[postgis-tickets] r16877 - St_AsMVTGeom: Handle type changes in geometry collections
Darafei "Komяpa" Praliaskouski me at komzpa.net
Wed Oct 3 09:07:56 PDT 2018
On ср, 3 кас 2018, 07:11 Raul <raul at rmr.ninja> wrote:
> Author: algunenano
> Date: 2018-10-03 04:11:12 -0700 (Wed, 03 Oct 2018)
> New Revision: 16877
> Modified:
>    branches/2.5/postgis/mvt.c
>    branches/2.5/regress/mvt.sql
>    branches/2.5/regress/mvt_expected
> Log:
> References #4181
> Modified: branches/2.5/postgis/mvt.c
> --- branches/2.5/postgis/mvt.c  2018-10-03 10:52:58 UTC (rev 16876)
> +++ branches/2.5/postgis/mvt.c  2018-10-03 11:11:12 UTC (rev 16877)
> @@ -727,6 +727,39 @@
>         POSTGIS_DEBUGF(3, "parse_values n_tags %zd", ctx->feature->n_tags);
> +/* For a given geometry, look for the highest dimensional basic type,
> that is,
> + * point, line or polygon */
> +static uint8
> +lwgeom_get_basic_type(LWGEOM *geom)
It looks like lwgeom_dimensionality which is also a copy of
lwgeom_dimension?
> +       switch(geom->type)
> +       case POINTTYPE:
> +       case LINETYPE:
> +       case POLYGONTYPE:
> +               return geom->type;
> +       case MULTIPOINTTYPE:
> +       case MULTILINETYPE:
> +       case MULTIPOLYGONTYPE:
> +               return geom->type - 3; /* Based on LWTYPE positions */
> +       case COLLECTIONTYPE:
> +               uint32_t i;
> +               uint8 type = 0;
> +               LWCOLLECTION *g = (LWCOLLECTION*)geom;
> +               for (i = 0; i < g->ngeoms; i++)
> +                       LWGEOM *sg = g->geoms[i];
> +                       type = Max(type, lwgeom_get_basic_type(sg));
> +               return type;
> +       default:
> +               elog(ERROR, "%s: Invalid type (%d)", __func__, geom->type);
>   * In place process a collection to find a concrete geometry
>   * object and expose that as the actual object. Will some
> @@ -734,27 +767,12 @@
>   * draw it anyways.
>  static void
> -lwgeom_to_basic_type(LWGEOM *geom)
> +lwgeom_to_basic_type(LWGEOM *geom, uint8 original_type)
>         if (lwgeom_get_type(geom) == COLLECTIONTYPE)
> -               /* MVT doesn't handle generic collections, so we */
> -               /* need to strip them down to a typed collection */
> -               /* by finding the largest basic type available and */
> -               /* using that as the basis of a typed collection. */
> -               LWCOLLECTION *gc;
> -               uint32_t i, maxtype = 0;
> -               for (i = 0; i < g->ngeoms; i++)
> -                       LWGEOM *sg = g->geoms[i];
> -                       if (sg->type > maxtype && sg->type <
> COLLECTIONTYPE)
> -                               maxtype = sg->type;
> -               if (maxtype > 3) maxtype -= 3;
> -               /* Force the working geometry to be a simpler version */
> -               /* of itself */
> -               gc = lwcollection_extract(g, maxtype);
> +               LWCOLLECTION *gc = lwcollection_extract(g, original_type);
>                 *g = *gc;
> @@ -776,6 +794,7 @@
>         double height = gbox->ymax - gbox->ymin;
>         double resx, resy, res, fx, fy;
>         int preserve_collapsed = LW_TRUE;
> +       const uint8_t basic_type = lwgeom_get_basic_type(lwgeom);
>         POSTGIS_DEBUG(2, "mvt_geom called");
>         /* Short circuit out on EMPTY */
> @@ -832,9 +851,7 @@
>                         /* For some polygons, the simplify step might have
> left them
>                          * as invalid, which can cause clipping to return
> the complementary
>                          * geometry of what it should */
> -                       if ((lwgeom->type == POLYGONTYPE ||
> -                               lwgeom->type == MULTIPOLYGONTYPE ||
> -                               lwgeom->type == COLLECTIONTYPE) &&
> +                       if ((basic_type == POLYGONTYPE) &&
>                             !gbox_contains_2d(&pre_clip_box,
> lwgeom_get_bbox(clipped_geom)))
>                                 /* TODO: Adapt this when and if Exception
> Policies are introduced.
> @@ -870,22 +887,11 @@
>                 return NULL;
> -       if (lwgeom->type == POLYGONTYPE ||
> +       if (basic_type == POLYGONTYPE)
>                 /* Force validation as per MVT spec */
>                 lwgeom = lwgeom_make_valid(lwgeom);
> -               /* Drop type changes tp play nice with MVT renderers */
> -               if (!(lwgeom->type == POLYGONTYPE ||
> -                       lwgeom->type == COLLECTIONTYPE))
> -                       lwgeom_free(lwgeom);
> -                       return NULL;
>                 /* In image coordinates CW actually comes out a CCW, so we
> reverse */
>                 lwgeom_force_clockwise(lwgeom);
>                 lwgeom_reverse_in_place(lwgeom);
> @@ -893,8 +899,15 @@
>         /* if geometry collection extract highest dimensional geometry
> type */
>         if (lwgeom->type == COLLECTIONTYPE)
> -               lwgeom_to_basic_type(lwgeom);
> +               lwgeom_to_basic_type(lwgeom, basic_type);
> +       if (basic_type != lwgeom_get_basic_type(lwgeom))
> +               /* Drop type changes to play nice with MVT renderers */
> +               POSTGIS_DEBUG(3, "mvt_geom: Dropping geometry after type
> change");
> +               return NULL;
>         if (lwgeom == NULL || lwgeom_is_empty(lwgeom))
>                 return NULL;
> Modified: branches/2.5/regress/mvt.sql
> --- branches/2.5/regress/mvt.sql        2018-10-03 10:52:58 UTC (rev 16876)
> +++ branches/2.5/regress/mvt.sql        2018-10-03 11:11:12 UTC (rev 16877)
> @@ -273,6 +273,14 @@
>         16,
>         true));
> +-- Geometry type change of one geometry of the multipolygon used to
> fallback to multilinestring
> +SELECT 'PG46', St_AsEWKT(ST_AsMVTGeom(
> +       'SRID=3857;MULTIPOLYGON(((-8230324.85567616
> 4984496.35685962,-8230307.1114228 4984654.46474466,-8230285.21085987
> 4984959.60349704,-8230324.85567616 4984496.35685962)),((-8230327.54013683
> 4984444.33052449,-8230327.23971431 4984450.39401942,-8230327.26833036
> 4984449.87731981,-8230327.54013683 4984444.33052449)))'::geometry,
> +       'SRID=3857;POLYGON((-8238077.16046316
> 4989809.20645631,-8238077.16046316 4980025.2668358,-8228293.22084265
> 4980025.2668358,-8228293.22084265 4989809.20645631,-8238077.16046316
> 4989809.20645631))'::geometry,
> +       4096,
> +       16,
> +       true));
>  -- geometry encoding tests
>  SELECT 'TG1', encode(ST_AsMVT(q, 'test', 4096, 'geom'), 'base64') FROM
> (SELECT 1 AS c1,
>         ST_AsMVTGeom(ST_GeomFromText('POINT(25 17)'),
> @@ -433,11 +441,11 @@
>         FROM (SELECT NULL::integer AS c1, NULL AS geom) AS q;
>  -- Ticket #3922
> -SELECT '#3922', length(bytea(ST_AsMVTGeom(
> +SELECT '#3922', St_AsEWKT(ST_AsMVTGeom(
> st_geomfromtwkb('\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
>  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
>  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'),
>                 'SRID=3347;POLYGON((3658201 658873,3658201
> 5958872.97428571,8958201.49428571 5958872.97428571,8958201.49428571
> 658873,3658201 658873))'::geometry,
>                 4096,
>                 0,
>                 true
> Modified: branches/2.5/regress/mvt_expected
> --- branches/2.5/regress/mvt_expected   2018-10-03 10:52:58 UTC (rev 16876)
> +++ branches/2.5/regress/mvt_expected   2018-10-03 11:11:12 UTC (rev 16877)
> @@ -48,6 +48,7 @@
>  PG43 - OFF|MULTIPOLYGON(((5 5,-1 -1,11 -1,5 5)),((5 5,11 11,-1 11,5 5)))
>  PG44|
>  PG45|
> +PG46|SRID=3857;MULTIPOLYGON(((3245 2224,3262 2030,3253 2158,3245 2224)))
>  TG1|GiEKBHRlc3QSDBICAAAYASIECTLePxoCYzEiAigBKIAgeAI=
>  TG2|GiMKBHRlc3QSDhICAAAYASIGETLePwIBGgJjMSICKAEogCB4Ag==
>  TG3|GiYKBHRlc3QSERICAAAYAiIJCQCAQArQD88PGgJjMSICKAEogCB4Ag==
> @@ -97,4 +98,4 @@
>  TU2
>  ERROR:  pgis_asmvt_transfn: parameter row cannot be other than a rowtype
>  TU3|
> -#3922|91
> +#3922|MULTIPOLYGON(((2613 3664,2615 3662,2616 3662,2617 3665,2615
> 3665,2615 3664,2613 3664)))
> postgis-tickets mailing list
> postgis-tickets at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-tickets
Darafei Praliaskouski
Support me: http://patreon.com/komzpa
URL: <http://lists.osgeo.org/pipermail/postgis-tickets/attachments/20181003/fd3a2a02/attachment-0001.html>
