[postgis-tickets] r16807 - Move geofromjson test from tickets to in_geojson so JSON-C guard can be applied.
Regina Obe lr at pcorp.us
Sun Sep 16 12:13:02 PDT 2018
Author: robe
Date: 2018-09-16 00:13:02 -0700 (Sun, 16 Sep 2018)
New Revision: 16807
   trunk/regress/in_geojson.sql
   trunk/regress/in_geojson_expected
   trunk/regress/tickets.sql
   trunk/regress/tickets_expected
Closes #4178 for PostGIS 3.0.0
Modified: trunk/regress/in_geojson.sql
--- trunk/regress/in_geojson.sql	2018-09-16 05:12:51 UTC (rev 16806)
+++ trunk/regress/in_geojson.sql	2018-09-16 07:13:02 UTC (rev 16807)
@@ -49,3 +49,6 @@
 -- #3583
 SELECT '#3583', ST_AsText(ST_GeomFromGeoJSON('{"type":"MultiPolygon", "coordinates":[[[139.10030364990232,35.16777444430609],5842.4224490305424]]}'));
+-- #4164
+SELECT ST_AsText(ST_GeomFromGeoJSON('{"type": "Polygon", "coordinates": [[0,0],[0,5],[5, 5],[5,0],[0,0]]}'));
Modified: trunk/regress/in_geojson_expected
--- trunk/regress/in_geojson_expected	2018-09-16 05:12:51 UTC (rev 16806)
+++ trunk/regress/in_geojson_expected	2018-09-16 07:13:02 UTC (rev 16807)
@@ -30,3 +30,4 @@
 geomfromgeojson_srs_3|GEOMETRYCOLLECTION(POINT(100 0),LINESTRING(101 0,102 1))
 geomfromgeojson_srs_4|GEOMETRYCOLLECTION(POINT(100 0),LINESTRING(101 0,102 1))
 #3583|MULTIPOLYGON Z (EMPTY)
+ERROR:  The 'coordinates' in GeoJSON polygon are not sufficiently nested
Modified: trunk/regress/tickets.sql
--- trunk/regress/tickets.sql	2018-09-16 05:12:51 UTC (rev 16806)
+++ trunk/regress/tickets.sql	2018-09-16 07:13:02 UTC (rev 16807)
@@ -1098,9 +1098,6 @@
     select ST_GeogFromText('SRID=4326;POINT(1.0 2.0)') as a, ST_GeogFromText('SRID=4326;POINT(1.0 1.0)') as b
 ) as points;
--- #4164
-SELECT ST_AsText(ST_GeomFromGeoJSON('{"type": "Polygon", "coordinates": [[0,0],[0,5],[5, 5],[5,0],[0,0]]}'));
 -- #4144
 DROP TABLE IF EXISTS bug_4144_table;
 CREATE TABLE bug_4144_table (
@@ -1107,7 +1104,7 @@
   geom geometry NOT NULL DEFAULT NULL
-INSERT INTO bug_4144_table (geom)
+INSERT INTO bug_4144_table (geom)
   VALUES ('GEOMETRYCOLLECTION(POINT(-3.385894e+38 0 0),POINT(0 0 0))');
 ANALYZE bug_4144_table;
Modified: trunk/regress/tickets_expected
--- trunk/regress/tickets_expected	2018-09-16 05:12:51 UTC (rev 16806)
+++ trunk/regress/tickets_expected	2018-09-16 07:13:02 UTC (rev 16807)
@@ -335,6 +335,5 @@
 #4089|LINESTRING Z (1 1 1,3 3 1)
 ERROR:  lwgeom_pointonsurface: GEOS Error: TopologyException: Input geom 1 is invalid: Self-intersection
 #4081|f|t
-ERROR:  The 'coordinates' in GeoJSON polygon are not sufficiently nested
 NOTICE:  table "bug_4144_table" does not exist, skipping
 #4176|t
