[postgis-tickets] [PostGIS] #4385: [raster2pgsql] -I option recreates index for each insertion
PostGIS trac at osgeo.org
Fri Aug 9 17:19:02 PDT 2019
  Reporter:  RaphJ        |      Owner:  Bborie Park
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 2.5.4
 Component:  raster       |    Version:  2.4.x
Resolution:               |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 2.5.3 => PostGIS 2.5.4
Comment:
 By insertion I presume you mean each append run.  Not for each individual
 tile?
 I haven't looked at this closely.  It should in theory fail if there is
 already an index on the table.  But it's also possible you do several
 append calls and then on your final commandline call you want to create
 the index on the table.  So seems perfectly legit to allow -I and a
 together.
 Anyway I'll push this to later once I've had time to test out all the
 scenarios
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4385#comment:1>
