[postgis-tickets] [PostGIS] #4260: FreeBSD failures
trac at osgeo.org
Tue Nov 27 03:00:25 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: liblwgeom | Version: trunk
Resolution: | Keywords:
Comment (by komzpa):
everything in lwinline is inlined on compile time. even if it wasn't,
link-time dependencies aren't done via .h files install.
This looks more like using installed version of liblwgeom instead of the
one in the tree, as it started showing only after bessie started building
older branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4260#comment:1>
