[postgis-tickets] r16938 - ST_Subdivide: support rect hole in rect shell
Darafei komzpa at gmail.com
Mon Oct 22 08:26:49 PDT 2018
Author: komzpa
Date: 2018-10-22 08:26:49 -0700 (Mon, 22 Oct 2018)
New Revision: 16938
   branches/2.5/NEWS
   branches/2.5/liblwgeom/lwgeom.c
   branches/2.5/regress/subdivide.sql
   branches/2.5/regress/subdivide_expected
Closes #4211
Closes https://github.com/postgis/postgis/pull/317
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2018-10-22 15:23:38 UTC (rev 16937)
+++ branches/2.5/NEWS	2018-10-22 15:26:49 UTC (rev 16938)
@@ -8,8 +8,9 @@
   - #4191, Fix undefined behaviour in ptarray_clone_deep (Raúl Marín)
   - #4020, Fix leftovers in topology upgrade from 2.1 (Sandro Santilli)
   - #4206, Fix support for PostgreSQL 12 dev branch (Laurenz Albe)
+  - #4211, Fix ST_Subdivide for minimal exterior ring with minimal hole (Darafei
+    Praliaskouski)
 PostGIS 2.5.0
 2018/09/23
 WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Modified: branches/2.5/liblwgeom/lwgeom.c
--- branches/2.5/liblwgeom/lwgeom.c	2018-10-22 15:23:38 UTC (rev 16937)
+++ branches/2.5/liblwgeom/lwgeom.c	2018-10-22 15:26:49 UTC (rev 16938)
@@ -2353,7 +2353,7 @@
 		lwpoly = (LWPOLY *)geom;
 		/* if there are more points in holes than in outer ring */
-		if (nvertices > 2 * lwpoly->rings[0]->npoints)
+		if (nvertices >= 2 * lwpoly->rings[0]->npoints)
 			/* trim holes starting from biggest */
 			for (i = 1; i < lwpoly->nrings; i++)
Modified: branches/2.5/regress/subdivide.sql
--- branches/2.5/regress/subdivide.sql	2018-10-22 15:23:38 UTC (rev 16937)
+++ branches/2.5/regress/subdivide.sql	2018-10-22 15:26:49 UTC (rev 16938)
@@ -58,3 +58,5 @@
 drop table big_polygon;
 drop table big_polygon_sliced;
+select '#4211', (select sum(ST_Area(geom))::numeric(12,11) from ST_Subdivide('MULTIPOLYGON(((-88.2059 41.7325,-88.2060 41.7244,-88.1959 41.7241,-88.1959 41.7326,-88.2059 41.7325),(-88.1997 41.7289,-88.1996 41.7285,-88.1990 41.7285,-88.1990 41.7289,-88.1997 41.7289)))') geom );
Modified: branches/2.5/regress/subdivide_expected
--- branches/2.5/regress/subdivide_expected	2018-10-22 15:23:38 UTC (rev 16937)
+++ branches/2.5/regress/subdivide_expected	2018-10-22 15:26:49 UTC (rev 16938)
@@ -5,3 +5,4 @@
 #3522|POINT(1 1)
 #3744|1600000000000000
 4|29321996468.6|29321996468.6|1857|256
+#4211|0.00008316000
