[postgis-tickets] [PostGIS] #4156: ST_ChaikinSmoothing not treating inner and outer rings the same
PostGIS trac at osgeo.org
Wed Sep 19 21:41:13 PDT 2018
  Reporter:  komzpa   |      Owner:  nicklas
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.0.0
 Component:  postgis  |    Version:  trunk
Resolution:           |   Keywords:
Comment (by nicklas):
 Yes, that is valid points.
 But I think it is different what different people find as surprise?
 I agree that this default behavior not is very useful for polygons. The
 networks I mentioned is linestrings.
 The reason for this behavior anyway is that I wanted the same default
 behavior for all geometry types. I thought that would give less surprises.
 This is also the behavior for ST_Simplify and ST_SimplifyVW, which I think
 people might relate this function to.
 select st_simplify(geom, 2) geom from
   select 'polygon((10 10, 11 15, 15 15, 16 10, 15 5, 11 5, 10
 10))'::geometry geom
 )a
 I don't have any strong personal feelings about this, so if people wants
 this changed I have no problem with that.
 But now it is also too late for 2.5 so it will be a breaking change in
 PostGIS 3.0 which is a good place to put breaking changes of course).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4156#comment:8>
