[postgis-tickets] [PostGIS] #4174: segfault when using spgist
PostGIS trac at osgeo.org
Wed Sep 12 13:15:21 PDT 2018
  Reporter:  TobWen   |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS PostgreSQL
 Component:  postgis  |    Version:  trunk
Resolution:  fixed    |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => fixed
 * milestone:  PostGIS 2.5.0 => PostGIS PostgreSQL
Comment:
 Fixed upstream
 https://git.postgresql.org/gitweb/?p=postgresql.git;a=commit;h=e331d6712f0224160d2699591704ddcc3ef2d67b
 Summary
     Repair double-free in SP-GIST rescan (bug #15378) (details)
 Commit e331d6712f0224160d2699591704ddcc3ef2d67b by rhodiumtoad
 spgrescan would first reset traversalCxt, and then traverse a
 potentially non-empty stack containing pointers to traversalValues which
 had been allocated in those contexts, freeing them a second time. This
 bug originates in commit ccd6eb49a where traversalValue was introduced.
 Repair by traversing the stack before the context reset; this isn't
 ideal, since it means doing retail pfree in a context that's about to be
 reset, but the freeing of a stack entry is also done in other places in
 the code during the scan so it's not worth trying to refactor it
 further. Regression test added.
 Backpatch to 9.6 where the problem was introduced.
 Per bug #15378; analysis and patch by me, originally from a report on
 IRC by user velix; see also PostGIS ticket #4174; review by Alexander
 Korotkov.
 Discussion:
 https://postgr.es/m/153663176628.23136.11901365223750051490@wrigleys.postgresql.org
 The file was modified   src/test/regress/expected/spgist.out
 The file was modified   src/test/regress/sql/spgist.sql
 The file was modified   src/backend/access/spgist/spgscan.c
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4174#comment:2>
