[postgis-tickets] [PostGIS] #4219: Report memory leaks on Travis
trac at osgeo.org
Tue Oct 30 11:18:06 PDT 2018
Reporter: komzpa | Owner: dbaston
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.4.6
Component: buildbots | Version: 2.4.x
Resolution: fixed | Keywords:
Changes (by dbaston):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"16962" 16962]:
#!CommitTicketReference repository="" revision="16962"
Add env vars to control valgrind for cunit tests
Valgrind will be run with CUNIT_VALGRIND_FLAGS when
CUNIT_WITH_VALGRIND is set to YES.
Also update the Travis configuration to use valgrind.
Closes #4219
Closes https://github.com/postgis/postgis/pull/323
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4219#comment:3>
