[postgis-tickets] r16835 - Stamp date of release.
Regina Obe
lr at pcorp.us
Sun Sep 23 01:04:42 PDT 2018
Author: robe
Date: 2018-09-23 13:04:42 -0700 (Sun, 23 Sep 2018)
New Revision: 16835
branches/2.5/NEWS
branches/2.5/doc/release_notes.xml
branches/2.5/raster/rt_pg/rtpg_inout.c
Put in legacy stub function for RASTER_to_binary to allow pg upgrade (newer lib)
Closes #4097
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS 2018-09-23 15:03:09 UTC (rev 16834)
+++ branches/2.5/NEWS 2018-09-23 20:04:42 UTC (rev 16835)
@@ -1,5 +1,5 @@
PostGIS 2.5.0
-2018/09/XX
+2018/09/23
WARNING: If compiling with PostgreSQL+JIT, LLVM >= 6 is required
Supported PostgreSQL versions for this release are:
PostgreSQL 9.4 - PostgreSQL 12 (in development)
Modified: branches/2.5/doc/release_notes.xml
--- branches/2.5/doc/release_notes.xml 2018-09-23 15:03:09 UTC (rev 16834)
+++ branches/2.5/doc/release_notes.xml 2018-09-23 20:04:42 UTC (rev 16835)
@@ -4,7 +4,7 @@
<subtitle>Release Notes</subtitle>
<sect1>
<title>Release 2.5.0</title>
- <para>Release date: 2018/09/xx</para>
+ <para>Release date: 2018/09/23</para>
<para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
<para>Supported PostgreSQL versions for this release are:
Modified: branches/2.5/raster/rt_pg/rtpg_inout.c
--- branches/2.5/raster/rt_pg/rtpg_inout.c 2018-09-23 15:03:09 UTC (rev 16834)
+++ branches/2.5/raster/rt_pg/rtpg_inout.c 2018-09-23 20:04:42 UTC (rev 16835)
@@ -37,9 +37,24 @@
Datum RASTER_to_bytea(PG_FUNCTION_ARGS);
+/** obsolete as of 2.5.0 stubbing for smoother upgrade from 2.4 **/
+Datum RASTER_to_binary(PG_FUNCTION_ARGS);
Datum RASTER_noop(PG_FUNCTION_ARGS);
+ * Legacy return error if called
+ * Removed in PostGIS 2.5.0
+PG_FUNCTION_INFO_V1(RASTER_to_binary);
+ elog(ERROR, "RASTER_to_binary: This function is out of date. Run ALTER EXTENSION postgis UPDATE; to fix");
* Input is Hex WKB
* Used as the input function of the raster type
