[postgis-tickets] [PostGIS] #4193: Create rt_legacy.c, postgis_legacy.c
trac at osgeo.org
Mon Oct 1 21:51:15 PDT 2018
Reporter: robe | Owner: robe
Type: task | Status: assigned
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Description changed by robe:
Old description:
> I plan to create two c script files to store legacy functions and each
> function will just throw an error when called instructing the user to
> upgrade their install.
> This was Darafei's idea and I think a good one even if we don't go into
> the "Oh my god we are changing so much" that gave pramsey the
> heebeegeebees in this pull request
> https://github.com/postgis/postgis/pull/302
> For starters I will put the pg_abs and the RT_AsBinary thingy functions
> in herethat were taken out in 2.5.
> These I had already changed in 2.5 to stub with errors so symlink still
> works.
> That will allow coming from 2.2 -> 3.0 by symlinking when you do a
> pg_upgrade.
> Next I will find the function we took out in 2.2 (I forget the name) that
> broke pg_upgrading between 2.1 and 2.2
> I think we might have some breakers between 2.0 and 2.1 as well which
> I'll try to dig up.
> I'm hoping all those folks stuck in 2.0 and 2.1 because their database is
> too big not to do a dump restore can be encouraged to move up to 3.0 if
> pg_upgrade from 2.0 -> 3.0 is relatively painless
New description:
I plan to create two c function files to store legacy functions and each
works.
pg_upgrade.
I think we might have some breakers between 2.0 and 2.1 as well which I'll
try to dig up.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4193#comment:1>
