[postgis-tickets] [PostGIS] #4206: "getrelid" removed in PostgreSQL v12devel
PostGIS trac at osgeo.org
Wed Oct 17 07:27:24 PDT 2018
  Reporter:  Laurenz Albe           |      Owner:  strk
      Type:  patch                  |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:                         |   Keywords:  getrelid
Comment (by strk):
 In [changeset:"16919" 16919]:
 #!CommitTicketReference repository="" revision="16919"
 Fix support for PostgreSQL-12 ("getrelid" macro removed)
 The call is replaced with its expansion which should work
 as back as PostgreSQL-9.1 which is before the oldest version
 PostGIS-2.2 (our oldest maintained branch) supports.
 This is then safe to backport to all branches till 2.2.
 Patch by Laurenz Albe
 References #4206 in 2.4 branch
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4206#comment:4>
