[postgis-tickets] [PostGIS] #4472: ST_AsMVT is being tested even on system without proto-buf installed
PostGIS trac at osgeo.org
Wed Aug 7 05:20:10 PDT 2019
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.0.0
Component:  postgis  |    Version:  trunk
 Keywords:           |
 berrie is failing.  She doesn't have protobuf installed and evidentally
 someones snuck somes tests in tickets that require protobuf
 -#4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
 08:17:24
 08:17:24 -#4399|ST_AsMVTGeom|
 08:17:24
 -#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}
 08:17:24
 -#4399|ST_AsGeoJSON|{"type":"GeometryCollection","geometries":[{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}]}
 08:17:24 -#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[]]}
 08:17:24 +ERROR:  ST_AsGeobuf: Missing libprotobuf-c >= version 1.1
 08:17:24
 08:17:15  tickets .. failed (diff expected obtained:
 /tmp/pgis_reg/test_102_diff)
 08:17:24
 08:17:24 --- tickets_expected   2019-08-07 05:02:54.592281192 -0700
 08:17:24 +++ /tmp/pgis_reg/test_102_out 2019-08-07 05:17:24.047138766
 -0700
 08:17:24 @@ -391,40 +391,4 @@
 08:17:24  #4176|t
 08:17:24  #4394
 08:17:24  #4445|f|t|t|t|f|t|t|f|f|f|f|f|f|t|t
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4472>
