[postgis-tickets] [PostGIS] #2740: postgis_full_version registering procs need upgrade on windows
trac at osgeo.org
Sun Sep 2 01:08:47 PDT 2018
Reporter: robe | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.4.5
Component: | Version: 2.4.x
build/upgrade/install |
Resolution: | Keywords: Linux 4.18.5, PostgreSQL 10.5
Changes (by andischi):
* status: closed => reopened
* cc: andischi (added)
* version: 2.0.x => 2.4.x
* milestone: PostGIS 2.0.7 => PostGIS 2.4.5
* keywords: windows,mingw64 => Linux 4.18.5, PostgreSQL 10.5
* resolution: wontfix =>
Comment:
# select version();
PostgreSQL 10.5 on x86_64-pc-linux-gnu, compiled by gcc (GCC) 8.2.0,
64-bit
# select postgis_full_version();
postgis_full_version | POSTGIS="2.4.4 r16526" PGSQL="100"
GEOS="3.6.2-CAPI-1.10.2 4d2925d6" PROJ="Rel. 5.1.0, June 1st, 2018"
GDAL="GDAL 2.3.1, released 2018/06/22" LIBXML="2.9.8" LIBJSON="0.13.1"
LIBPROTOBUF="1.3.0" (core procs from "2.4.3 r16312" need upgrade) TOPOLOGY
(topology procs from "2.4.3 r16312" need upgrade) RASTER (raster procs
# select postgis_scripts_installed(), postgis_scripts_released();
postgis_scripts_installed | postgis_scripts_released
2.4.3 r16312 | 2.4.4 r16526
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2740#comment:8>
