[postgis-tickets] [PostGIS] #4460: Problems migrating Postgis 2.1 to 2.4
PostGIS trac at osgeo.org
Sat Aug 10 20:36:49 PDT 2019
  Reporter:  davidperez  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  high        |  Milestone:  PostGIS 2.4.8
 Component:  postgis     |    Version:  2.4.x
Resolution:  wontfix     |   Keywords:
Changes (by robe):
 * status:  new => closed
 * resolution:   => wontfix
Comment:
 The warning about postgis.backend is harmless -it happens because both
 postgis-2.1 and postgis-2.4.so are live at same time and conflicting.  It
 can be ignored.
 My suggestion is not try to compile 2.4 for PostgreSQL 9.3.
 I've done a similar migration on CentOS going from 9.3 2.1 -> 11 2.5 and
 9.2->9.6
 Details of my steps here:
 https://www.bostongis.com/blog/index.php?/archives/273-Using-pg_upgrade-
 to-upgrade-PostgreSQL-9.3-PostGIS-2.1-to-PostgreSQL-11-2.5-on-Yum.html
 The basic idea is you
 1) Install the new cluster PostgreSQL 11 with new PostGIS 2.5
 2) you symlink the postgis-2.5 -> postgis-2.1 in new cluster
 3) Since you are running 2.1, you need to first drop the functions in your
 old cluster since the backing functions were removed in 2.2
 ALTER EXTENSION postgis DROP FUNCTION GeomFromEWKB(bytea);
 ALTER EXTENSION postgis DROP FUNCTION ST_GeomFromEWKB(bytea);
 4) Do your pg_upgrade as usual
 5) Then on new cluster after pg_upgrade do the
 ALTER EXTENSION postgis UPDATE;
 The reason why installing the newer PostGIS in your old cluster and then
 pg_upgrading didn't work is because brin was introduced in 9.4, and the
 2.5 you installed therefore lackaged those when installed in 9.3 and since
 you were already at 2.5 by the time you pg upgraded, it didn't do
 anything.
 Anyway I think we had fixed this issue already in 2.5 and we can't really
 backport it to 2.4 because as I recall it was a bit involved.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4460#comment:2>
