[postgis-tickets] r17680 - Try to get berrie to return fail code if	regress fails - try 2
    Regina Obe
    lr at pcorp.us
    Fri Aug  9 03:21:13 PDT 2019
Author: robe
Date: 2019-08-09 15:21:12 -0700 (Fri, 09 Aug 2019)
New Revision: 17680
   trunk/ci/berrie/postgis_regress.sh
Modified: trunk/ci/berrie/postgis_regress.sh
--- trunk/ci/berrie/postgis_regress.sh	2019-08-09 21:55:25 UTC (rev 17679)
+++ trunk/ci/berrie/postgis_regress.sh	2019-08-09 22:21:12 UTC (rev 17680)
@@ -21,12 +21,13 @@
 ./configure --with-pgconfig=${PGPATH}/bin/pg_config
 #make clean
 make
-export err=0
+export err_status=0
 make check RUNTESTFLAGS="-v"
 make install
-make check RUNTESTFLAGS="-v --extension" || $err=1
+make check RUNTESTFLAGS="-v --extension"
+err_status=$?
 if [ -d $PGDATA/postmaster.pid ] ; then
 	$PGCTL stop -D $PGDATA -s -m fast
 fi
-exit $err
\ No newline at end of file
+exit $err_status
