[postgis-tickets] [PostGIS] #4210: PostGIS 3.0 is completely broken
trac at osgeo.org
Tue Oct 30 20:25:23 PDT 2018
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
In [changeset:"16968" 16968]:
#!CommitTicketReference repository="" revision="16968"
Fix sfcgal regress failure - Delete 4326 entry before readding. Also use
integer format instead of string format.
References #4210
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4210#comment:7>
