[postgis-tickets] r17082 - Update PostgreSQL note about lowest minor supported, add updated output of tests, minor casing fix on NEWS
Regina Obe
lr at pcorp.us
Wed Nov 28 12:58:58 PST 2018
Author: robe
Date: 2018-11-28 12:58:57 -0800 (Wed, 28 Nov 2018)
New Revision: 17082
trunk/NEWS
trunk/doc/installation.xml
trunk/doc/postgis.xml
Modified: trunk/NEWS
--- trunk/NEWS 2018-11-27 00:23:41 UTC (rev 17081)
+++ trunk/NEWS 2018-11-28 20:58:57 UTC (rev 17082)
@@ -24,8 +24,8 @@
radius in table (Darafei Praliaskouski, github user Boscop).
- #4161, MVT: Drop geometries smaller than the resolution (Raúl Marín)
- #4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
- - #4181, St_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
- - #4183, St_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
+ - #4181, ST_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
+ - #4183, ST_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
- #4188, Avoid division by zero in KMeans (Raúl Marín)
- #4189, Fix undefined behaviour in SADFWrite (Raúl Marín)
- #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
Modified: trunk/doc/installation.xml
--- trunk/doc/installation.xml 2018-11-27 00:23:41 UTC (rev 17081)
+++ trunk/doc/installation.xml 2018-11-28 20:58:57 UTC (rev 17082)
@@ -91,7 +91,7 @@
<note><para>If you are on windows, do not quote the driver list</para></note>
<para>Setting environment variables varies depending on OS. For PostgreSQL installed on Ubuntu or Debian via apt-postgresql, the preferred way is to
- edit <filename>/etc/postgresql/<replaceable>10</replaceable>/<replaceable>main</replaceable>/environment</filename> where 9.3 refers to version of PostgreSQL and main refers to the cluster.</para>
+ edit <filename>/etc/postgresql/<replaceable>10</replaceable>/<replaceable>main</replaceable>/environment</filename> where 10 refers to version of PostgreSQL and main refers to the cluster.</para>
<para>On windows, if you are running as a service, you can set via System variables which for Windows 7 you can get to by right-clicking on Computer->Properties Advanced System Settings or in explorer navigating to <varname>Control Panel\All Control Panel Items\System</varname>.
Then clicking <emphasis>Advanced System Settings ->Advanced->Environment Variables</emphasis> and adding new system variables.</para>
@@ -722,6 +722,7 @@
address_standardizer | &last_release_version; | &last_release_version;
address_standardizer_data_us | &last_release_version; | &last_release_version;
postgis | &last_release_version; | &last_release_version;
+ postgis_raster | &last_release_version; | &last_release_version;
postgis_sfcgal | &last_release_version; |
postgis_tiger_geocoder | &last_release_version; | &last_release_version;
postgis_topology | &last_release_version; |
@@ -733,6 +734,7 @@
<para>If you have the extensions available, you can install postgis extension in your database of choice by either using pgAdmin extension interface or running these sql commands:</para>
<programlisting>CREATE EXTENSION postgis;
+CREATE EXTENSION postgis_raster;
CREATE EXTENSION postgis_sfcgal;
CREATE EXTENSION fuzzystrmatch; --needed for postgis_tiger_geocoder
--optional used by postgis_tiger_geocoder, or can be used standalone
@@ -829,11 +831,12 @@
following:
</para>
- <programlisting> CUnit - A unit testing framework for C - Version 2.1-2
+ <programlisting>
+ CUnit - A unit testing framework for C - Version 2.1-2
http://cunit.sourceforge.net/
-Suite: computational_geometry
+Suite: algorithm
Test: test_lw_segment_side ...passed
Test: test_lw_segment_intersects ...passed
Test: test_lwline_crossing_short_lines ...passed
@@ -842,7 +845,10 @@
Test: test_lwpoint_set_ordinate ...passed
Test: test_lwpoint_get_ordinate ...passed
Test: test_point_interpolate ...passed
+ Test: test_lwline_interpolate_points ...passed
Test: test_lwline_clip ...passed
+ Test: test_lwpoly_clip ...passed
+ Test: test_lwtriangle_clip ...passed
Test: test_lwline_clip_big ...passed
Test: test_lwmline_clip ...passed
Test: test_geohash_point ...passed
@@ -851,6 +857,14 @@
Test: test_geohash_point_as_int ...passed
Test: test_isclosed ...passed
Test: test_lwgeom_simplify ...passed
+ Test: test_lw_arc_center ...passed
+ Test: test_point_density ...passed
+ Test: test_kmeans ...passed
+ Test: test_median_handles_3d_correctly ...passed
+ Test: test_median_robustness ...passed
+ Test: test_lwpoly_construct_circle ...passed
+ Test: test_trim_bits ...passed
+ Test: test_lwgeom_remove_repeated_points ...passed
Suite: buildarea
Test: buildarea1 ...passed
Test: buildarea2 ...passed
@@ -872,7 +886,6 @@
Test: test_sphere_direction ...passed
Test: test_sphere_project ...passed
Test: test_lwgeom_area_sphere ...passed
- Test: test_signum ...passed
Test: test_gbox_from_spherical_coordinates ...passed
Test: test_gserialized_get_gbox_geocentric ...passed
Test: test_clairaut ...passed
@@ -892,20 +905,31 @@
Test: test_lwgeom_segmentize_sphere ...passed
Test: test_ptarray_contains_point_sphere ...passed
Test: test_ptarray_contains_point_sphere_iowa ...passed
-Suite: GEOS
+ Test: test_gbox_to_string_truncated ...passed
+Suite: geos
Test: test_geos_noop ...passed
Test: test_geos_subdivide ...passed
Test: test_geos_linemerge ...passed
-Suite: Clustering
+ Test: test_geos_offsetcurve ...passed
+ Test: test_geos_offsetcurve_crash ...passed
+ Test: test_geos_makevalid ...passed
+Suite: clustering
Test: basic_test ...passed
Test: nonsequential_test ...passed
Test: basic_distance_test ...passed
Test: single_input_test ...passed
Test: empty_inputs_test ...passed
-Suite: Clustering Union-Find
+ Test: multipoint_test ...passed
+ Test: dbscan_test ...passed
+ Test: dbscan_test_3612a ...passed
+ Test: dbscan_test_3612b ...passed
+ Test: dbscan_test_3612c ...passed
+Suite: clustering_unionfind
Test: test_unionfind_create ...passed
Test: test_unionfind_union ...passed
Test: test_unionfind_ordered_by_cluster ...passed
+ Test: test_unionfind_path_compression ...passed
+ Test: test_unionfind_collapse_cluster_ids ...passed
Suite: homogenize
Test: test_coll_point ...passed
Test: test_coll_line ...passed
@@ -920,6 +944,13 @@
Test: in_geojson_test_srid ...passed
Test: in_geojson_test_bbox ...passed
Test: in_geojson_test_geoms ...passed
+Suite: iterator
+ Test: test_point_count ...passed
+ Test: test_ordering ...passed
+ Test: test_modification ...passed
+ Test: test_mixed_rw_access ...passed
+ Test: test_cannot_modify_read_only ...passed
+ Test: test_no_memory_leaked_when_iterator_is_partially_used ...passed
Suite: twkb_input
Test: test_twkb_in_point ...passed
Test: test_twkb_in_linestring ...passed
@@ -932,7 +963,8 @@
Suite: serialization/deserialization
Test: test_typmod_macros ...passed
Test: test_flags_macros ...passed
- Test: test_serialized_srid ...passed
+ Test: test_serialized_srid ...NOTICE: SRID value -3005 converted to the officially unknown SRID value 0
+passed
Test: test_gserialized_from_lwgeom_size ...passed
Test: test_gbox_serialized_size ...passed
Test: test_lwgeom_from_gserialized ...passed
@@ -941,7 +973,7 @@
Test: test_geometry_type_from_string ...passed
Test: test_lwcollection_extract ...passed
Test: test_lwgeom_free ...passed
- Test: test_lwgeom_flip_coordinates ...passed
+ Test: test_lwgeom_swap_ordinates ...passed
Test: test_f2d ...passed
Test: test_lwgeom_clone ...passed
Test: test_lwgeom_force_clockwise ...passed
@@ -952,12 +984,26 @@
Test: test_lwgeom_as_curve ...passed
Test: test_lwgeom_scale ...passed
Test: test_gserialized_is_empty ...passed
+ Test: test_gserialized_peek_gbox_p_no_box_when_empty ...passed
+ Test: test_gserialized_peek_gbox_p_gets_correct_box ...passed
+ Test: test_gserialized_peek_gbox_p_fails_for_unsupported_cases ...passed
Test: test_gbox_same_2d ...passed
+ Test: test_signum_macro ...passed
+Suite: lwstroke
+ Test: test_lwcurve_linearize ...passed
+ Test: test_unstroke ...passed
Suite: measures
Test: test_mindistance2d_tolerance ...passed
+ Test: test_mindistance3d_tolerance ...NOTICE: One or both of the geometries is missing z-value. The unknown z-value will be regarded as "any value"
+passed
Test: test_rect_tree_contains_point ...passed
Test: test_rect_tree_intersects_tree ...passed
- Test: test_lwgeom_segmentize2d ...passed
+ Test: test_lwgeom_segmentize2d ...NOTICE: ptarray.c:445 - ptarray_segmentize2d: Too many segments required (1.000000e+101)
+NOTICE: liblwgeom code interrupted
+passed
Test: test_lwgeom_locate_along ...passed
Test: test_lw_dist2d_pt_arc ...passed
Test: test_lw_dist2d_seg_arc ...passed
@@ -966,10 +1012,25 @@
Test: test_lw_dist2d_pt_ptarrayarc ...passed
Test: test_lw_dist2d_ptarray_ptarrayarc ...passed
Test: test_lwgeom_tcpa ...passed
- Test: test_lwgeom_is_trajectory ...passed
+ Test: test_lwgeom_is_trajectory ...NOTICE: Geometry is not a LINESTRING
+NOTICE: Line does not have M dimension
+NOTICE: Measure of vertex 1 (1) not bigger than measure of vertex 0 (1)
+NOTICE: Measure of vertex 1 (0) not bigger than measure of vertex 0 (1)
+NOTICE: Measure of vertex 2 (2) not bigger than measure of vertex 1 (3)
+passed
+ Test: test_rect_tree_distance_tree ...passed
Suite: effectivearea
Test: do_test_lwgeom_effectivearea_lines ...passed
Test: do_test_lwgeom_effectivearea_polys ...passed
+Suite: chaikin
+ Test: do_test_chaikin_lines ...passed
+ Test: do_test_chaikin_polygons ...passed
+Suite: filterm
+ Test: do_test_filterm_single_geometries ...passed
+ Test: do_test_filterm_collections ...passed
+Suite: minimum_bounding_circle
+ Test: basic_test ...passed
+ Test: test_empty ...passed
Suite: miscellaneous
Test: test_misc_force_2d ...passed
Test: test_misc_simplify ...passed
@@ -977,6 +1038,9 @@
Test: test_misc_area ...passed
Test: test_misc_wkb ...passed
Test: test_grid ...passed
+ Test: test_grid_in_place ...passed
+ Test: test_clone ...passed
+ Test: test_lwmpoint_from_lwgeom ...passed
Suite: noding
Test: test_lwgeom_node ...passed
Suite: encoded_polyline_output
@@ -1020,7 +1084,6 @@
Test: test_ptarray_locate_point ...passed
Test: test_ptarray_isccw ...passed
Test: test_ptarray_signed_area ...passed
- Test: test_ptarray_unstroke ...passed
Test: test_ptarray_insert_point ...passed
Test: test_ptarray_contains_point ...passed
Test: test_ptarrayarc_contains_point ...passed
@@ -1031,7 +1094,7 @@
Test: test_lwprint_optional_format ...passed
Test: test_lwprint_oddball_formats ...passed
Test: test_lwprint_bad_formats ...passed
-Suite: SFCGAL
+Suite: sfcgal
Test: test_sfcgal_noop ...passed
Suite: split
Test: test_lwline_split_by_point_to ...passed
@@ -1044,7 +1107,7 @@
Test: tin_parse ...passed
Test: polyhedralsurface_parse ...passed
Test: surface_dimension ...passed
-Suite: Internal Spatial Trees
+Suite: spatial_trees
Test: test_tree_circ_create ...passed
Test: test_tree_circ_pip ...passed
Test: test_tree_circ_pip2 ...passed
@@ -1052,6 +1115,9 @@
Test: test_tree_circ_distance_threshold ...passed
Suite: triangulate
Test: test_lwgeom_delaunay_triangulation ...passed
+ Test: test_lwgeom_voronoi_diagram ...passed
+ Test: test_lwgeom_voronoi_diagram_expected_empty ...passed
+ Test: test_lwgeom_voronoi_diagram_custom_envelope ...passed
Suite: twkb_output
Test: test_twkb_out_point ...passed
Test: test_twkb_out_linestring ...passed
@@ -1109,6 +1175,7 @@
Test: test_wkt_in_tin ...passed
Test: test_wkt_in_polyhedralsurface ...passed
Test: test_wkt_in_errlocation ...passed
+ Test: test_wkt_double ...passed
Suite: wkt_output
Test: test_wkt_out_point ...passed
Test: test_wkt_out_linestring ...passed
@@ -1122,68 +1189,68 @@
Test: test_wkt_out_curvpolygon ...passed
Test: test_wkt_out_multicurve ...passed
Test: test_wkt_out_multisurface ...passed
+Suite: wrapx
+ Test: test_lwgeom_wrapx ...passed
Run Summary: Type Total Ran Passed Failed Inactive
- suites 38 38 n/a 0 0
- tests 251 251 251 0 0
- asserts 2468 2468 2468 0 n/a
+ suites 44 44 n/a 0 0
+ tests 299 299 299 0 0
+ asserts 4087 4087 4087 0 n/a
-Elapsed time = 0.298 seconds
+Elapsed time = 0.196 seconds
-Creating database 'postgis_reg'
-Loading PostGIS into 'postgis_reg'
- /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/postgis.sql
- /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/postgis_comments.sql
-Loading SFCGAL into 'postgis_reg'
- /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/sfcgal.sql
- /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/sfcgal_comments.sql
-PostgreSQL 9.4.4, compiled by Visual C++ build 1800, 32-bit
- Postgis 2.2.0dev - r13980 - 2015-08-23 06:13:07
- scripts 2.2.0dev r13980
- GEOS: 3.5.0-CAPI-1.9.0 r4088
- PROJ: Rel. 4.9.1, 04 March 2015
- SFCGAL: 1.1.0
+PostgreSQL 12devel on x86_64-w64-mingw32, compiled by gcc.exe (x86_64-posix-seh-rev0, Built by MinGW-W64 project) 8.1.0, 64-bit
+ Postgis 3.0.0dev - r17081 - 2018-11-28 18:50:02
+ scripts 3.0.0dev r17081
+ GEOS: 3.7.0-CAPI-1.11.0 673b9939
+ PROJ: Rel. 5.2.0, September 15th, 2018
Running tests
- loader/Point .............. ok
- loader/PointM .............. ok
- loader/PointZ .............. ok
- loader/MultiPoint .............. ok
- loader/MultiPointM .............. ok
- loader/MultiPointZ .............. ok
- loader/Arc .............. ok
- loader/ArcM .............. ok
- loader/ArcZ .............. ok
- loader/Polygon .............. ok
- loader/PolygonM .............. ok
- loader/PolygonZ .............. ok
- loader/TSTPolygon ......... ok
- loader/TSIPolygon ......... ok
- loader/TSTIPolygon ......... ok
- loader/PointWithSchema ..... ok
- loader/NoTransPoint ......... ok
- loader/NotReallyMultiPoint ......... ok
- loader/MultiToSinglePoint ......... ok
- loader/ReprojectPts ........ ok
- loader/ReprojectPtsGeog ........ ok
- loader/Latin1 .... ok
- loader/Latin1-implicit .... ok
- loader/mfile .... ok
- dumper/literalsrid ....... ok
- dumper/realtable ....... ok
+ ../loader/Point .............. ok
+ ../loader/PointM .............. ok
+ ../loader/PointZ .............. ok
+ ../loader/MultiPoint .............. ok
+ ../loader/MultiPointM .............. ok
+ ../loader/MultiPointZ .............. ok
+ ../loader/Arc .............. ok
+ ../loader/ArcM .............. ok
+ ../loader/ArcZ .............. ok
+ ../loader/Polygon .............. ok
+ ../loader/PolygonM .............. ok
+ ../loader/PolygonZ .............. ok
+ ../loader/TSTPolygon ......... ok
+ ../loader/TSIPolygon ......... ok
+ ../loader/TSTIPolygon ......... ok
+ ../loader/PointWithSchema ..... ok
+ ../loader/NoTransPoint ......... ok
+ ../loader/NotReallyMultiPoint ......... ok
+ ../loader/MultiToSinglePoint ......... ok
+ ../loader/ReprojectPts ........ ok
+ ../loader/ReprojectPtsGeog ........ ok
+ ../loader/Latin1 .... ok
+ ../loader/Latin1-implicit .... ok
+ ../loader/mfile .... ok
+ ../dumper/literalsrid ....... ok
+ ../dumper/realtable ....... ok
affine .. ok
bestsrid .. ok
binary .. ok
boundary .. ok
+ chaikin .. ok
+ filterm .. ok
cluster .. ok
concave_hull .. ok
+ concave_hull_hard .. ok
ctors .. ok
+ curvetoline .. ok
dump .. ok
dumppoints .. ok
empty .. ok
+ estimatedextent .. ok
forcecurve .. ok
geography .. ok
+ geometric_median .. ok
in_geohash .. ok
in_gml .. ok
in_kml .. ok
@@ -1193,14 +1260,19 @@
long_xact .. ok
lwgeom_regress .. ok
measures .. ok
+ minimum_bounding_circle .. ok
+ normalize .. ok
operators .. ok
+ orientation .. ok
out_geometry .. ok
out_geography .. ok
polygonize .. ok
polyhedralsurface .. ok
postgis_type_name .. ok
+ quantize_coordinates .. ok
regress .. ok
regress_bdpoly .. ok
+ regress_gist_index_nd .. ok
regress_index .. ok
regress_index_nulls .. ok
regress_management .. ok
@@ -1213,6 +1285,7 @@
relate .. ok
remove_repeated_points .. ok
removepoint .. ok
+ reverse .. ok
setpoint .. ok
simplify .. ok
simplifyvw .. ok
@@ -1235,9 +1308,11 @@
wkb .. ok
wkt .. ok
wmsservers .. ok
- knn .. ok
+ knn_recheck .. ok
+ temporal_knn .. ok
hausdorff .. ok
regress_buffer_params .. ok
+ frechet .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
@@ -1250,24 +1325,22 @@
delaunaytriangles .. ok
clipbybox2d .. ok
subdivide .. ok
+ voronoi .. ok
+ minimum_clearance .. ok
+ oriented_envelope .. ok
in_geojson .. ok
- regress_sfcgal .. ok
- sfcgal/empty .. ok
- sfcgal/geography .. ok
- sfcgal/legacy .. ok
- sfcgal/measures .. ok
- sfcgal/regress_ogc_prep .. ok
- sfcgal/regress_ogc .. ok
- sfcgal/regress .. ok
- sfcgal/tickets .. ok
- sfcgal/concave_hull .. ok
- sfcgal/wmsservers .. ok
- sfcgal/approximatemedialaxis .. ok
- uninstall . /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/uninstall_sfcgal.sql
- /projects/postgis/branches/2.2/regress/00-regress-install/share/contrib/postgis/uninstall_postgis.sql
-. ok (4336)
+ regress_brin_index .. ok
+ regress_brin_index_3d .. ok
+ regress_brin_index_geography .. ok
+ regress_spgist_index_2d .. ok
+ regress_spgist_index_3d .. ok
+ regress_spgist_index_nd .. ok
+ mvt .. ok
+ geobuf .. ok
+ mvt_jsonb .. ok
+ uninstall .. ok (4643)
-Run tests: 118
+Run tests: 134
Failed: 0
-- if you built --with-gui, you should see this too
Modified: trunk/doc/postgis.xml
--- trunk/doc/postgis.xml 2018-11-27 00:23:41 UTC (rev 17081)
+++ trunk/doc/postgis.xml 2018-11-28 20:58:57 UTC (rev 17082)
@@ -4,7 +4,7 @@
<!-- This value is automatically generated by the Makefile -->
<!ENTITY last_release_version "@@LAST_RELEASE_VERSION@@">
-<!ENTITY last_minor_version "2.4">
+<!ENTITY last_minor_version "3.0">
<!-- ONCE Tagged, this need to change to http://download.osgeo.org/postgis/source/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
<!-- In dev should be, this need to change to http://postgis.net/stuff/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
@@ -12,8 +12,8 @@
<!-- Change these values to update the version numbers referenced within the documentation -->
<!ENTITY last_proj_release_version "5.1.0">
-<!ENTITY last_geos_release_version "3.7.0beta1">
-<!ENTITY min_postgres_version "9.4">
+<!ENTITY last_geos_release_version "3.7.0">
+<!ENTITY min_postgres_version "9.5">
<!ENTITY introduction SYSTEM "introduction.xml">
<!ENTITY installation SYSTEM "installation.xml">
