[postgis-tickets] [PostGIS] #4474: bessie32 failing
PostGIS trac at osgeo.org
Fri Aug 9 15:44:59 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.0.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Comment (by robe):
 In [changeset:"17681" 17681]:
 #!CommitTicketReference repository="" revision="17681"
 Try to fix bessie32 Undefined symbol
 "_ZNKSt8__detail20_Prime_rehash_policy11_M_next_bktEj" by getting rid of
 redundant configure lines that should be pulled in via pkg-config
 References #4474 for PostGIS 3.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:1>
