[postgis-tickets] [PostGIS] #4259: PostGIS 2.5 unable to compile with GDAL 2.3
PostGIS trac at osgeo.org
Tue Nov 27 08:18:47 PST 2018
  Reporter:  nstires  |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.2
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:  postgis gdal
Comment (by Algunenano):
 > One thing of note: the lib path is set to lib64, but they actually
 reside within /usr/lib. I've also built the gdal packages, is this a build
 flag?
 Most likely your `/usr/lib64` just points to `/usr/lib`:
 $ ls -al /usr/lib64
 lrwxrwxrwx 1 root root 3 ago 21 16:21 /usr/lib64 -> lib
 The problem appears to reside in your GDAL installation. From the log:
 configure:17642: gcc -o conftest -Wall -Wmissing-prototypes -Wpointer-
 arith -Wdeclaration-after-statement -Wendif-labels -Wmissing-format-
 attribute -Wformat-security -fno-strict-aliasing -fwrapv -O2 -g -pipe
 -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-
 buffer-size=4 -m64 -mtune=generic -I/usr/include  conftest.c -L/usr/lib64
 -lgdal >&5
 /usr/lib/libgdal.so: undefined reference to
 `std::__detail::_List_node_base::_M_hook(std::__detail::_List_node_base*)'
 /usr/lib/libgdal.so: undefined reference to `std::_Hash_bytes(void const*,
 unsigned long, unsigned long)'
 `std::__detail::_List_node_base::_M_unhook()'
 `std::__detail::_Prime_rehash_policy::_M_next_bkt(unsigned long) const'
 `std::__detail::_List_node_base::_M_transfer(std::__detail::_List_node_base*,
 `std::__detail::_Prime_rehash_policy::_M_need_rehash(unsigned long,
 unsigned long, unsigned long) const'
 /usr/lib/libgdal.so: undefined reference to `std::string::back()'
 collect2: error: ld returned 1 exit status
 configure:17642: $? = 1
 configure: failed program was:
 You might be mixing gcc or libstdc++ releases so you'll need to find how
 to sort it out.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4259#comment:3>
