)::geometry, 0.00001))
FROM (VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') ) ) As a(geog) CROSS JOIN ( VALUES (ST_GeogFromText('SRID=4326;POINT(-11.1111111 40)') ), (ST_GeogFromText('SRID=4326;POINT(-11.1111111 55)') )) As b(geog);
-- #729 --
Modified: branches/2.5/regress/tickets_expected
--- branches/2.5/regress/tickets_expected 2018-11-26 16:31:20 UTC (rev 17077)
+++ branches/2.5/regress/tickets_expected 2018-11-27 00:14:17 UTC (rev 17078)
@@ -124,10 +124,10 @@
ERROR: First argument must be a LINESTRING
#696|010f000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f0000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000000000000000000000000000000000001030000800100000005000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000
000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000010300008001000000050000000000000000000000000000000000f03f00000000000000000000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f00000000000000000103000080010000000500000000000000000000000000000000000000000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f000000000000f03f000000000000f03f0000000000000000000000000000f03f000000000000f03f00000000000000000000000000000000000000000000f03f
#720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54 11028513.63)
-#723|0101000020e61000006284f068e33826c00000000000004440
-#723|0107000020e610000000000000
-#723|0101000020e61000006284f068e33826c00100000000804b40
+#723|f
+#723|t
+#723|t
+#723|f
#804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos srsDimension="2">0 0</gml:pos></gml:Point>
#845|t
#834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
