[postgis-tickets] [PostGIS] #4260: FreeBSD failures
trac at osgeo.org
Tue Nov 27 03:30:57 PST 2018
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.0
Component: liblwgeom | Version: trunk
Resolution: | Keywords:
Comment (by Algunenano):
> This looks more like using installed version of liblwgeom instead of the
one in the tree, as it started showing only after bessie started building
older branches.
I think you are right, `rt_pg/Makefile` is including LIBLWGEOM_CFLAGS
after the rest of the `CFLAGS` but it should be included first.
> Even better question: do we need to install headers at all, if liblwgeom
is our private thing?
AFAIK `liblwgeom` isn't "our private thing" and it's used by external
projects. Those projects will need `lwinline.h` too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4260#comment:3>
