[postgis-tickets] [PostGIS] #4175: debbie failures on postgis
PostGIS trac at osgeo.org
Wed Sep 12 12:16:06 PDT 2018
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  closed
  Priority:  blocker    |  Milestone:  PostGIS PostgreSQL
 Component:  buildbots  |    Version:  trunk
Resolution:  fixed      |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 Fixed upstream. (9.3, 9.4, 9.5, 9.6, 10, 11)
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=f7d0343ead29cd3e44eccd1c8b7cc291b79209fe
     Repair bug in regexp split performance improvements. (details)
 Commit f7d0343ead29cd3e44eccd1c8b7cc291b79209fe by rhodiumtoad
 Commit c8ea87e4b introduced a temporary conversion buffer for substrings
 extracted during regexp splits. Unfortunately the code that sized it was
 failing to ignore the effects of ignored degenerate regexp matches, so
 for regexp_split_* calls it could under-size the buffer in such cases.
 Fix, and add some regression test cases (though those will only catch
 the bug if run in a multibyte encoding).
 Backpatch to 9.3 as the faulty code was.
 Thanks to the PostGIS project, Regina Obe and Paul Ramsey for the report
 (via IRC) and assistance in analysis. Patch by me.
 The file was modified   src/test/regress/expected/strings.out
 The file was modified   src/test/regress/sql/strings.sql
 The file was modified   src/backend/utils/adt/regexp.c
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4175#comment:4>
