[postgis-tickets] [PostGIS] #4261: Revise index lock mode in spatial_index_read_extent
trac at osgeo.org
Wed Nov 28 01:41:42 PST 2018
Reporter: Algunenano | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
From IRC, use `andehhh` has reported a locking problem related with an
external process having an `AccessShareLock` to the spatial index and a
call to `st_estimatedextent`.
As `st_estimatedextent` is using `AccessExclusiveLock` it will block until
the other function finishes even though it's only using it for reading.
We could revise whether that level of exclusive access to the index is
really needed or we can make do with less "exclusivity".
From [1]:
Index access methods must handle concurrent updates of the index by
multiple processes. The core PostgreSQL system obtains AccessShareLock on
the index during an index scan, and RowExclusiveLock when updating the
index (including plain VACUUM). Since these lock types do not conflict,
the access method is responsible for handling any fine-grained locking it
might need. An exclusive lock on the index as a whole will be taken only
during index creation, destruction, or REINDEX.
I understand that the operation we are doing in
`spatial_index_read_extent` is equivalent to an index scan but I don't
think the perf gain it's worth the added complexity of dealing with
concurrent modifications. We could avoid that using "just" a
`ExclusiveLock`, which allows concurrent read locks but blocks any
modifications.
Am I missing something?
Some refs:
[1] https://www.postgresql.org/docs/11/index-locking.html
[2] https://www.postgresql.org/docs/11/index-scanning.html
[3] https://www.postgresql.org/docs/11/explicit-locking.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4261>
