[postgis-tickets] [PostGIS] #4475: in_geojson regress failure on travis
trac at osgeo.org
Sat Aug 10 19:27:05 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.4.8
Component: postgis | Version: 2.5.x
Keywords: |
This is for both 2.4 and 2.5 --
in_geojson .. failed (diff expected obtained: /tmp/pgis_reg/test_119_diff)
--- in_geojson_expected 2019-08-10 20:02:55.169398790 +0000
+++ /tmp/pgis_reg/test_119_out 2019-08-10 20:11:37.647269750 +0000
@@ -31,7 +31,7 @@
geomfromgeojson_srs_4|GEOMETRYCOLLECTION(POINT(100 0),LINESTRING(101
0,102 1))
#3583|MULTIPOLYGON Z (EMPTY)
ERROR: The 'coordinates' in GeoJSON polygon are not sufficiently nested
-#4470.a|POLYGON((0 0),())
+ERROR: ptarray.c [1767] called outside of ptarray range (n=0,
pa.npoints=0, pa.maxpoints=0)
-#4470.c|MULTIPOLYGON(((0 0),()))
#4470.d|MULTIPOLYGON Z (EMPTY)
It is happening on:
CFLAGS="-g -O0 --coverage -fprofile-arcs -ftest-coverage" LDFLAGS="--
coverage -fprofile-arcs -ftest-coverage" CONFIGURE_FLAGS="--enable-debug"
and
I don't know what flags these are -- this one just says
-------------- Dependencies --------------
GEOS config: /usr/bin/geos-config
GEOS version: 3.5.1
GDAL config: /usr/bin/gdal-config
GDAL version: 2.2.2
SFCGAL config: /usr/bin/sfcgal-config
SFCGAL version: 1.2.2
PostgreSQL config: /usr/lib/postgresql/9.6/bin/pg_config
PostgreSQL version: PostgreSQL 9.6.15
PROJ4 version: 49
Libxml2 config: /usr/bin/xml2-config
Libxml2 version: 2.9.3
JSON-C support: yes
protobuf-c support: yes
protobuf-c version: 1.2.1
PCRE support: yes
Perl: /usr/bin/perl
This seems to have been introduced at #4470
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4475>
