[postgis-tickets] r17667 - ST_Subdivide crash on intermediate EMPTY fix.
Darafei
komzpa at gmail.com
Sun Aug 4 12:08:37 PDT 2019
Author: komzpa
Date: 2019-08-04 00:08:37 -0700 (Sun, 04 Aug 2019)
New Revision: 17667
trunk/NEWS
trunk/liblwgeom/lwgeom.c
Closes #4459
Closes https://github.com/postgis/postgis/pull/456
Modified: trunk/NEWS
--- trunk/NEWS 2019-08-03 21:48:49 UTC (rev 17666)
+++ trunk/NEWS 2019-08-04 07:08:37 UTC (rev 17667)
@@ -193,7 +193,6 @@
- #4394, Allow FULL OUTER JOIN on geometry equality operator (Darafei Praliaskouski)
- #4441, Make GiST penalty friendly to multi-column indexes and build single-column
ones faster. (Darafei Praliaskouski)
- #4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
* Fixes *
@@ -220,6 +219,7 @@
- #4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
- #4327, Avoid pfree'ing the result of getenv (Raúl Marín)
- #4406, Throw on invalid characters when decoding geohash (Raúl Marín)
+ - #4459, Fix ST_Subdivide crash on intermediate EMPTY (Darafei Praliaskouski)
PostGIS 2.5.0
2018/09/23
Modified: trunk/liblwgeom/lwgeom.c
--- trunk/liblwgeom/lwgeom.c 2019-08-03 21:48:49 UTC (rev 17666)
+++ trunk/liblwgeom/lwgeom.c 2019-08-04 07:08:37 UTC (rev 17667)
@@ -2219,20 +2219,19 @@
LWCOLLECTION *col)
const uint32_t maxdepth = 50;
- GBOX clip, subbox1, subbox2;
- uint32_t nvertices = 0;
- uint32_t i;
- uint32_t split_ordinate;
- double width;
- double height;
- double pivot = DBL_MAX;
- double center = DBL_MAX;
- LWPOLY *lwpoly = NULL;
- gbox_duplicate(lwgeom_get_bbox(geom), &clip);
- width = clip.xmax - clip.xmin;
- height = clip.ymax - clip.ymin;
+ if (!geom)
+ return;
+ const GBOX *box_in = lwgeom_get_bbox(geom);
+ if (!box_in)
+ return;
+ GBOX clip;
+ gbox_duplicate(box_in, &clip);
+ double width = clip.xmax - clip.xmin;
+ double height = clip.ymax - clip.ymin;
if ( geom->type == POLYHEDRALSURFACETYPE || geom->type == TINTYPE )
lwerror("%s: unsupported geometry type '%s'", __func__, lwtype_name(geom->type));
@@ -2262,7 +2261,7 @@
LWCOLLECTION *incol = (LWCOLLECTION*)geom;
/* Don't increment depth yet, since we aren't actually
* subdividing geometries yet */
- for ( i = 0; i < incol->ngeoms; i++ )
+ for (uint32_t i = 0; i < incol->ngeoms; i++ )
lwgeom_subdivide_recursive(incol->geoms[i], dimension, maxvertices, depth, col);
return;
@@ -2282,7 +2281,7 @@
return;
- nvertices = lwgeom_count_vertices(geom);
+ uint32_t nvertices = lwgeom_count_vertices(geom);
/* Skip empties entirely */
if (nvertices == 0)
@@ -2295,12 +2294,9 @@
return;
- split_ordinate = (width > height) ? 0 : 1;
- if (split_ordinate == 0)
- center = (clip.xmin + clip.xmax) / 2;
- else
- center = (clip.ymin + clip.ymax) / 2;
+ uint8_t split_ordinate = (width > height) ? 0 : 1;
+ double center = (split_ordinate == 0) ? (clip.xmin + clip.xmax) / 2 : (clip.ymin + clip.ymax) / 2;
+ double pivot = DBL_MAX;
if (geom->type == POLYGONTYPE)
uint32_t ring_to_trim = 0;
@@ -2308,14 +2304,13 @@
double pivot_eps = DBL_MAX;
double pt_eps = DBL_MAX;
POINTARRAY *pa;
- pivot = DBL_MAX;
- lwpoly = (LWPOLY *)geom;
+ LWPOLY *lwpoly = (LWPOLY *)geom;
/* if there are more points in holes than in outer ring */
if (nvertices >= 2 * lwpoly->rings[0]->npoints)
/* trim holes starting from biggest */
- for (i = 1; i < lwpoly->nrings; i++)
+ for (uint32_t i = 1; i < lwpoly->nrings; i++)
double current_ring_area = fabs(ptarray_signed_area(lwpoly->rings[i]));
if (current_ring_area >= ring_area)
@@ -2329,7 +2324,7 @@
pa = lwpoly->rings[ring_to_trim];
/* find most central point in chosen ring */
- for (i = 0; i < pa->npoints; i++)
+ for (uint32_t i = 0; i < pa->npoints; i++)
double pt;
@@ -2344,11 +2339,12 @@
+ GBOX subbox1, subbox2;
gbox_duplicate(&clip, &subbox1);
gbox_duplicate(&clip, &subbox2);
- if (pivot == DBL_MAX) pivot = center;
+ if (pivot == DBL_MAX)
+ pivot = center;
