[postgis-tickets] [PostGIS] #4260: FreeBSD failures
PostGIS trac at osgeo.org
Tue Nov 27 02:52:49 PST 2018
 Reporter:  Algunenano  |      Owner:  Algunenano
     Type:  defect      |     Status:  assigned
 Priority:  medium      |  Milestone:  PostGIS 3.0.0
Component:  liblwgeom   |    Version:  trunk
 Keywords:              |
 02:22:50
 psql:/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/e90f4dcfde28ab68e70c38fc761960a2060f82fa/regress/00
 -regress-install/share/contrib/postgis/rtpostgis.sql:129: ERROR:  could
 not load library
 "/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/e90f4dcfde28ab68e70c38fc761960a2060f82fa/regress/00
 -regress-install/lib/rtpostgis-3.so": dlopen
 (/usr/home/jenkins/workspace/PostGIS_Worker_Run/label/bessie32/e90f4dcfde28ab68e70c38fc761960a2060f82fa/regress/00
 -regress-install/lib/rtpostgis-3.so) failed:
 -regress-install/lib/rtpostgis-3.so: Undefined symbol "lwgeom_is_empty"
 lwgeom_is_empty is located in "lwinline.h" which I guess should be
 installed too as it's included by "liblwgeom.h"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4260>
