[postgis-tickets] r16933 - Fix "make check" on platforms without SFCGAL support
Sandro Santilli
strk at kbt.io
Sun Oct 21 11:23:35 PDT 2018
Author: strk
Date: 2018-10-21 23:23:34 -0700 (Sun, 21 Oct 2018)
New Revision: 16933
trunk/regress/Makefile.in
trunk/regress/sfcgal/Makefile.in
Modified: trunk/regress/Makefile.in
--- trunk/regress/Makefile.in 2018-10-21 10:19:25 UTC (rev 16932)
+++ trunk/regress/Makefile.in 2018-10-22 06:23:34 UTC (rev 16933)
@@ -12,6 +12,7 @@
PERL=@PERL@
MINGWBUILD=@MINGWBUILD@
+HAVE_SFCGAL=@HAVE_SFCGAL@
# Where we put our regression installation
ifeq ($(MINGWBUILD),1)
@@ -23,8 +24,12 @@
all:
-check: staged-install check-core check-sfcgal
+check: staged-install check-core
+ifeq ($(HAVE_SFCGAL),yes)
+check: check-sfcgal
+endif
check-core:
$(MAKE) -C core check
Modified: trunk/regress/sfcgal/Makefile.in
--- trunk/regress/sfcgal/Makefile.in 2018-10-21 10:19:25 UTC (rev 16932)
+++ trunk/regress/sfcgal/Makefile.in 2018-10-22 06:23:34 UTC (rev 16933)
@@ -17,6 +17,8 @@
# MingW hack: rather than use PGSQL_BINDIR directly, we change
# to the directory and then use "pwd" to return the path. This
# ensures that the returned path is in MSYS format, otherwise
@@ -29,12 +31,7 @@
PATH := $(PGSQL_BINDIR):$(PATH)
export PATH
-TESTS =
-ifeq ($(HAVE_SFCGAL),yes)
- # SFCGAL additionnal backend
- TESTS += \
+TESTS = \
regress_sfcgal \
empty.sql \
geography.sql \
@@ -48,20 +45,25 @@
wmsservers.sql \
approximatemedialaxis.sql
- SFCGALTESTFLAGS = --sfcgal
-endif
+RUNTESTFLAGS += --sfcgal
+test check:
+ $(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS)
+ # only run upgrade test if RUNTESTFLAGS was not already doing that
+ if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
+ $(PERL) ../run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+ fi
-all install uninstall:
+else
+check:
+endif # HAVE_SFCGAL
distclean: clean
rm Makefile
-test check:
- $(PERL) ../run_test.pl $(RUNTESTFLAGS) $(SFCGALTESTFLAGS) $(TESTS)
- # only run upgrade test if RUNTESTFLAGS was not already doing that
- if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
- $(PERL) ../run_test.pl --upgrade $(RUNTESTFLAGS) $(SFCGALTESTFLAGS) $(TESTS); \
- fi
+all install uninstall:
clean:
