[postgis-tickets] [PostGIS] #4202: Topology extension upgrade from 2.1.9 to 3.0.0dev fails
trac at osgeo.org
Sun Oct 14 06:41:06 PDT 2018
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Run:
regress/run_test.pl -v --extension \
--topology --upgrade-path 2.1.9--3.0.0dev \
topology/test/regress/st_simplify.sql
I get:
ERROR: cannot drop schema topology because other objects depend on it
DETAIL: function _st_remedgecheck(character
varying,integer,integer,integer,integer) depends on schema topology
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4202>
