[postgis-tickets] r16900 - [topology] properly drop removed internal functions on upgrade
Sandro Santilli strk at kbt.io
Mon Oct 15 03:35:58 PDT 2018
Author: strk
Date: 2018-10-15 03:35:58 -0700 (Mon, 15 Oct 2018)
New Revision: 16900
   trunk/topology/topology_drop_before.sql.in
References #4202 in trunk
Modified: trunk/topology/topology_drop_before.sql.in
--- trunk/topology/topology_drop_before.sql.in	2018-10-15 06:54:20 UTC (rev 16899)
+++ trunk/topology/topology_drop_before.sql.in	2018-10-15 10:35:58 UTC (rev 16900)
@@ -17,3 +17,6 @@
 -- used to be in public, will now be moved to topology
 DROP FUNCTION IF EXISTS postgis_topology_scripts_installed();
+-- Removed in 2.2.0 when topology API moved to liblwgeom
+DROP FUNCTION topology._ST_RemEdgeCheck(varchar, integer, integer, integer, integer);
+DROP FUNCTION topology._ST_AddFaceSplit(varchar, integer, integer, boolean);
