[postgis-tickets] r16840 - [run_test] Drop raster if needed when enforced by extension
Sandro Santilli
strk at kbt.io
Mon Sep 24 03:18:15 PDT 2018
Author: strk
Date: 2018-09-24 03:18:15 -0700 (Mon, 24 Sep 2018)
New Revision: 16840
trunk/regress/run_test.pl
Modified: trunk/regress/run_test.pl
--- trunk/regress/run_test.pl 2018-09-24 10:06:13 UTC (rev 16839)
+++ trunk/regress/run_test.pl 2018-09-24 10:18:15 UTC (rev 16840)
@@ -1509,7 +1509,31 @@
+ else
+ # Raster support was not requested, so drop it if
+ # left unpackaged
+ if ( $OPT_UPGRADE_FROM
+ && ! has_split_raster_ext($OPT_UPGRADE_FROM) )
+ $sql = "CREATE EXTENSION postgis_raster VERSION '${nextver}' FROM unpackaged";
+ $cmd = "psql $psql_opts -c \"" . $sql . "\" $DB >> $REGRESS_LOG 2>&1";
+ $rv = system($cmd);
+ if ( $rv ) {
+ fail "Error encountered creating EXTENSION POSTGIS_RASTER from unpackaged on upgrade", $REGRESS_LOG;
+ die;
+ $sql = "DROP EXTENSION postgis_raster";
+ if ( $rv ) {
+ fail "Error encountered dropping EXTENSION POSTGIS_RASTER on upgrade", $REGRESS_LOG;
+ die;
if ( $OPT_WITH_TOPO )
my $sql = "ALTER EXTENSION postgis_topology UPDATE TO '${nextver}'";
