[postgis-tickets] r17659 - Harmonize calls so tests return same results on multiple Pg versions
Paul Ramsey
pramsey at cleverelephant.ca
Thu Aug 1 01:31:12 PDT 2019
Author: pramsey
Date: 2019-08-01 13:31:12 -0700 (Thu, 01 Aug 2019)
New Revision: 17659
trunk/regress/core/estimatedextent.sql
trunk/regress/core/estimatedextent_expected
References #4464
Modified: trunk/regress/core/estimatedextent.sql
--- trunk/regress/core/estimatedextent.sql 2019-08-01 20:15:14 UTC (rev 17658)
+++ trunk/regress/core/estimatedextent.sql 2019-08-01 20:31:12 UTC (rev 17659)
@@ -9,17 +9,17 @@
-- #877.3
select '#877.3', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
round(st_ymin(e.e)::numeric, 5), round(st_ymax(e.e)::numeric, 5)
-from ( select ST_EstimatedExtent('t','g') as e ) AS e;
+from ( select ST_EstimatedExtent('t','g') as e offset 0 ) AS e;
-- #877.4
analyze t;
select '#877.4', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
-- #877.5
truncate t;
-with e as ( select ST_EstimatedExtent('t','g') as e )
+with e as ( select ST_EstimatedExtent('t','g') as e offset 0 )
select '#877.5', round(st_xmin(e.e)::numeric, 5), round(st_xmax(e.e)::numeric, 5),
round(st_ymin(e.e)::numeric, 5), round(st_ymax(e.e)::numeric, 5) from e;
drop table t;
@@ -38,17 +38,17 @@
-- #3391.1
select '#3391.1', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
round(st_ymin(e.e)::numeric, 2), round(st_ymax(e.e)::numeric, 2)
-from ( select ST_EstimatedExtent('c1','g') as e ) AS e;
+from ( select ST_EstimatedExtent('c1','g') as e offset 0 ) AS e;
-- #3391.2
select '#3391.2', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('c2','g') as e ) AS e;
+from ( select ST_EstimatedExtent('c2','g') as e offset 0 ) AS e;
-- #3391.3
select '#3391.3', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('p','g') as e ) AS e;
+from ( select ST_EstimatedExtent('p','g') as e offset 0 ) AS e;
insert into c1 values ('Point(0 0)'::geometry);
insert into c1 values ('Point(1 1)'::geometry);
@@ -60,17 +60,17 @@
-- #3391.4
select '#3391.4', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.5
select '#3391.5', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.6
select '#3391.6', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
insert into c2 values ('Point(0 0)'::geometry);
insert into c2 values ('Point(-1 -1)'::geometry);
@@ -82,17 +82,17 @@
-- #3391.7
select '#3391.7', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.8
select '#3391.8', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.9
select '#3391.9', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
insert into p values ('Point(1 1)'::geometry);
insert into p values ('Point(2 2)'::geometry);
@@ -104,17 +104,17 @@
-- #3391.10
select '#3391.10', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.11
select '#3391.11', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.12
select '#3391.12', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- test calls with 3th parameter
@@ -133,22 +133,22 @@
-- #3391.13
select '#3391.13', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','p','g','t') as e ) AS e;
+from ( select ST_EstimatedExtent('public','p','g','t') as e offset 0 ) AS e;
-- #3391.14
select '#3391.14', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','p','g','f') as e ) AS e;
+from ( select ST_EstimatedExtent('public','p','g','f') as e offset 0 ) AS e;
-- #3391.15
select '#3391.15', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from (select ST_EstimatedExtent('public','c1','g', 't') as e ) AS e;
+from (select ST_EstimatedExtent('public','c1','g', 't') as e offset 0 ) AS e;
-- #3391.16
select '#3391.16', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','c1','g', 'f') as e ) AS e;
+from ( select ST_EstimatedExtent('public','c1','g', 'f') as e offset 0 ) AS e;
@@ -160,22 +160,22 @@
-- #3391.17
select '#3391.17', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','p','g','f') as e) AS e;
-- #3391.18
select '#3391.18', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','p','g','t') as e )AS e;
+from ( select ST_EstimatedExtent('public','p','g','t') as e offset 0 )AS e;
-- #3391.19
select '#3391.19', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-- #3391.20
select '#3391.20', round(st_xmin(e.e)::numeric, 2), round(st_xmax(e.e)::numeric, 2),
-from ( select ST_EstimatedExtent('public','c1','g', 't') as e ) AS e;
+from ( select ST_EstimatedExtent('public','c1','g', 't') as e offset 0 ) AS e;
drop table p cascade;
Modified: trunk/regress/core/estimatedextent_expected
--- trunk/regress/core/estimatedextent_expected 2019-08-01 20:15:14 UTC (rev 17658)
+++ trunk/regress/core/estimatedextent_expected 2019-08-01 20:31:12 UTC (rev 17659)
@@ -3,32 +3,17 @@
WARNING: stats for "t.g" do not exist
#877.2|
-WARNING: stats for "t.g" do not exist
#877.3||||
#877.4|-10.15000|20.15000|-50.40000|30.40000
#877.5|-10.15000|20.15000|-50.40000|30.40000
WARNING: stats for "c1.g" do not exist
-WARNING: stats for "c1.g" do not exist
#3391.1||||
WARNING: stats for "c2.g" do not exist
-WARNING: stats for "c2.g" do not exist
#3391.2||||
WARNING: stats for "p.g" do not exist
-WARNING: stats for "p.g" do not exist
#3391.3||||
#3391.4|0.00|1.00|0.00|1.00
#3391.5||||
#3391.6|0.00|1.00|0.00|1.00
#3391.7|0.00|1.00|0.00|1.00
@@ -38,30 +23,15 @@
#3391.11|-1.00|0.00|-1.00|0.00
#3391.12|-1.01|2.02|-1.01|2.02
#3391.13||||
#3391.14||||
#3391.15||||
#3391.16||||
#3391.17|0.00|1.00|0.00|1.00
#3391.18||||
#3391.19|0.00|1.00|0.00|1.00
#3391.20|0.00|1.00|0.00|1.00
