[postgis-tickets] r17675 - [doc] Note about mulitlinestring in ST_OffsetCurve
Darafei
komzpa at gmail.com
Sun Aug 4 04:52:29 PDT 2019
Author: komzpa
Date: 2019-08-04 04:52:29 -0700 (Sun, 04 Aug 2019)
New Revision: 17675
trunk/doc/reference_processing.xml
Closes #2553
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2019-08-04 11:43:42 UTC (rev 17674)
+++ trunk/doc/reference_processing.xml 2019-08-04 11:52:29 UTC (rev 17675)
@@ -2261,6 +2261,9 @@
and retain the same direction. For a negative distance it'll be at the right
side and in the opposite direction.
</para>
+ <para>
+Note that output may be a MULTILINESTRING or EMPTY for some jigsaw-shaped input geometries.
+ </para>
<para>Performed by the GEOS module.</para>
<para>Availability: 2.0</para>
