[postgis-tickets] r17687 - Add upgrade install paths for address_standardizer
Regina Obe
lr at pcorp.us
Sat Aug 10 07:36:53 PDT 2019
Author: robe
Date: 2019-08-10 19:36:53 -0700 (Sat, 10 Aug 2019)
New Revision: 17687
trunk/NEWS
trunk/doc/release_notes.xml
trunk/extensions/address_standardizer/Makefile.in
Closese #4420 for PostGIS 3.0 (trunk)
Modified: trunk/NEWS
--- trunk/NEWS 2019-08-11 01:44:24 UTC (rev 17686)
+++ trunk/NEWS 2019-08-11 02:36:53 UTC (rev 17687)
@@ -21,6 +21,7 @@
- #4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)
- #4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)
- #4456, add Rasbery Pi 32-bit jenkins bot for testing (Bruce Rindahl,Regina Obe)
+ - #4420, update path does not exists for address_standardizer extension (Regina Obe)
PostGIS 3.0.0alpha3
2019/07/01
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml 2019-08-11 01:44:24 UTC (rev 17686)
+++ trunk/doc/release_notes.xml 2019-08-11 02:36:53 UTC (rev 17687)
@@ -27,6 +27,7 @@
<para>4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)</para>
<para>4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)</para>
<para>4456, add Rasbery Pi 32-bit jenkins bot for testing (Bruce Rindahl,Regina Obe)</para>
+ <para>4420, update path does not exists for address_standardizer extension (Regina Obe)</para>
</simplesect>
</sect1>
Modified: trunk/extensions/address_standardizer/Makefile.in
--- trunk/extensions/address_standardizer/Makefile.in 2019-08-11 01:44:24 UTC (rev 17686)
+++ trunk/extensions/address_standardizer/Makefile.in 2019-08-11 02:36:53 UTC (rev 17687)
@@ -1,3 +1,4 @@
+include ../upgradeable_versions.mk
OBJS = \
address_parser.o \
address_standardizer.o \
@@ -44,7 +45,7 @@
$(EXTENSION)_data_us.control \
$(NULL)
-all: sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/address_standardizer--$(EXTVERSION).sql sql/address_standardizer--$(EXTVERSION)--$(EXTVERSION)next.sql sql/address_standardizer--$(EXTVERSION)next--$(EXTVERSION).sql \
+all: sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).sql sql/$(EXTENSION)--$(EXTVERSION).sql sql/$(EXTENSION)--ANY--$(EXTVERSION).sql \
sql/$(EXTENSION)_data_us.sql sql/address_standardizer-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us-- at POSTGIS_LIB_VERSION@.sql sql/$(EXTENSION)_data_us--$(EXTVERSION)--$(EXTVERSION)next.sql \
sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql \
sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
@@ -87,10 +88,7 @@
mkdir -p sql
cat $^ > $@
-# upgrade logic for us data extension (to go to next cludge for dev upgrading)
-sql/$(EXTENSION)--$(EXTVERSION)--$(EXTVERSION)next.sql: sql/address_standardizer_functions.sql
- mkdir -p sql
- cat $^ > $@
+EXTENSION_UPGRADE_SCRIPTS = sql/address_standardizer_functions.sql
# upgrade logic for us data extension (to go to original round-robin yoyo cludge for dev upgrading)
sql/$(EXTENSION)--$(EXTVERSION)next--$(EXTVERSION).sql: sql/address_standardizer_functions.sql
@@ -116,6 +114,12 @@
mkdir -p sql
cat $^ > $@
+sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: $(EXTENSION_UPGRADE_SCRIPTS)
+ cat $(EXTENSION_UPGRADE_SCRIPTS) > $@
+include ../upgrade-paths-rules.mk
mk-st-regexp: mk-st-regexp.pl
$(PERL) -c mk-st-regexp.pl
rm -f mk-st-regexp
