[postgis-tickets] [PostGIS] #4203: GNU Make 4.1 breaks all our extensions making them start with ESC
trac at osgeo.org
Mon Oct 15 04:16:20 PDT 2018
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.8
Component: postgis | Version: 2.2.x
Keywords: |
The line:
echo '\echo Use "CREATE EXTENSION postgis" to load this file. \quit' >
sql/postgis.sql
In our Makefiles have started writing an ESC control character followed by
"cho" as the start of all our extensions. In turn those files break
creating the extension.
All branches affected, for obvious reasons.
Doubling the backslash seems to be a fix with this version of `make`, but
I don't know how it would affect older versions. We need a better way to
output those literal backslashes maybe...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4203>
