[postgis-tickets] r17691 - Prepare for release of PostGIS 2.3.10
Regina Obe
lr at pcorp.us
Sat Aug 10 09:00:37 PDT 2019
Author: robe
Date: 2019-08-10 21:00:37 -0700 (Sat, 10 Aug 2019)
New Revision: 17691
branches/2.3/ChangeLog
branches/2.3/NEWS
branches/2.3/Version.config
branches/2.3/doc/release_notes.xml
Modified: branches/2.3/ChangeLog
--- branches/2.3/ChangeLog 2019-08-11 03:56:02 UTC (rev 17690)
+++ branches/2.3/ChangeLog 2019-08-11 04:00:37 UTC (rev 17691)
@@ -1,24 +1,165 @@
+2019-08-11 03:03 Regina Obe <lr at pcorp.us>
+ * [r17689] .travis.yml: Fix compile error on travis
+ Closes https://github.com/postgis/postgis/pull/459
+2019-08-04 07:42 Darafei Praliaskouski <me at komzpa.net>
+ * [r17671] NEWS, liblwgeom/lwin_geojson.c: ST_GeomFromGeoJSON crash
+ on empty rings
+ Closes #4470
+2019-07-31 21:41 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17650] NEWS, loader/pgsql2shp-core.c, loader/shp2pgsql-core.c:
+ Handle POINT EMPTY in shape loader/dumper
+ References #4437
+2019-07-29 16:45 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17643] NEWS, loader/pgsql2shp-core.c: Handle NULL geometry
+ values in pgsql2shp
+ Closes #4209
+2019-07-29 16:30 Sandro Santilli <strk at kbt.io>
+ * [r17638] .gitlab-ci.yml: [gitlab-ci] Be explicit about target
+ distro (stretch)
+2019-07-29 15:32 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17632] NEWS, postgis/gserialized_estimate.c: Fix undefined
+ behaviour in _postgis_gserialized_stats
+ References #4466
+2019-07-16 08:57 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17606] libpgcommon/Makefile.in, loader/Makefile.in,
+ raster/loader/Makefile.in: Add CPPFLAGS where missing
+ Spotted by Debian's build log hardening checker, blhc.
+ https://salsa.debian.org/debian-gis-team/postgis/-/jobs/222378
+ Patch by Christoph Berg <myon -at- debian.org>
+2019-06-20 15:13 Sandro Santilli <strk at kbt.io>
+ * [r17552] .drone-1.0.yml: [drone] Branch 2.3 is not ready for
+ parallel builds...
+2019-06-20 07:08 Sandro Santilli <strk at kbt.io>
+ * [r17550] extensions/postgis_tiger_geocoder/Makefile.in: Ensure
+ sql and expected dirs are created when needed
+ See https://dronie.osgeo.org/postgis/postgis/311/3/2
+2019-06-13 11:54 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17526] NEWS, liblwgeom/cunit/cu_algorithm.c,
+ liblwgeom/lwalgorithm.c: Throw on invalid characters when
+ decoding geohash
+ References #4406
+2019-06-13 07:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17525] NEWS, raster/rt_pg/rtpostgis.c: Avoid pfree'ing the
+ result of getenv
+ Closes #4327
+2019-06-12 13:31 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17514] NEWS, raster/rt_pg/rtpostgis.sql.in,
+ raster/test/regress/tickets.sql,
+ raster/test/regress/tickets_expected: AddRasterConstraints:
+ Ignore NULLs when generating constraints
+ Closes #4388
+2019-06-06 10:24 Sandro Santilli <strk at kbt.io>
+ * [r17478] .drone-1.0.yml: [drone] Add drone-1.0 config
+2019-06-06 06:57 Sandro Santilli <strk at kbt.io>
+ * [r17473] NEWS: Typos..
+2019-06-06 06:51 Sandro Santilli <strk at kbt.io>
+ * [r17472] NEWS: Remove extraneous UTF8 characters
+2019-04-12 22:21 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17388] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: Circular string distances have some failure
+ modes, and test
+ suite should test everything bi-directionally.
+ References #4326
+2019-03-29 14:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17369] NEWS, postgis/postgis.sql.in,
+ regress/postgis_type_name.sql,
+ regress/postgis_type_name_expected: Fix postgis_type_name with
+ (GEOMETRYM,3)
+ Patch by Matt Bretl
+ References #4361
+2019-03-11 20:05 Regina Obe <lr at pcorp.us>
+ * [r17338] Version.config, ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh,
+ extensions/upgradeable_versions.mk: Flip to 2.3.10dev, also flip
+ winnie to use latest stable GEOS
+2019-03-11 19:39 Regina Obe <lr at pcorp.us>
+ * [r17336] ChangeLog, doc/release_notes.xml: Fix typos in doc
+ release and update change log
+2019-03-11 18:38 Regina Obe <lr at pcorp.us>
+ * [r17334] README.postgis, Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Prep for 2.3.9 release
+2019-03-11 18:21 Regina Obe <lr at pcorp.us>
+ * [r17333] NEWS, raster/rt_pg/rtpostgis.sql.in: Schema qualify all
+ geometry casts in raster code, otherwise materialized views do
+ not resture
+ Closes #4291 for PostGIS 2.3.9
2019-02-15 19:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17257] Update test running instructions
+ * [r17257] extras/ogc_test_suite/README: Update test running
+ instructions
2019-02-15 18:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17255] Update OGC certification scripts to match SFSQL 1.2
- signatures
+ * [r17255] extras/ogc_test_suite/1_schema.sql,
+ extras/ogc_test_suite/2_queries.sql,
+ extras/ogc_test_suite/Makefile: Update OGC certification scripts
+ to match SFSQL 1.2 signatures
2019-02-11 17:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17241] Add generated file
+ * [r17241] liblwgeom/lwin_wkt_lex.c: Add generated file
- * [r17240] Add initialization to lexer
+ * [r17240] liblwgeom/lwin_wkt_lex.l: Add initialization to lexer
References #4017
2019-01-22 09:02 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17204] Revert r17178
+ * [r17204] NEWS, postgis/postgis.sql.in: Revert r17178
It changes the behaviour of _postgis_pgsql_version
@@ -26,22 +167,26 @@
2019-01-18 21:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17188] Un space
+ * [r17188] NEWS: Un space
2019-01-18 18:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17184] Geodetic tolerance issue in 32-bit
+ * [r17184] NEWS, liblwgeom/lwgeodetic.c: Geodetic tolerance issue
+ in 32-bit
References #4298
2019-01-18 17:24 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17178] Use `server_version_num` instead of parsing `version()`
+ * [r17178] NEWS, postgis/postgis.sql.in: Use `server_version_num`
+ instead of parsing `version()`
References #4296
2019-01-18 16:07 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17177] Avoid passing a NULL pointer to GEOSisEmpty
+ * [r17177] NEWS, liblwgeom/lwgeom_geos_clean.c,
+ liblwgeom/lwgeom_geos_cluster.c: Avoid passing a NULL pointer to
+ GEOSisEmpty
Closes #4275
Closes https://github.com/postgis/postgis/pull/362
@@ -48,18 +193,21 @@
2019-01-11 21:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17140] More robust geography distance
+ * [r17140] NEWS, liblwgeom/cunit/cu_tree.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic_tree.c: More robust geography distance
References #4290
2018-12-26 04:12 Regina Obe <lr at pcorp.us>
- * [r17121] Fix so custom --with-projdir= configure switch works
- again.
+ * [r17121] configure.ac: Fix so custom --with-projdir= configure
+ switch works again.
Closes #4279 for PostGIS 2.3
2018-12-17 10:39 Darafei Praliaskouski <me at komzpa.net>
- * [r17111] Support Proj 6. Support is via legacy API.
+ * [r17111] NEWS, configure.ac, liblwgeom/liblwgeom.h.in,
+ macros/ac_proj4_version.m4, raster/macros/ac_proj4_version.m4:
+ Support Proj 6. Support is via legacy API.
Closes #4254
Closes https://github.com/postgis/postgis/pull/354
@@ -66,12 +214,17 @@
2018-11-27 00:16 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17080] Change test conditions to explicit empty test
+ * [r17080] regress/tickets.sql, regress/tickets_expected: Change
+ test conditions to explicit empty test
References #4245
2018-11-25 19:36 Darafei Praliaskouski <me at komzpa.net>
- * [r17076] Stabilize GiST ND indexes for mixed dimensions
+ * [r17076] NEWS, postgis/gserialized_gist_nd.c,
+ regress/Makefile.in, regress/regress_gist_index_nd.data,
+ regress/regress_gist_index_nd.sql,
+ regress/regress_gist_index_nd_expected: Stabilize GiST ND indexes
+ for mixed dimensions
Patch by Darafei Praliaskouski
@@ -84,51 +237,61 @@
2018-11-24 05:08 Regina Obe <lr at pcorp.us>
- * [r17066] Flip to 2.3.9dev
+ * [r17066] Version.config, extensions/upgradeable_versions.mk: Flip
+ to 2.3.9dev
2018-11-24 05:02 Regina Obe <lr at pcorp.us>
- * [r17064] Preparing for 2.3.8 release
+ * [r17064] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk:
+ Preparing for 2.3.8 release
2018-11-22 16:14 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17056] Avoid unaligned memory access in BOX2D_out
+ * [r17056] NEWS, postgis/lwgeom_box.c: Avoid unaligned memory
+ access in BOX2D_out
References #4244
2018-11-22 13:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17050] Fix undefined behaviour in ST_3DDistance
+ * [r17050] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.h, liblwgeom/measures3d.c,
+ regress/measures.sql, regress/measures_expected: Fix undefined
+ behaviour in ST_3DDistance
References #4246
2018-11-21 14:10 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17040] Fix undefined behaviour in raster intersection
+ * [r17040] NEWS, raster/rt_core/rt_spatial_relationship.c: Fix
+ undefined behaviour in raster intersection
References #4249
2018-11-21 11:43 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17035] Avoid undefined behaviour in next_float functions (Raúl
- Marín)
+ * [r17035] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/lwgeom_api.c: Avoid undefined behaviour in next_float
+ functions (Raúl Marín)
References #4247
2018-11-15 09:05 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17016] Allocate enough memory in gidx_to_string
+ * [r17016] NEWS, libpgcommon/gserialized_gist.c: Allocate enough
+ memory in gidx_to_string
References #4236
2018-11-07 17:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16994] Add 4223 news line
+ * [r16994] NEWS: Add 4223 news line
2018-11-07 17:15 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16993] Patch over bad behaviour for near-parallel boxes and
- distancetree.
+ * [r16993] liblwgeom/lwgeodetic.h: Patch over bad behaviour for
+ near-parallel boxes and distancetree.
Unfortunately, this "fix" is probably breakable, just put the
boxes closer and closer together until we get "close enough to be
@@ -139,7 +302,8 @@
2018-10-23 13:07 Darafei Praliaskouski <me at komzpa.net>
- * [r16943] [raster] Fix envelope Contains shortcut in ST_Clip
+ * [r16943] NEWS, raster/rt_pg/rtpostgis.sql.in: [raster] Fix
+ envelope Contains shortcut in ST_Clip
Patch by Sai-bot
@@ -147,7 +311,8 @@
2018-10-17 14:28 Sandro Santilli <strk at kbt.io>
- * [r16920] Fix support for PostgreSQL-12 ("getrelid" macro removed)
+ * [r16920] NEWS, postgis/gserialized_estimate.c: Fix support for
+ PostgreSQL-12 ("getrelid" macro removed)
The call is replaced with its expansion which should work
as back as PostgreSQL-9.1 which is before the oldest version
@@ -161,63 +326,73 @@
2018-10-15 11:47 Sandro Santilli <strk at kbt.io>
- * [r16912] Only drop function IF EXISTS ...
+ * [r16912] topology/topology_drop_before.sql.in: Only drop function
+ IF EXISTS ...
2018-10-15 11:31 Sandro Santilli <strk at kbt.io>
- * [r16907] Use portable code to write extension-protection line
+ * [r16907] NEWS, extensions/postgis/Makefile.in: Use portable code
+ to write extension-protection line
References #4203 in 2.3 branch
2018-10-15 10:41 Sandro Santilli <strk at kbt.io>
- * [r16902] [topology] properly drop removed internal functions on
- upgrade
+ * [r16902] NEWS, topology/topology_drop_before.sql.in: [topology]
+ properly drop removed internal functions on upgrade
References #4202 in 2.3 branch
2018-10-02 11:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16868] Fix undefined behaviour in ptarray_clone_deep
+ * [r16868] NEWS, liblwgeom/ptarray.c: Fix undefined behaviour in
+ ptarray_clone_deep
References #4191
2018-10-02 09:45 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16865] Fix undefined behaviour in SADFWrite
+ * [r16865] NEWS, loader/safileio.c: Fix undefined behaviour in
+ SADFWrite
References #4189
2018-09-14 15:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16799] Use qualified names in topology extension install
+ * [r16799] NEWS,
+ extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in:
+ Use qualified names in topology extension install
References #4160
2018-09-13 19:24 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16782] Avoid array overflow in ANALYZE (References #2985)
+ * [r16782] postgis/gserialized_estimate.c: Avoid array overflow in
+ ANALYZE (References #2985)
2018-06-12 12:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16614] Fix flags in case where a boxless geom comes in with a
- "has box" set of flags.
+ * [r16614] liblwgeom/g_serialized.c: Fix flags in case where a
+ boxless geom comes in with a "has box" set of flags.
Closes #4707
2018-05-23 09:27 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16587] Avoid segfault in median test (32bits)
+ * [r16587] liblwgeom/lwgeom_median.c: Avoid segfault in median test
+ (32bits)
References #4095
2018-05-22 19:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16585] Inconsistent results from qsort callback (yugr)
+ * [r16585] NEWS, liblwgeom/effectivearea.c, liblwgeom/measures.c:
+ Inconsistent results from qsort callback (yugr)
References #4093
2018-05-21 11:03 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16580] Fix bug in lwgeom_median and avoid division by zero
+ * [r16580] NEWS, liblwgeom/lwgeom_median.c: Fix bug in
+ lwgeom_median and avoid division by zero
References #3997
Closes https://github.com/postgis/postgis/pull/245
@@ -224,58 +399,72 @@
2018-05-16 21:39 Nicklas Avén <nicklas.aven at jordogskog.no>
- * [r16574] Fixes bounding box handling in twkb_input #4089
+ * [r16574] liblwgeom/lwin_twkb.c, regress/tickets.sql,
+ regress/tickets_expected: Fixes bounding box handling in
+ twkb_input #4089
2018-05-12 20:31 Regina Obe <lr at pcorp.us>
- * [r16571] comment out sfcgal tests for now until we resolve
- cgal/sfcgal dependency issue on debian (hopefully got syntax
- right this time)
+ * [r16571] ci/debbie/postgis_regress.sh: comment out sfcgal tests
+ for now until we resolve cgal/sfcgal dependency issue on debian
+ (hopefully got syntax right this time)
References #4068
2018-05-09 07:30 Regina Obe <lr at pcorp.us>
- * [r16568] comment out sfcgal tests for now until we resolve
+ * [r16568] ci/debbie/postgis_regress.sh: comment out sfcgal tests
References #4068
2018-04-24 09:28 Regina Obe <lr at pcorp.us>
- * [r16551] Disable interrupt tests by default, now requires
- --with-interrupt-tests to turn on.
+ * [r16551] NEWS, configure.ac: Disable interrupt tests by default,
+ now requires --with-interrupt-tests to turn on.
This is to quiet false alarms which often happen on a busy box
Closes #4074
2018-04-21 13:17 Darafei Praliaskouski <me at komzpa.net>
- * [r16549] ST_ClusterKMeans crash on NULL and EMPTY
+ * [r16549] NEWS, liblwgeom/lwkmeans.c, regress/lwgeom_regress.sql,
+ regress/lwgeom_regress_expected: ST_ClusterKMeans crash on NULL
+ and EMPTY
Closes #4071
2018-04-06 04:58 Regina Obe <lr at pcorp.us>
- * [r16525] Flip version to 2.3.8dev
+ * [r16525] Version.config, extensions/upgradeable_versions.mk: Flip
+ version to 2.3.8dev
2018-04-02 07:04 Regina Obe <lr at pcorp.us>
- * [r16521] Fix winnie's packaging versions for GEOS and GDAL
+ * [r16521] ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh: Fix
+ winnie's packaging versions for GEOS and GDAL
2018-04-02 03:58 Regina Obe <lr at pcorp.us>
- * [r16516] Update postgis_release_docs recipe for 2.2 (to be same
- as 2.4, so debbie can build)
+ * [r16516] ci/debbie/postgis_release_docs.sh: Update
+ postgis_release_docs recipe for 2.2 (to be same as 2.4, so debbie
+ can build)
2018-04-02 03:01 Regina Obe <lr at pcorp.us>
- * [r16512] Update to 2.3.7 and get everything ready in prep for
- official tagging on Friday (2018-04-06)
+ * [r16512] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Update to 2.3.7 and get
+ everything ready in prep for official tagging on Friday
+ (2018-04-06)
2018-03-28 09:02 Regina Obe <lr at pcorp.us>
- * [r16505] Fix crasher in raster when fed an empty raster (note was
- tempted to change the def of empty raster to include raster with
- no bands but not sure where else that is used, so just revised
- the clip check to not try to clip if no bands).
+ * [r16505] NEWS, doc/reference_raster.xml,
+ raster/rt_pg/rtpg_mapalgebra.c, raster/test/regress/tickets.sql,
+ raster/test/regress/tickets_expected: Fix crasher in raster when
+ fed an empty raster (note was tempted to change the def of empty
+ raster to include raster with no bands but not sure where else
+ that is used, so just revised the clip check to not try to clip
+ if no bands).
References #3055 for PostGIS 2.3.7,
also minor doc fix references #2925 for PostGIS 2.3.7
reorder NEWS tickets numerically
@@ -282,55 +471,64 @@
2018-03-27 17:38 Darafei Praliaskouski <me at komzpa.net>
- * [r16501] ST_CPAWithin precision fix
+ * [r16501] NEWS, liblwgeom/lwlinearreferencing.c: ST_CPAWithin
+ precision fix
Closes #4032
2018-03-24 00:01 Daniel Baston <dbaston at gmail.com>
- * [r16492] Avoid dropping SRID in ST_ClusterIntersecting
+ * [r16492] liblwgeom/lwgeom_geos_cluster.c, regress/tickets.sql,
+ regress/tickets_expected: Avoid dropping SRID in
+ ST_ClusterIntersecting
References #4055
2018-03-22 15:45 Regina Obe <lr at pcorp.us>
- * [r16481] schema qualify geography functions (including ST_Buffer)
+ * [r16481] NEWS, postgis/geography.sql.in: schema qualify geography
+ functions (including ST_Buffer)
References #4052 for PostGIS 2.3.7
2018-02-26 20:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16427] Add generated lexer (for 2.3)
+ * [r16427] liblwgeom/lwin_wkt_lex.c: Add generated lexer (for 2.3)
- * [r16426] Fix memory corruption in case where lexer is interrupted
- mid-process
+ * [r16426] NEWS, liblwgeom/lwin_wkt_lex.l: Fix memory corruption in
+ case where lexer is interrupted mid-process
References #4017
For 2.3
2018-02-26 18:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16421] Use more precise bounds when testing overlap of temporal
- ranges.
+ * [r16421] NEWS, liblwgeom/lwlinearreferencing.c: Use more precise
+ bounds when testing overlap of temporal ranges.
For 2.3, references #4025
2018-02-23 19:54 Regina Obe <lr at pcorp.us>
- * [r16414] Add Raúl Marín Rodríguez to svn and git authors lists
+ * [r16414] authors.git, authors.svn: Add Raúl Marín Rodríguez to
+ svn and git authors lists
2018-02-22 22:22 Regina Obe <lr at pcorp.us>
- * [r16411] Backport ci changes to 2.3
+ * [r16411] ci/winnie/build_postgis.sh,
+ Backport ci changes to 2.3
2018-02-22 13:42 Sandro Santilli <strk at kbt.io>
- * [r16408] [gitlab-ci] Switch to PostgreSQL 9.6 and libjson-c-dev
+ * [r16408] .gitlab-ci.yml: [gitlab-ci] Switch to PostgreSQL 9.6 and
+ libjson-c-dev
Fixes gitlab-ci build for 2.3, references #4023
2018-02-22 11:16 Darafei Praliaskouski <me at komzpa.net>
- * [r16407] Fix cast from box3d to geometry
+ * [r16407] NEWS, postgis/lwgeom_box3d.c, regress/regress_expected,
+ regress/sfcgal/regress_expected: Fix cast from box3d to geometry
Patch by Matthias Bay
@@ -339,13 +537,14 @@
2018-01-26 14:56 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16363] lwpoly_construct_circle: Avoid division by zero (Raúl
- Marín Rodríguez)
+ * [r16363] NEWS, liblwgeom/lwpoly.c: lwpoly_construct_circle: Avoid
+ division by zero (Raúl Marín Rodríguez)
References #4003
2018-01-22 14:13 Sandro Santilli <strk at kbt.io>
- * [r16357] Set availability of support function for KNN index
+ * [r16357] NEWS, postgis/geography.sql.in: Set availability of
+ support function for KNN index
Fixes upgrade from 2.1 to 2.2+
References #3978 in 2.3 branch (2.3.7)
@@ -352,8 +551,8 @@
2018-01-22 12:37 Sandro Santilli <strk at kbt.io>
- * [r16354] [drone] Use trisquel2 image, test all pgsql versions and
- upgrades
+ * [r16354] .drone.yml: [drone] Use trisquel2 image, test all pgsql
+ versions and upgrades
The new docker image also uses newer GEOS (3.6.2).
References #3813 for 2.3 branch
@@ -361,32 +560,40 @@
2018-01-22 11:31 Sandro Santilli <strk at kbt.io>
- * [r16351] Backport run_test.pl fixes from trunk
+ * [r16351] regress/run_test.pl: Backport run_test.pl fixes from
+ trunk
2018-01-16 06:33 Regina Obe <lr at pcorp.us>
- * [r16314] flip version to 2.3.7dev, add in 2.3.6 to upgrade path
+ * [r16314] Version.config, ci/debbie/postgis_make_dist.sh,
+ ci/debbie/postgis_release_docs.sh,
+ extensions/upgradeable_versions.mk: flip version to 2.3.7dev, add
+ in 2.3.6 to upgrade path
backport changes to stamp timestamp
References #3991 for PostGIS 2.3.7dev
2018-01-15 21:01 Regina Obe <lr at pcorp.us>
- * [r16303] Get rid of sed fiddling with SVN revision
+ * [r16303] ci/debbie/postgis_release_docs.sh: Get rid of sed
+ fiddling with SVN revision
2018-01-15 20:58 Regina Obe <lr at pcorp.us>
- * [r16302] more clearifying notes on HOWTO_RELEASE
+ * [r16302] HOWTO_RELEASE, Version.config: more clearifying notes on
+ HOWTO_RELEASE
change version to 2.3.6 in prep for tagging tomorrow or
Wednesday.
2018-01-15 02:19 Regina Obe <lr at pcorp.us>
- * [r16300] update change log, echo branch reference, minor
- correction to HOWTO_RELEASE
+ * [r16300] ChangeLog, HOWTO_RELEASE,
+ ci/debbie/postgis_make_dist.sh: update change log, echo branch
+ reference, minor correction to HOWTO_RELEASE
2018-01-14 16:05 Regina Obe <lr at pcorp.us>
- * [r16295] minor edits to HOWTO_RELEASE
+ * [r16295] HOWTO_RELEASE, Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: minor edits to HOWTO_RELEASE
Add 2.3.5, 2.3.6dev to upgradeable_versions.mk
Update release_notes.xml to reflect impending release
Flip version to 2.3.6rc1 (in prep for rc1 tagging)
@@ -393,8 +600,9 @@
2018-01-14 15:34 Regina Obe <lr at pcorp.us>
- * [r16291] Backport changes to standardize debbie's packaging and
- ensure
+ * [r16291] HOWTO_RELEASE, NEWS, ci/debbie/postgis_make_dist.sh,
+ ci/debbie/postgis_release_docs.sh, make_dist.sh: Backport changes
+ to standardize debbie's packaging and ensure
she builds tagged versions as well without manual intervention
Update HOWTO_RELEASE to reflect change
References #3985 for PostGIS 2.3
@@ -401,12 +609,15 @@
2018-01-12 13:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16272] 2.3 fix, st_transform does not qualify query to
- spatial_ref_sys (references #3975)
+ * [r16272] NEWS, libpgcommon/lwgeom_pg.h,
+ libpgcommon/lwgeom_transform.c, libpgcommon/lwgeom_transform.h:
+ 2.3 fix, st_transform does not qualify query to spatial_ref_sys
+ (references #3975)
2018-01-12 09:38 Sandro Santilli <strk at kbt.io>
- * [r16267] Add check for PostgreSQL version compatibility in
+ * [r16267] NEWS, postgis/postgis.sql.in, postgis/sqldefines.h.in:
+ Add check for PostgreSQL version compatibility in
postgis_full_version
Adds _postgis_scripts_pgsql_version() and
@@ -421,7 +632,8 @@
2018-01-12 08:55 Darafei Praliaskouski <me at komzpa.net>
- * [r16265] Encoded Polyline of EMPTY
+ * [r16265] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
+ liblwgeom/lwout_encoded_polyline.c: Encoded Polyline of EMPTY
Pull in from trunk
Closes #3982
@@ -428,34 +640,35 @@
2018-01-09 20:52 Sandro Santilli <strk at kbt.io>
- * [r16246] Use template1 for connecting
+ * [r16246] .drone.yml: Use template1 for connecting
2018-01-09 20:29 Sandro Santilli <strk at kbt.io>
- * [r16245] Wait for database to be up before proceeding
+ * [r16245] .drone.yml: Wait for database to be up before proceeding
2018-01-09 18:41 Sandro Santilli <strk at kbt.io>
- * [r16244] Simplify syntax for brin opclasses so upgrade script
- recognizes it
+ * [r16244] NEWS, postgis/geography_brin.sql.in,
+ postgis/postgis_brin.sql.in: Simplify syntax for brin opclasses
+ so upgrade script recognizes it
Fixes #3956 in 2.3 branch
- * [r16243] Do not assume CREATE OPERATOR CLASS needs to end with
+ * [r16243] utils/postgis_proc_upgrade.pl: Do not assume CREATE
+ OPERATOR CLASS needs to end with ');'
A single ending semicolon is enough to terminate the statement
2018-01-09 18:40 Sandro Santilli <strk at kbt.io>
- * [r16242] Upgrade SFCGAL too when requested
+ * [r16242] regress/run_test.pl: Upgrade SFCGAL too when requested
2018-01-02 14:09 Darafei Praliaskouski <me at komzpa.net>
- * [r16214] Fix KMeans initialization issue that lost clusters
- sometimes.
+ * [r16214] NEWS, liblwgeom/lwkmeans.c: Fix KMeans initialization
+ issue that lost clusters sometimes.
Closes #3965
Closes https://github.com/postgis/postgis/pull/179
@@ -462,56 +675,68 @@
2018-01-02 13:45 Darafei Praliaskouski <me at komzpa.net>
- * [r16210] Drag in authors mapping from trunk.
+ * [r16210] authors.git, authors.svn: Drag in authors mapping from
+ trunk.
2017-12-12 18:10 Regina Obe <lr at pcorp.us>
- * [r16147] add in verbose and logic to drop test database if it
- exists. Switch to using BRANCH instead of TAG
+ * [r16147] ci/bessie/postgis_regress.sh,
+ ci/bessie32/postgis_regress.sh: add in verbose and logic to drop
+ test database if it exists. Switch to using BRANCH instead of TAG
2017-12-10 01:55 Regina Obe <lr at pcorp.us>
- * [r16140] use new osgeo project logo
+ * [r16140] doc/html/images/osgeo_logo.png: use new osgeo project
+ logo
2017-11-30 21:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16132] Support google line encodings that include a backslash
- character (References #3713)
+ * [r16132] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
+ liblwgeom/lwout_encoded_polyline.c, postgis/lwgeom_export.c:
+ Support google line encodings that include a backslash character
+ (References #3713)
2017-11-29 02:37 Regina Obe <lr at pcorp.us>
- * [r16125] Add to bessie step to install and test extension install
+ * [r16125] ci/bessie/postgis_regress.sh: Add to bessie step to
+ install and test extension install
2017-11-29 01:12 Regina Obe <lr at pcorp.us>
- * [r16124] Explicitly specify $(PERL) to call create_unpackaged.pl
- otherwise at least on freebsd it fails (and backport other minor
- changes like remove of 9.1 which support was dropped in 2.2)
+ * [r16124] ci/bessie, ci/bessie/postgis_regress.sh, ci/bessie32,
+ ci/bessie32/postgis_regress.sh,
+ extensions/postgis_sfcgal/Makefile.in: Explicitly specify $(PERL)
+ to call create_unpackaged.pl otherwise at least on freebsd it
+ fails (and backport other minor changes like remove of 9.1 which
+ support was dropped in 2.2)
Closes #3938 for PostGIS 2.3.6
Also add the Bessie sisters to battery testing
2017-11-15 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16111] Push versions for next release
+ * [r16111] NEWS, Version.config: Push versions for next release
2017-11-15 17:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16109] Prepare for release
+ * [r16109] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml: Prepare for release
2017-11-09 09:01 Regina Obe <lr at pcorp.us>
- * [r16101] Add missing 2.2.6 upgrade path
+ * [r16101] NEWS, extensions/upgradeable_versions.mk: Add missing
+ 2.2.6 upgrade path
References #3926 for PostGIS 2.3.5
2017-11-09 08:55 Regina Obe <lr at pcorp.us>
- * [r16100] Add missing release notes for ST_Segmentize geography
- fix.
+ * [r16100] NEWS: Add missing release notes for ST_Segmentize
+ geography fix.
References #3667 for PostGIS 2.3.5
2017-11-07 18:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16095] Replace project-and-entend logic with
+ * [r16095] liblwgeom/cunit/cu_geodetic.c, liblwgeom/lwgeodetic.c,
+ regress/geography_expected: Replace project-and-entend logic with
bisect-and-recurse in geography segmentization.
Preserves "mostly equal" segment lengths, and
should be more numerically stable.
@@ -520,8 +745,8 @@
2017-10-31 15:33 Sandro Santilli <strk at kbt.io>
- * [r16087] Make sure target directories are created before copying
- files to them
+ * [r16087] configure.ac, liblwgeom/Makefile.in: Make sure target
+ directories are created before copying files to them
References #3912 for 2.3 branch
References #3916 for 2.3 branch
@@ -528,7 +753,10 @@
2017-10-21 09:04 Sandro Santilli <strk at kbt.io>
- * [r16030] Put build AUX files under build-aux
+ * [r16030] .gitignore, GNUmakefile.in, configure.ac,
+ liblwgeom/Makefile.in, loader/Makefile.in, raster/install-sh,
+ raster/loader/Makefile.in, utils/Makefile.in: Put build AUX files
+ under build-aux
Cleans and ignore build aux files from new location,
and remove spurious install-sh from repository.
@@ -537,21 +765,26 @@
2017-10-18 18:19 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16010] Push versions to dev
+ * [r16010] HOWTO_RELEASE, NEWS, Version.config,
+ extensions/upgradeable_versions.mk: Push versions to dev
2017-10-18 18:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16008] Prepare for 2.3.4 release
+ * [r16008] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ extensions/upgradeable_versions.mk: Prepare for 2.3.4 release
2017-10-17 16:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15998] Allocate enough space for all possible GBOX string
- outputs (Raúl Marín Rodríguez)
+ * [r15998] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
+ Allocate enough space for all possible GBOX string outputs (Raúl
+ Marín Rodríguez)
Closes #3907
2017-10-10 22:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15959] Throw error on malformed WKB input (2.3 branch)
+ * [r15959] NEWS, liblwgeom/lwin_wkb.c: Throw error on malformed WKB
+ input (2.3 branch)
Credit to OSS-Fuzz:
https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2589
Credit to OSS-Fuzz:
@@ -564,136 +797,158 @@
2017-10-10 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15954] Undefined behaviour in pointarray_to_encoded_polyline
- (2.3 branch)
+ * [r15954] NEWS, liblwgeom/lwout_encoded_polyline.c: Undefined
+ behaviour in pointarray_to_encoded_polyline (2.3 branch)
(References #3891)
2017-10-10 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15949] Fix undefined behaviour in zigzag with negative inputs
- (2.4 branch)
+ * [r15949] NEWS, liblwgeom/cunit/cu_varint.c, liblwgeom/varint.c,
+ liblwgeom/varint.h: Fix undefined behaviour in zigzag with
+ negative inputs (2.4 branch)
(References #3882)
2017-10-10 16:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15946] lw_dist2d_pt_arc division by zero (References #3874)
+ * [r15946] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: lw_dist2d_pt_arc division by zero
+ (References #3874)
2017-10-06 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15920] geohash_point_as_int: Fix undefined behaviour in shift
- operation
+ * [r15920] NEWS, liblwgeom/lwalgorithm.c: geohash_point_as_int: Fix
+ undefined behaviour in shift operation
References #3875
2017-10-06 13:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15916] Undefined behaviour in TYPMOD_GET_SRID
+ * [r15916] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/liblwgeom.h.in: Undefined behaviour in TYPMOD_GET_SRID
References #3880
2017-10-05 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15901] Combine multiple signum definitions (2.3)
+ * [r15901] NEWS, liblwgeom/cunit/cu_geodetic.c,
+ liblwgeom/cunit/cu_libgeom.c, liblwgeom/liblwgeom_internal.h,
+ liblwgeom/lwalgorithm.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic.h, liblwgeom/lwspheroid.c: Combine multiple
+ signum definitions (2.3)
(References #3878)
2017-10-05 13:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15898] division by zero in lw_dist2d_arc_arc
+ * [r15898] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: division by zero in lw_dist2d_arc_arc
References #3879
2017-10-02 12:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15871] Gracefully handle short-measure issue (Closes #3845)
+ * [r15871] NEWS, liblwgeom/lwlinearreferencing.c: Gracefully handle
+ short-measure issue (Closes #3845)
2017-10-02 06:20 Sandro Santilli <strk at kbt.io>
- * [r15867] Add -lm to liblwgeom link line
+ * [r15867] NEWS, liblwgeom/Makefile.in: Add -lm to liblwgeom link
+ line
References #3869 for 2.3 branch
2017-09-30 17:46 Sandro Santilli <strk at kbt.io>
- * [r15861] Fix yaml syntax in drone config
+ * [r15861] .drone.yml: Fix yaml syntax in drone config
2017-09-26 19:48 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15838] TWKB news item (References #3866)
+ * [r15838] NEWS: TWKB news item (References #3866)
2017-09-26 19:10 Nicklas Avén <nicklas.aven at jordogskog.no>
- * [r15837] increase possible size of varint
+ * [r15837] liblwgeom/bytebuffer.c: increase possible size of varint
2017-09-26 17:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15835] Triangles un-closed in M should be WKT parseable (Closes
- #3818)
+ * [r15835] NEWS, liblwgeom/lwin_wkb.c, liblwgeom/lwin_wkt.c:
+ Triangles un-closed in M should be WKT parseable (Closes #3818)
2017-09-25 13:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15815] Not-quite curved CurvePolygon rejected by ST_Contains
- (Closes #3781)
+ * [r15815] NEWS, liblwgeom/lwstroke.c: Not-quite curved
+ CurvePolygon rejected by ST_Contains (Closes #3781)
2017-09-20 00:19 Regina Obe <lr at pcorp.us>
- * [r15776] ST_ConcaveHull fix for ExteriorRing is not a polygon
+ * [r15776] NEWS, postgis/postgis.sql.in: ST_ConcaveHull fix for
+ ExteriorRing is not a polygon
References #2836 for PostGIS 2.3.4
2017-09-18 21:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15762] News item (references #3731)
+ * [r15762] NEWS: News item (references #3731)
2017-09-18 14:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15761] Added NEWS entry (references #3774)
+ * [r15761] NEWS: Added NEWS entry (references #3774)
2017-09-18 13:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15756] Trig length calculation for compoundcurve in 2.3 branch
- (references #3774)
+ * [r15756] liblwgeom/lwcompound.c: Trig length calculation for
+ compoundcurve in 2.3 branch (references #3774)
2017-09-14 22:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15740] #3731, backend crash on zero size stats histogram
+ * [r15740] postgis/gserialized_estimate.c: #3731, backend crash on
+ zero size stats histogram
2017-09-14 14:01 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15724] #3847, coverity fixes for 2.3
+ * [r15724] extensions/address_standardizer/gamma.c,
+ loader/dbfopen.c, loader/pgsql2shp-core.c,
+ loader/shp2pgsql-core.c, raster/loader/raster2pgsql.c: #3847,
+ coverity fixes for 2.3
2017-09-13 20:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15718] Fix misplaced section end
+ * [r15718] doc/extras_topology.xml: Fix misplaced section end
2017-09-13 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15714] #3249, #2352, document ST_RemoveIsoEdge
+ * [r15714] doc/extras_topology.xml: #3249, #2352, document
+ ST_RemoveIsoEdge
2017-09-13 13:14 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15709] Light PgSQL 11 support so I can compile and test bug
- fixes
+ * [r15709] topology/postgis_topology.c: Light PgSQL 11 support so I
+ can compile and test bug fixes
2017-09-11 16:38 Sandro Santilli <strk at kbt.io>
- * [r15686] [drone] Extract upgrade target version dynamically
+ * [r15686] .drone.yml: [drone] Extract upgrade target version
+ dynamically
2017-09-11 15:50 Regina Obe <lr at pcorp.us>
- * [r15683] initialize state->num_fields and state->pgfieldtypes so
- doesn't cause intermittent crashes on windows
+ * [r15683] NEWS, loader/shp2pgsql-core.c: initialize
+ state->num_fields and state->pgfieldtypes so doesn't cause
+ intermittent crashes on windows
Closes #3839 for PostGIS 2.3.4
2017-09-11 15:16 Regina Obe <lr at pcorp.us>
- * [r15682] always enable loader cunit tests
+ * [r15682] loader/Makefile.in: always enable loader cunit tests
References #3839
2017-09-07 05:51 Regina Obe <lr at pcorp.us>
- * [r15645] fix field typo in reverse_geocoder
+ * [r15645] extras/tiger_geocoder/geocode/reverse_geocode.sql: fix
+ field typo in reverse_geocoder
Closes #3833 for PostGIS 2.3.4
2017-09-05 21:25 Sandro Santilli <strk at kbt.io>
- * [r15635] Revert "Rework PGSQL_VERSION again so to use 2-digits
- minor from 10 onward"
+ * [r15635] configure.ac, libpgcommon/gserialized_gist.c,
+ postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c:
+ Revert "Rework PGSQL_VERSION again so to use 2-digits minor from
+ 10 onward"
This reverts commit r15631
@@ -704,37 +959,50 @@
2017-09-05 20:50 Sandro Santilli <strk at kbt.io>
- * [r15632] Add item about PostgreSQL 10 support
+ * [r15632] NEWS: Add item about PostgreSQL 10 support
- * [r15631] Rework PGSQL_VERSION again so to use 2-digits minor from
- 10 onward
+ * [r15631] configure.ac, libpgcommon/gserialized_gist.c,
+ Rework PGSQL_VERSION again so to use 2-digits minor from 10
+ onward
See #3614 (for 2.3 branch)
2017-09-05 20:37 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15630] Support PgSQL 10 on PostGIS 2.3
+ * [r15630] configure.ac, libpgcommon/gserialized_gist.c,
+ postgis/gserialized_estimate.c, postgis/gserialized_gist_nd.c,
+ raster/rt_pg/rtpostgis.sql.in, raster/test/regress/rt_union.sql,
+ raster/test/regress/rt_union_expected,
+ regress/regress_selectivity.sql,
+ topology/sql/topogeometry/totopogeom.sql.in,
+ topology/test/regress/copytopology.sql,
+ topology/test/regress/copytopology_expected: Support PgSQL 10 on
+ PostGIS 2.3
2017-09-05 16:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15627] #3829 Segfault in LWGEOM2GEOS
+ * [r15627] liblwgeom/cunit/cu_geos.c, liblwgeom/lwgeom_geos.c:
+ #3829 Segfault in LWGEOM2GEOS
2017-09-04 00:06 Daniel Baston <dbaston at gmail.com>
- * [r15618] #3499, Clarify distance units in docs for
- ST_ClusterWithin
+ * [r15618] doc/reference_measure.xml: #3499, Clarify distance units
+ in docs for ST_ClusterWithin
2017-09-01 14:00 Regina Obe <lr at pcorp.us>
- * [r15612] Note that ST_Intersection drops M
+ * [r15612] doc/reference_processing.xml: Note that ST_Intersection
+ drops M
Closes #3826 for PostGIS 2.3.4
2017-08-24 18:05 Regina Obe <lr at pcorp.us>
- * [r15585] fix issues with loading tabblock, incorporate changes
- from Jeffrey Wescott
+ * [r15585] NEWS, doc/installation.xml,
+ extras/tiger_geocoder/tiger_loader_2016.sql: fix issues with
+ loading tabblock, incorporate changes from Jeffrey Wescott
change url to new census ssl one
update docs to describe how to load bg, tract, tabblock tables
Closes #3698 for PostGIS 2.3.4
@@ -742,23 +1010,28 @@
2017-08-24 03:00 Regina Obe <lr at pcorp.us>
- * [r15579] delete no longer used
+ * [r15579] extras/tiger_geocoder/census_loader.sql: delete no
+ longer used
2017-08-20 06:31 Regina Obe <lr at pcorp.us>
- * [r15557] Add reference to ST_HausdorffDistance to ST_Distance
- function.
+ * [r15557] doc/reference_measure.xml: Add reference to
+ ST_HausdorffDistance to ST_Distance function.
per Gary Turner
https://lists.osgeo.org/pipermail/postgis-users/2017-August/042322.html
2017-08-18 04:02 Regina Obe <lr at pcorp.us>
- * [r15554] Reverse geocoder missing street suffix direction.
+ * [r15554] NEWS, extras/tiger_geocoder/geocode/reverse_geocode.sql,
+ extras/tiger_geocoder/regress/reverse_geocode_regress,
+ extras/tiger_geocoder/regress/reverse_geocode_regress.sql:
+ Reverse geocoder missing street suffix direction.
Closes #3806 for PostGIS 2.3.4
2017-08-10 09:36 Regina Obe <lr at pcorp.us>
- * [r15547] Fix travis build by changing permissions of home folder
+ * [r15547] .travis.yml: Fix travis build by changing permissions of
+ home folder
upgrade to test on 9.5
References #3803 for PostGIS 2.3.4
Closes https://github.com/postgis/postgis/pull/134
@@ -765,134 +1038,149 @@
2017-08-08 23:48 Regina Obe <lr at pcorp.us>
- * [r15546] doc Patch from Even Rouault
+ * [r15546] doc/reference_raster.xml: doc Patch from Even Rouault
Closes #3804 for PostGIS 2.3.4
2017-08-08 15:36 Sandro Santilli <strk at kbt.io>
- * [r15543] Request crlf for .bat files
+ * [r15543] .editorconfig: Request crlf for .bat files
2017-08-05 11:16 Regina Obe <lr at pcorp.us>
- * [r15524] Clarify description of ST_Snap that it is the newly
- snapped input geometry and will return input geometry unchanged
- if no snapping.
+ * [r15524] doc/reference_editor.xml: Clarify description of ST_Snap
+ that it is the newly snapped input geometry and will return input
+ geometry unchanged if no snapping.
2017-08-04 23:02 Regina Obe <lr at pcorp.us>
- * [r15523] revert last change seems other things I borught over
- from 2.4 where are unrelated to #3800
+ * [r15523] loader/shp2pgsql-core.c: revert last change seems other
+ things I borught over from 2.4 where are unrelated to #3800
2017-08-04 22:49 Regina Obe <lr at pcorp.us>
- * [r15522] Fix email addresses and credit stuff. shp2pgsql-gui Add
- support for exporting materialized views, foreign tables, and
- partitioned tables
+ * [r15522] NEWS, loader/shp2pgsql-core.c, loader/shp2pgsql-gui.c:
+ Fix email addresses and credit stuff. shp2pgsql-gui Add support
+ for exporting materialized views, foreign tables, and partitioned
+ tables
Closes #3800 for PostGIS 2.3.4
2017-07-28 04:09 Regina Obe <lr at pcorp.us>
- * [r15514] Mark 3D functions and some other missed functions as
- parallel safe.
+ * [r15514] NEWS, doc/xsl/postgis_aggs_mm.xml.xsl,
+ postgis/postgis.sql.in, postgis/sfcgal.sql.in: Mark 3D functions
+ and some other missed functions as parallel safe.
Closes #3792 for PostGIS 2.3.4
2017-07-27 19:27 Regina Obe <lr at pcorp.us>
- * [r15511] Solaris build issues due to missing isfinite define
+ * [r15511] NEWS, postgis/gserialized_estimate.c: Solaris build
+ issues due to missing isfinite define
Patch from Julian Schauder
Closes #3795 for PostGIS 2.3.4
2017-07-20 22:34 Regina Obe <lr at pcorp.us>
- * [r15489] OSS-Fuzz detected issues with ptarray
+ * [r15489] NEWS, liblwgeom/ptarray.c: OSS-Fuzz detected issues with
+ ptarray
References #3786 for PostGIS 2.3 (for 2.3.4)
2017-07-10 18:00 Sandro Santilli <strk at kbt.io>
- * [r15483] Fix buffer overflow and use of uninitialized values
+ * [r15483] NEWS, loader/pgsql2shp-core.c: Fix buffer overflow and
+ use of uninitialized values
Closes #3101 for 2.3 branch
2017-07-09 14:35 Regina Obe <lr at pcorp.us>
- * [r15479] Memory leak in lwline_from_wkb_state
+ * [r15479] NEWS, liblwgeom/lwin_wkb.c: Memory leak in
+ lwline_from_wkb_state
Closes #3782 for PostGIS 2.3.4
Patch provided by Even Rouault
2017-07-06 20:41 Regina Obe <lr at pcorp.us>
- * [r15477] missing copying libintl-8.dll needed for the VC++ 32-bit
- builds for postgis-gui
+ * [r15477] ci/winnie/package_postgis.sh: missing copying
+ libintl-8.dll needed for the VC++ 32-bit builds for postgis-gui
2017-07-01 06:49 Regina Obe <lr at pcorp.us>
- * [r15474] bump to 2.3.4dev
+ * [r15474] Version.config, extensions/upgradeable_versions.mk: bump
+ to 2.3.4dev
2017-07-01 04:15 Regina Obe <lr at pcorp.us>
- * [r15472] update version numbers, NEWS, release notes in prep for
- PostGIS 2.3.3 release
+ * [r15472] NEWS, README.postgis, Version.config,
+ doc/release_notes.xml: update version numbers, NEWS, release
+ notes in prep for PostGIS 2.3.3 release
2017-07-01 03:22 Regina Obe <lr at pcorp.us>
- * [r15470] update ChangeLog in prep for PostGIS 2.3.3 release
+ * [r15470] ChangeLog: update ChangeLog in prep for PostGIS 2.3.3
+ release
2017-06-30 20:43 Regina Obe <lr at pcorp.us>
- * [r15469] Bring performance tips section up to newer versions
+ * [r15469] doc/performance_tips.xml, doc/using_postgis_dataman.xml:
+ Bring performance tips section up to newer versions
Closes #3746 for PostGIS 2.3 (branch)
2017-06-24 06:18 Regina Obe <lr at pcorp.us>
- * [r15463] try to fix travis gdal related build error
+ * [r15463] .travis.yml: try to fix travis gdal related build error
2017-06-24 05:36 Regina Obe <lr at pcorp.us>
- * [r15460] fix typo
+ * [r15460] doc/installation.xml: fix typo
- * [r15459] Specify highest version of PostgreSQL supported.
+ * [r15459] doc/installation.xml: Specify highest version of
+ PostgreSQL supported.
References #3762 for PostGIS 2.3.3
2017-06-24 05:31 Regina Obe <lr at pcorp.us>
- * [r15458] change doco for Geocode_Intersection to agree with
- function definition.
+ * [r15458] doc/extras_tigergeocoder.xml: change doco for
+ Geocode_Intersection to agree with function definition.
Closes #3717 for PostGIS 2.3.3
2017-06-24 04:58 Regina Obe <lr at pcorp.us>
- * [r15457] Change ST_Clip from Error to Notice when ST_Clip can
- compute no band
+ * [r15457] NEWS, raster/rt_pg/rtpg_mapalgebra.c: Change ST_Clip
+ from Error to Notice when ST_Clip can compute no band
Closest #3730 for PostGIS 2.3.3
2017-06-24 04:33 Regina Obe <lr at pcorp.us>
- * [r15454] Update 3D example and put a note about function may
- return the same geometry.
+ * [r15454] doc/reference_processing.xml: Update 3D example and put
+ a note about function may return the same geometry.
References #3702 for PostGIS 2.4 (trunk)
2017-06-24 04:06 Regina Obe <lr at pcorp.us>
- * [r15452] Increase LIMIT clause on tests so can more readily catch
- issues like #3704.
+ * [r15452] doc/xsl/postgis_gardentest.sql.xsl: Increase LIMIT
+ clause on tests so can more readily catch issues like #3704.
2017-06-23 22:57 Sandro Santilli <strk at kbt.io>
- * [r15451] Fix lwgeom_cmp return code
+ * [r15451] postgis/lwgeom_btree.c, regress/operators.sql,
+ regress/operators_expected: Fix lwgeom_cmp return code
Closes #3777 once again (for 2.3 branch)
2017-06-23 15:07 Sandro Santilli <strk at kbt.io>
- * [r15449] Fix compiler warnings about printf-like formats
+ * [r15449] topology/postgis_topology.c: Fix compiler warnings about
+ printf-like formats
This was already fixed in trunk
2017-06-23 14:58 Sandro Santilli <strk at kbt.io>
- * [r15448] Fix handling of EMPTY geometries in btree operator
+ * [r15448] NEWS, postgis/lwgeom_btree.c, regress/operators.sql,
+ regress/operators_expected: Fix handling of EMPTY geometries in
+ btree operator
Includes regress test
@@ -900,19 +1188,22 @@
2017-06-23 06:15 Regina Obe <lr at pcorp.us>
- * [r15445] ST_AsX3D handle empty geometries
+ * [r15445] NEWS, liblwgeom/lwout_x3d.c, regress/tickets.sql,
+ regress/tickets_expected: ST_AsX3D handle empty geometries
Closes #3704 for PostGIS 2.3.3
2017-06-23 05:55 Regina Obe <lr at pcorp.us>
- * [r15443] Backport test sql script missed in last commit
+ * [r15443] regress/dumper/realtable-pre.sql: Backport test sql
+ script missed in last commit
References #3682 for 2.3.3
References #3701 for 2.3.3
2017-06-23 05:19 Regina Obe <lr at pcorp.us>
- * [r15442] Backport fixes for pgsql2shp for Boolean field length
- and quote escaping
+ * [r15442] NEWS, loader/pgsql2shp-core.c, loader/pgsql2shp-core.h,
+ regress/dumper/realtable_expected.dbf: Backport fixes for
+ pgsql2shp for Boolean field length and quote escaping
Includes tests for both
Closes #3682
Closes #3701
@@ -919,17 +1210,27 @@
2017-06-19 20:37 Sandro Santilli <strk at kbt.io>
- * [r15437] Avoid ever-growing postgis extension upgrade scripts
+ * [r15437] postgis/Makefile.in: Avoid ever-growing postgis
+ extension upgrade scripts
Fixes #3775 for 2.3 branch
- * [r15436] Style only change: remove trailing blanks
+ * [r15436] postgis/Makefile.in: Style only change: remove trailing
+ blanks
2017-06-06 12:27 Sandro Santilli <strk at kbt.io>
- * [r15421] Speep up -> Speed up
+ * [r15421] NEWS, doc/po/de_DE/release_notes.xml.po,
+ doc/po/es/release_notes.xml.po, doc/po/fr/release_notes.xml.po,
+ doc/po/it_IT/release_notes.xml.po,
+ doc/po/ja/release_notes.xml.po,
+ doc/po/ko_KR/release_notes.xml.po,
+ doc/po/pl/release_notes.xml.po,
+ doc/po/pt_BR/release_notes.xml.po,
+ doc/po/templates/release_notes.xml.pot, doc/release_notes.xml:
+ Speep up -> Speed up
Thanks Andreas Schild via
https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993598/
@@ -936,7 +1237,8 @@
2017-06-06 12:22 Sandro Santilli <strk at kbt.io>
- * [r15418] shp2pgsql locale fixes are #3084, not #3048
+ * [r15418] NEWS, doc/release_notes.xml: shp2pgsql locale fixes are
+ #3084, not #3048
https://www.transifex.com/postgis/postgis/translate/#de/release_notesxmlpot/74993584/
@@ -943,14 +1245,15 @@
2017-05-04 18:01 Sandro Santilli <strk at kbt.io>
- * [r15388] Set RUNTESTFLAGS env variable locally
+ * [r15388] .drone.yml: Set RUNTESTFLAGS env variable locally
global env doesn't seem to work with Drone
2017-05-03 03:50 Regina Obe <lr at pcorp.us>
- * [r15383] @ operator not schema qualified and ~ not schema
- qualified in some places
+ * [r15383] NEWS, postgis/postgis.sql.in,
+ raster/rt_pg/rtpostgis.sql.in: @ operator not schema qualified
+ and ~ not schema qualified in some places
apply patch with adjustments. Patch provided by Shane StClair
(Axiom Data Science)
Closes #3750 for PostGIS 2.3.3
@@ -957,14 +1260,15 @@
2017-04-25 08:20 Regina Obe <lr at pcorp.us>
- * [r15368] revise ST_Subdivide regress to use ticket instead of
- github pull request
+ * [r15368] regress/subdivide.sql, regress/subdivide_expected:
+ revise ST_Subdivide regress to use ticket instead of github pull
+ request
References #3744 for PostGIS 2.3
2017-04-25 06:02 Regina Obe <lr at pcorp.us>
- * [r15365] PDF manual from dblatex renders fancy quotes for
- programlisting
+ * [r15365] NEWS, doc/Makefile.in, doc/texstyle.sty: PDF manual from
+ dblatex renders fancy quotes for programlisting
Change to use regular quotes
patch from Mike Toews
References #3726 for PostGIS 2.3
@@ -971,8 +1275,9 @@
2017-04-24 20:42 Regina Obe <lr at pcorp.us>
- * [r15364] ST_Subdivide loses subparts of inverted geometries patch
- from Darafei Praliaskouski (Komzpa)
+ * [r15364] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
+ regress/subdivide_expected: ST_Subdivide loses subparts of
+ inverted geometries patch from Darafei Praliaskouski (Komzpa)
Closes #3744 for PostGIS 2.3
changed area regress to cast to numeric so doesn't return
scientific notation on windows
@@ -979,29 +1284,36 @@
2017-04-23 20:34 Regina Obe <lr at pcorp.us>
- * [r15362] Get rid of logic that set out_srid to same as input srid
- and change to not try to transform when out_srid is unknown.
+ * [r15362] NEWS, raster/loader/raster2pgsql.c: Get rid of logic
+ that set out_srid to same as input srid and change to not try to
+ transform when out_srid is unknown.
Closes #3738 for PostGIS 2.3
2017-04-12 13:35 Sandro Santilli <strk at kbt.io>
- * [r15352] Fix drone build badge url
+ * [r15352] README.md: Fix drone build badge url
[ci skip]
2017-04-08 12:25 Regina Obe <lr at pcorp.us>
- * [r15348] Get rid of knn tests where multiple records have the
- same distances
+ * [r15348] regress/knn_recheck.sql, regress/knn_recheck_expected:
+ Get rid of knn tests where multiple records have the same
+ distances
references #3649 for 2.3
2017-04-04 17:40 Daniel Baston <dbaston at gmail.com>
- * [r15346] Fix error in docs for ST_ClusterDBSCAN
+ * [r15346] doc/reference_measure.xml: Fix error in docs for
+ ST_ClusterDBSCAN
2017-03-11 16:23 Sandro Santilli <strk at kbt.io>
- * [r15331] Fix azimuth computation for 2.5D edge ends
+ * [r15331] NEWS, liblwgeom/lwgeom_topo.c,
+ topology/test/regress/topogeo_addlinestring.sql,
+ topology/test/regress/topogeo_addlinestring_expected_newsnap,
+ topology/test/regress/topogeo_addlinestring_expected_oldsnap: Fix
+ azimuth computation for 2.5D edge ends
The change disreguard vertical movemements of the edge and
computes
@@ -1013,48 +1325,57 @@
2017-01-31 05:05 Regina Obe <lr at pcorp.us>
- * [r15303] Bump to next dev revision
+ * [r15303] Version.config, extensions/upgradeable_versions.mk: Bump
+ to next dev revision
2017-01-30 05:59 Regina Obe <lr at pcorp.us>
- * [r15301] Prep for PostGIS 2.3.2 release
+ * [r15301] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk: Prep
+ for PostGIS 2.3.2 release
2017-01-28 04:10 Regina Obe <lr at pcorp.us>
- * [r15295] Fix for 32-bit lwprint to support ST_AsLatLonText
+ * [r15295] liblwgeom/lwprint.c: Fix for 32-bit lwprint to support
+ ST_AsLatLonText
References #3688 for PostGIS 2.3.2
2017-01-25 23:42 Regina Obe <lr at pcorp.us>
- * [r15293] Turn off loading of tabblock by default. It's been
- broken since 2014
+ * [r15293] extras/tiger_geocoder/tiger_loader_2016.sql: Turn off
+ loading of tabblock by default. It's been broken since 2014
References #3898 for PostGIS 2.3
2017-01-22 07:44 Regina Obe <lr at pcorp.us>
- * [r15291] Fix for pg_upgrade of pg < 9.5 + 2.3+, pg_upgrade and
- doing a postgis micro update to latest stable.
+ * [r15291] postgis/geography.sql.in, postgis/geography_brin.sql.in,
+ postgis/postgis.sql.in, postgis/postgis_brin.sql.in: Fix for
+ pg_upgrade of pg < 9.5 + 2.3+, pg_upgrade and doing a postgis
+ micro update to latest stable.
closes #3683 for PostGIS 2.3
2017-01-18 21:07 Sandro Santilli <strk at kbt.io>
- * [r15289] ST_AsLatLonText: round minutes [2.3 backport]
+ * [r15289] NEWS, liblwgeom/cunit/cu_print.c, liblwgeom/lwprint.c:
+ ST_AsLatLonText: round minutes [2.3 backport]
Patch by Mike Toews, closes #3688
2017-01-07 08:52 Regina Obe <lr at pcorp.us>
- * [r15285] KNN recheck in 9.5+ fails with index returned tuples in
- wrong order
+ * [r15285] NEWS, postgis/gserialized_gist_2d.c,
+ regress/knn_recheck.sql, regress/knn_recheck_expected: KNN
+ recheck in 9.5+ fails with index returned tuples in wrong order
references #3418 for PostGIS 2.3
2017-01-06 10:31 Regina Obe <lr at pcorp.us>
- * [r15282] update news with latest 2 bug fixes
+ * [r15282] NEWS: update news with latest 2 bug fixes
2017-01-05 19:15 Regina Obe <lr at pcorp.us>
- * [r15280] Relationship functions not using an index in some cases
+ * [r15280] postgis/postgis.sql.in: Relationship functions not using
+ an index in some cases
Set cost back to 1 for functions that return a geometry
A higher cost has the side-effect of making the planner
think when used in conjunction with relate constructs like
@@ -1065,131 +1386,150 @@
2016-12-20 03:22 Regina Obe <lr at pcorp.us>
- * [r15278] PostGIS upgrade scripts missing GRANT for views
+ * [r15278] utils/postgis_proc_upgrade.pl: PostGIS upgrade scripts
+ missing GRANT for views
references #3680 for PostGIS 2.3
2016-12-03 22:32 Sandro Santilli <strk at kbt.io>
- * [r15270] Indent and style NEWS file
+ * [r15270] NEWS: Indent and style NEWS file
2016-12-03 20:39 Regina Obe <lr at pcorp.us>
- * [r15268] Cost on ST_SetSRID is preventing index use with relation
- functions. Change from 10 to 1.
+ * [r15268] postgis/postgis.sql.in: Cost on ST_SetSRID is preventing
+ index use with relation functions. Change from 10 to 1.
References #3675 for PostGIS 2.3
2016-11-28 15:10 Regina Obe <lr at pcorp.us>
- * [r15265] More minor corrections to HOW_TO_RELEASE, bump version
- to 2.3.2dev
+ * [r15265] HOWTO_RELEASE, Version.config,
+ extensions/upgradeable_versions.mk: More minor corrections to
+ HOW_TO_RELEASE, bump version to 2.3.2dev
2016-11-28 14:49 Regina Obe <lr at pcorp.us>
- * [r15263] More corrections to HOWTO_RELEASE, prepare for PostGIS
- 2.3.1 release
+ * [r15263] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ extensions/upgradeable_versions.mk: More corrections to
+ HOWTO_RELEASE, prepare for PostGIS 2.3.1 release
2016-11-26 21:49 Regina Obe <lr at pcorp.us>
- * [r15260] Add build badges, trunk vs. branch release
+ * [r15260] HOWTO_RELEASE: Add build badges, trunk vs. branch
+ release
closes #3671 for PostGIS 2.3
2016-11-26 19:54 Regina Obe <lr at pcorp.us>
- * [r15256] Mark ST_Extent, ST_Mem* aggregate functions parallel
- safe
+ * [r15256] NEWS, postgis/postgis.sql.in: Mark ST_Extent, ST_Mem*
+ aggregate functions parallel safe
closes #3650 for PostGIS 2.3.1
2016-11-26 16:39 Regina Obe <lr at pcorp.us>
- * [r15253] ST_DumpAsPolygons documentation confusing wrt no data
- value
+ * [r15253] doc/reference_raster.xml: ST_DumpAsPolygons
+ documentation confusing wrt no data value
closes #3512 for PostGIS 2.3.1
2016-11-26 15:19 Regina Obe <lr at pcorp.us>
- * [r15250] ST_Equals documentation does not describe current
- behavior
+ * [r15250] doc/reference_measure.xml: ST_Equals documentation does
+ not describe current behavior
closes #3566 for 2.3.1
2016-11-26 14:55 Regina Obe <lr at pcorp.us>
- * [r15246] Incorrect parameter name for CreateTopology
+ * [r15246] doc/extras_topology.xml: Incorrect parameter name for
+ CreateTopology
references #3509 for 2.3.1
2016-11-25 01:05 Regina Obe <lr at pcorp.us>
- * [r15245] add raster constraint max extent exceeds array size
- limit
+ * [r15245] NEWS, raster/rt_pg/rtpostgis.sql.in: add raster
+ constraint max extent exceeds array size limit
references #3501 for 2.3 (PostGIS 2.3.1)
2016-11-21 15:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15238] Change MSG line
+ * [r15238] configure.ac: Change MSG line
2016-11-17 08:01 Sandro Santilli <strk at kbt.io>
- * [r15235] Backport trunk changes in topology docs
+ * [r15235] doc/extras_topology.xml: Backport trunk changes in
+ topology docs
2016-11-15 23:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15231] OS guard 10.12 osx libxml fix
+ * [r15231] configure.ac: OS guard 10.12 osx libxml fix
2016-11-11 19:51 Regina Obe <lr at pcorp.us>
- * [r15228] add missing bug fix to list
+ * [r15228] NEWS: add missing bug fix to list
2016-11-11 19:42 Regina Obe <lr at pcorp.us>
- * [r15227] index corruption and memory leak in BRIN support
+ * [r15227] NEWS, doc/using_postgis_dataman.xml,
+ libpgcommon/gserialized_gist.c, libpgcommon/gserialized_gist.h,
+ postgis/brin_2d.c, postgis/brin_nd.c,
+ postgis/gserialized_gist_2d.c, postgis/gserialized_gist_nd.c,
+ regress/regress_brin_index.sql,
+ regress/regress_brin_index_3d.sql,
+ regress/regress_brin_index_3d_expected,
+ regress/regress_brin_index_expected: index corruption and memory
+ leak in BRIN support
Patch from Julien Rouhaud (Dalibo)
closes #3665 for PostGIS 2.3.1
2016-11-10 00:11 Regina Obe <lr at pcorp.us>
- * [r15222] Bug in geography ST_Segmentize
+ * [r15222] NEWS, liblwgeom/lwgeodetic.c, regress/geography.sql,
+ regress/geography_expected: Bug in geography ST_Segmentize
References #3667 for PostGIS 2.3.1
Patch provided by Hugo Mercier (Oslandia)
2016-10-30 22:30 Regina Obe <lr at pcorp.us>
- * [r15220] st_concavehull() returns sometimes empty geometry
- collection
+ * [r15220] NEWS, postgis/postgis.sql.in: st_concavehull() returns
+ sometimes empty geometry collection
references #1973 for PostGIS 2.3
2016-10-28 15:41 Sandro Santilli <strk at kbt.io>
- * [r15216] Update drone yml to 0.5 version
+ * [r15216] .drone.yml: Update drone yml to 0.5 version
See https://git.osgeo.org/gogs/sac/gogs-service/issues/14
2016-10-16 01:16 Regina Obe <lr at pcorp.us>
- * [r15209] raster GUC - boot_postgis_gdal_enabled_drivers should
- use TopMemoryContext instead of CurrentMemoryContext
+ * [r15209] raster/rt_pg/rtpostgis.c: raster GUC -
+ boot_postgis_gdal_enabled_drivers should use TopMemoryContext
+ instead of CurrentMemoryContext
References #3659 for 2.3 (PostGIS 2.3.4) patch provided by
manaeem
2016-10-10 20:24 Sandro Santilli <strk at kbt.io>
- * [r15202] Fix typo in error message about ClipByBox availability
+ * [r15202] liblwgeom/lwgeom_geos.c: Fix typo in error message about
+ ClipByBox availability
2016-10-10 19:46 Sandro Santilli <strk at kbt.io>
- * [r15198] Be verbose in running tests
+ * [r15198] .drone.yml: Be verbose in running tests
2016-10-08 09:11 Sandro Santilli <strk at kbt.io>
- * [r15194] Fix buildbot badges to point to 2.3 branch
+ * [r15194] README.md: Fix buildbot badges to point to 2.3 branch
See #3657
2016-10-07 20:17 Sandro Santilli <strk at kbt.io>
- * [r15191] Add missing upgrade checker
+ * [r15191] utils/check_all_upgrades.sh: Add missing upgrade checker
2016-10-07 20:05 Sandro Santilli <strk at kbt.io>
- * [r15190] Fix aggregates upgrade
+ * [r15190] .drone.yml, NEWS, postgis/postgis.sql.in: Fix aggregates
+ upgrade
Fixes #3656 (aggregate upgrades)
@@ -1197,43 +1537,49 @@
2016-10-06 17:31 Sandro Santilli <strk at kbt.io>
- * [r15179] Remove hard-coded version in Doxygen project name
+ * [r15179] doc/doxygen.cfg.in: Remove hard-coded version in Doxygen
+ project name
2016-10-03 20:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15168] #3652, Crash on collection(multicurve())
+ * [r15168] NEWS, liblwgeom/lwstroke.c: #3652, Crash on
+ collection(multicurve())
2016-09-27 22:55 Regina Obe <lr at pcorp.us>
- * [r15160]
+ * [r15160] README.postgis:
2016-09-27 08:12 Sandro Santilli <strk at kbt.io>
- * [r15157] Do not call printf from interrupt handler, fixing
- deadlocks
+ * [r15157] NEWS, postgis/postgis_module.c: Do not call printf from
+ interrupt handler, fixing deadlocks
Closes #3644 for 2.3 branch
2016-09-26 21:47 Regina Obe <lr at pcorp.us>
- * [r15153] PostGIS not building on latest OSX XCode
+ * [r15153] NEWS, configure.ac: PostGIS not building on latest OSX
+ XCode
References #3643 for PostGIS 2.3.1 (patch from pramsey)
2016-09-26 05:45 Regina Obe <lr at pcorp.us>
- * [r15148] bump up version to 2.3.1dev
+ * [r15148] Version.config, extensions/upgradeable_versions.mk: bump
+ up version to 2.3.1dev
2016-09-26 05:15 Regina Obe <lr at pcorp.us>
- * [r15145] fix typo in release notes
+ * [r15145] doc/release_notes.xml: fix typo in release notes
2016-09-26 04:45 Regina Obe <lr at pcorp.us>
- * [r15144] Get ready for PostGIS 2.3.0 launch
+ * [r15144] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk: Get
+ ready for PostGIS 2.3.0 launch
2016-09-26 03:26 Regina Obe <lr at pcorp.us>
- * [r15143] Branch 2.3 (trunk will become 2.4 after we are done)
+ * [r15143] .: Branch 2.3 (trunk will become 2.4 after we are done)
2016-09-25 09:19 Regina Obe <lr at pcorp.us>
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS 2019-08-11 03:56:02 UTC (rev 17690)
+++ branches/2.3/NEWS 2019-08-11 04:00:37 UTC (rev 17691)
@@ -1,5 +1,5 @@
PostGIS 2.3.10
-2019/XX/XX
+2019/08/XX
* Bug Fixes and Enhancements *
Modified: branches/2.3/Version.config
--- branches/2.3/Version.config 2019-08-11 03:56:02 UTC (rev 17690)
+++ branches/2.3/Version.config 2019-08-11 04:00:37 UTC (rev 17691)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=10dev
+POSTGIS_MICRO_VERSION=10
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.3/doc/release_notes.xml
--- branches/2.3/doc/release_notes.xml 2019-08-11 03:56:02 UTC (rev 17690)
+++ branches/2.3/doc/release_notes.xml 2019-08-11 04:00:37 UTC (rev 17691)
@@ -3,6 +3,23 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.3.10</title>
+ <para>Release date: 2019/08/11</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect>
+ <title>Bug Fixes and Enhancements</title>
+ <para>#4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)</para>
+ <para>#4326, Fix circular arc distance calculation (Paul Ramsey)</para>
+ <para>#4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)</para>
+ <para>#4327, Avoid pfree'ing the result of getenv (Raúl Marín)</para>
+ <para>#4406, Throw on invalid characters when decoding geohash (Raúl Marín)</para>
+ <para>#4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)</para>
+ <para>#4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)</para>
+ <para>#4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)</para>
+ <para>#4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.3.9</title>
<para>Release date: 2019/03/10</para>
