[postgis-tickets] r17682 - Move protobuf specific ticket lines to mvt test
Regina Obe
lr at pcorp.us
Fri Aug 9 03:50:19 PDT 2019
Author: robe
Date: 2019-08-09 15:50:19 -0700 (Fri, 09 Aug 2019)
New Revision: 17682
trunk/NEWS
trunk/regress/core/mvt.sql
trunk/regress/core/mvt_expected
trunk/regress/core/tickets.sql
trunk/regress/core/tickets_expected
Closes #4472
Modified: trunk/NEWS
--- trunk/NEWS 2019-08-09 22:44:58 UTC (rev 17681)
+++ trunk/NEWS 2019-08-09 22:50:19 UTC (rev 17682)
@@ -1,5 +1,5 @@
PostGIS 3.0.0alpha4
-2019/xx/xx
+2019/08/xx
For full changes and enhancements, refer to PostGIS 3.0.0.
This version requires PostgreSQL 9.5+-12 and GEOS >= 3.6+
Additional features enabled if you are running Proj6+ and PostgreSQL 12
Modified: trunk/regress/core/mvt.sql
--- trunk/regress/core/mvt.sql 2019-08-09 22:44:58 UTC (rev 17681)
+++ trunk/regress/core/mvt.sql 2019-08-09 22:50:19 UTC (rev 17682)
@@ -725,3 +725,14 @@
16,
true
)), 0) BETWEEN 0 AND 100;
+WITH geom AS (
+ SELECT 'TRIANGLE((0 0, 1 1, 0 1, 0 0))'::geometry geom
+ union all
+ SELECT 'TIN(((0 0, 1 1, 0 1, 0 0)))'::geometry geom
+ union all
+ SELECT 'TRIANGLE EMPTY'::geometry geom
+select '#4399', 'ST_AsGeobuf', ST_AsGeobuf(geom.*)::text from geom
+union all
+select '#4399', 'ST_AsMVTGeom', ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32)))::text from geom;
Modified: trunk/regress/core/mvt_expected
--- trunk/regress/core/mvt_expected 2019-08-09 22:44:58 UTC (rev 17681)
+++ trunk/regress/core/mvt_expected 2019-08-09 22:50:19 UTC (rev 17682)
@@ -142,3 +142,7 @@
#4348Reversed2|t
#4348Point|t
#4348Crash|t
+#4399|ST_AsGeobuf|\x180022260a0c0a0a08041a060000020201000a100a0e0806220a08041a060000020201000a040a020804
+#4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
Modified: trunk/regress/core/tickets.sql
--- trunk/regress/core/tickets.sql 2019-08-09 22:44:58 UTC (rev 17681)
+++ trunk/regress/core/tickets.sql 2019-08-09 22:50:19 UTC (rev 17682)
@@ -1283,9 +1283,4 @@
union all
select '#4399', 'ST_GeoHash', ST_GeoHash(geom)::text from geom
union all
-select '#4399', 'ST_AsGeobuf', ST_AsGeobuf(geom.*)::text from geom
-union all
-select '#4399', 'ST_AsMVTGeom', ST_AsMVTGeom(geom, ST_MakeBox2D(ST_Point(0, 0), ST_Point(32, 32)))::text from geom
-union all
select '#4399', 'ST_AsGeoJSON', ST_AsGeoJSON(geom)::text from geom;
Modified: trunk/regress/core/tickets_expected
--- trunk/regress/core/tickets_expected 2019-08-09 22:44:58 UTC (rev 17681)
+++ trunk/regress/core/tickets_expected 2019-08-09 22:50:19 UTC (rev 17682)
@@ -421,10 +421,6 @@
#4399|ST_GeoHash|
#4399|ST_GeoHash|
#4399|ST_GeoHash|
-#4399|ST_AsGeobuf|\x180022260a0c0a0a08041a060000020201000a100a0e0806220a08041a060000020201000a040a020804
-#4399|ST_AsMVTGeom|011100000001000000040000000000000000000000000000000000B0400000000000000000000000000000AF400000000000006040000000000000AF400000000000000000000000000000B040
#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}
#4399|ST_AsGeoJSON|{"type":"GeometryCollection","geometries":[{"type":"Polygon","coordinates":[[[0,0],[1,1],[0,1],[0,0]]]}]}
#4399|ST_AsGeoJSON|{"type":"Polygon","coordinates":[[]]}
