[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
trac at osgeo.org
Wed Oct 17 01:33:38 PDT 2018
Reporter: strk | Owner: robe
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords: extension
Comment (by strk):
But what we need is probably a specific test to check if custom
records written in those "config tables" are retained across
dump/reload operations, I guess. This is most likely _not_ done
by run_test.pl (how could it know...)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2503#comment:28>
