[postgis-tickets] r16817 - Replace long tag with short-tag for xref ST_MemSize. Was causing problems with po conversion
Regina Obe lr at pcorp.us
Sun Sep 16 05:03:36 PDT 2018
Author: robe
Date: 2018-09-16 17:03:36 -0700 (Sun, 16 Sep 2018)
New Revision: 16817
   trunk/ci/debbie/postgis_release_docs.sh
   trunk/doc/po/templates/reference_editor.xml.pot
   trunk/doc/reference_editor.xml
Revise to build html of languages with high completion % as part of general doc building
Modified: trunk/ci/debbie/postgis_release_docs.sh
--- trunk/ci/debbie/postgis_release_docs.sh	2018-09-16 23:58:35 UTC (rev 16816)
+++ trunk/ci/debbie/postgis_release_docs.sh	2018-09-17 00:03:36 UTC (rev 16817)
@@ -71,12 +71,13 @@
 make -e chunked-html 2>&1 | tee -a doc-errors.log
 if [[ "$reference" == *"trunk"* ]]; then  #only do this for trunk because only trunk follows transifex
-  #make update-po
-  #make -C po/it_IT/ local-html
+  make update-pot
+  make pull-tx
+  make -C po/it_IT/ local-html
   make -C po/pt_BR/ local-html
-  #make -C po/ja/ local-html
+  make -C po/ja/ local-html
   make -C po/de/ local-html
-  #make -C po/ko_KR/ local-html
+  make -C po/ko_KR/ local-html
   #make pdf-localized
 fi
Modified: trunk/doc/po/templates/reference_editor.xml.pot
--- trunk/doc/po/templates/reference_editor.xml.pot	2018-09-16 23:58:35 UTC (rev 16816)
+++ trunk/doc/po/templates/reference_editor.xml.pot	2018-09-17 00:03:36 UTC (rev 16817)
@@ -6,7 +6,7 @@
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: http://bugs.kde.org\n"
-"POT-Creation-Date: 2018-09-16 19:07+0000\n"
+"POT-Creation-Date: 2018-09-16 20:04+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
Modified: trunk/doc/reference_editor.xml
--- trunk/doc/reference_editor.xml	2018-09-16 23:58:35 UTC (rev 16816)
+++ trunk/doc/reference_editor.xml	2018-09-17 00:03:36 UTC (rev 16817)
@@ -1179,7 +1179,7 @@
 			<note>
 				<para>
 					Only the on-disk size of the geometry is potentially affected by
-					<code>ST_QuantizeCoordinates</code>.  <xref linkend="ST_MemSize"></xref>,
+					<code>ST_QuantizeCoordinates</code>.  <xref linkend="ST_MemSize" />,
 					which reports the in-memory usage of the geometry, will return the
 					the same value regardless of the disk space used by a geometry.
 				</para>
