[postgis-tickets] r17693 - Prepare for release of PostGIS 2.4.8
Regina Obe
lr at pcorp.us
Sat Aug 10 09:20:40 PDT 2019
Author: robe
Date: 2019-08-10 21:20:40 -0700 (Sat, 10 Aug 2019)
New Revision: 17693
branches/2.4/ChangeLog
branches/2.4/NEWS
branches/2.4/Version.config
branches/2.4/doc/release_notes.xml
branches/2.4/extensions/upgradeable_versions.mk
Modified: branches/2.4/ChangeLog
--- branches/2.4/ChangeLog 2019-08-11 04:16:40 UTC (rev 17692)
+++ branches/2.4/ChangeLog 2019-08-11 04:20:40 UTC (rev 17693)
@@ -1,6 +1,196 @@
+2019-08-11 03:56 Regina Obe <lr at pcorp.us>
+ * [r17690] regress/in_geojson.sql, regress/in_geojson_expected:
+ Take out ST_GeomFromJSON - json, jsonb versions. These weren't
+ introduced until 2.5
+ Closes #4476
+2019-08-11 02:50 Regina Obe <lr at pcorp.us>
+ * [r17688] authors.git, authors.svn: Add Martin Davis to committer
+ list
+2019-08-11 01:44 Regina Obe <lr at pcorp.us>
+ * [r17686] NEWS, extensions/address_standardizer/Makefile.in,
+ extensions/upgrade-paths-rules.mk: Add upgrade install paths for
+ address_standardizer
+ references #4420 for PostGIS 2.4
+2019-08-04 07:39 Darafei Praliaskouski <me at komzpa.net>
+ * [r17670] NEWS, liblwgeom/lwin_geojson.c, regress/in_geojson.sql,
+ regress/in_geojson_expected: ST_GeomFromGeoJSON crash on empty
+ rings
+ Closes #4470
+2019-08-02 16:32 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17662] configure.ac: Fix minor version check issue in protobuf
+ configuration
+2019-08-01 17:48 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17657] NEWS, liblwgeom/lwout_twkb.c, regress/twkb.sql,
+ regress/twkb_expected: ST_AsTWKB doesn't always remove duplicate
+ points
+ References #4461
+2019-07-31 21:41 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17651] NEWS, loader/pgsql2shp-core.c, loader/shp2pgsql-core.c:
+ Handle POINT EMPTY in shape loader/dumper
+ References #4437
+2019-07-30 22:27 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17646] NEWS, configure.ac, postgis/Makefile.in,
+ postgis/geobuf.c, postgis/geobuf.h, postgis/lwgeom_out_geobuf.c,
+ postgis_config.h.in, regress/Makefile.in: Use protobuf version to
+ enable/disable mvt/geobuf
+ References #4419
+2019-07-29 16:45 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17642] NEWS, loader/pgsql2shp-core.c: Handle NULL geometry
+ values in pgsql2shp
+ References #4209
+2019-07-29 16:22 Sandro Santilli <strk at kbt.io>
+ * [r17637] .gitlab-ci.yml: [gitlab-ci] Be explicit about target
+ distribution (stretch)
+2019-07-29 15:33 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17633] NEWS, postgis/gserialized_estimate.c: Fix undefined
+ behaviour in _postgis_gserialized_stats
+ References #4466
+2019-07-16 08:58 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17607] libpgcommon/Makefile.in, loader/Makefile.in,
+ raster/loader/Makefile.in: Add CPPFLAGS where missing
+ Spotted by Debian's build log hardening checker, blhc.
+ https://salsa.debian.org/debian-gis-team/postgis/-/jobs/222378
+ Patch by Christoph Berg <myon -at- debian.org>
+2019-07-02 08:59 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17578] NEWS, postgis/lwgeom_btree.c: Fix bug in lwgeom_le
+ References #4445
+ Closes https://github.com/postgis/postgis/pull/428
+2019-06-28 18:03 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17569] NEWS, libpgcommon/lwgeom_pg.c, libpgcommon/lwgeom_pg.h,
+ libpgcommon/lwgeom_transform.c, postgis/geobuf.c, postgis/mvt.c:
+ Internal type lookups fail over FDW
+ Closes #4440
+2019-06-13 11:55 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17527] NEWS, liblwgeom/cunit/cu_algorithm.c,
+ liblwgeom/lwalgorithm.c: Throw on invalid characters when
+ decoding geohash
+ References #4406
+2019-06-13 07:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17524] NEWS, raster/rt_pg/rtpostgis.c: Avoid pfree'ing the
+ result of getenv
+ References #4327
+2019-06-12 14:04 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17515] .travis.yml: Travis: Use xenial as distribution and
+ bionic repos
+ References #4426
+2019-06-12 13:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17513] NEWS, raster/rt_pg/rtpostgis.sql.in,
+ raster/test/regress/tickets.sql,
+ raster/test/regress/tickets_expected: AddRasterConstraints:
+ Ignore NULLs when generating constraints
+ References #4388
+2019-06-06 10:20 Sandro Santilli <strk at kbt.io>
+ * [r17477] .drone-1.0.yml: [drone] 2.4 branch is not ready for
+ -Werror, drop that
+2019-06-06 10:01 Sandro Santilli <strk at kbt.io>
+ * [r17476] postgis/geography_centroid.c, postgis/lwgeom_sqlmm.c:
+ Fix a couple of warning about C99
+ Note: these are turned to error for some possibly
+ postgresql-injected
+ C flag, see https://dronie.osgeo.org/postgis/postgis/307/2/2
+2019-06-06 09:47 Sandro Santilli <strk at kbt.io>
+ * [r17475] .drone-1.0.yml: [dronie] fix yml syntax
+2019-06-06 08:04 Sandro Santilli <strk at kbt.io>
+ * [r17474] .drone-1.0.yml: [dronie] Add drone-1.0 configuration,
+ enabling 9.3 testing
+2019-04-12 22:16 Paul Ramsey <pramsey at cleverelephant.ca>
+ * [r17387] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: Circular string distances have some failure
+ modes, and test
+ suite should test everything bi-directionally.
+ References #4326
+2019-03-29 14:29 Raúl Marín Rodríguez <rmrodriguez at carto.com>
+ * [r17368] NEWS, postgis/postgis.sql.in,
+ regress/postgis_type_name.sql,
+ regress/postgis_type_name_expected: Fix postgis_type_name with
+ (GEOMETRYM,3)
+ Patch by Matt Bretl
+ References #4361
+2019-03-11 17:51 Regina Obe <lr at pcorp.us>
+ * [r17331] Version.config, extensions/upgradeable_versions.mk: Bump
+ to 2.4.8dev
+2019-03-11 14:24 Regina Obe <lr at pcorp.us>
+ * [r17325] Version.config: forgot to commit bump version
+2019-03-11 14:22 Regina Obe <lr at pcorp.us>
+ * [r17324] ChangeLog, NEWS, README.postgis, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk,
+ extras/tiger_geocoder/tables/lookup_tables_2011.sql: Prep for
+ PostGIS 2.4.7 release
+ Remove zcta5 geometry constraint
+ References #4086
2019-03-10 19:04 Regina Obe <lr at pcorp.us>
- * [r17322] Make _drop_raster_constraint_spatially_unique and
+ * [r17322] raster/rt_pg/rtpostgis.sql.in,
+ raster/test/regress/check_raster_columns.sql,
+ raster/test/regress/check_raster_columns_expected: Make
+ _drop_raster_constraint_spatially_unique and
_raster_constraint_info_spatially_unique allow for presence or
absense of schema qual on geometry cast.
Was failing before when installed as extension (but not by
@@ -9,31 +199,42 @@
2019-03-09 18:43 Regina Obe <lr at pcorp.us>
- * [r17315] Schema qualify all geometry casts in raster code,
- otherwise materialized views do not resture
+ * [r17315] NEWS, raster/rt_pg/rtpostgis.sql.in: Schema qualify all
+ geometry casts in raster code, otherwise materialized views do
+ not resture
Closes #4291 for PostGIS 2.4.7
2019-02-15 19:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17258] Update test running instructions
+ * [r17258] extras/ogc_test_suite/README: Update test running
+ instructions
2019-02-15 18:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17254] Update OGC certification scripts to match new SFSQL 1.2
- signatures
+ * [r17254] extras/ogc_test_suite/1_schema.sql,
+ extras/ogc_test_suite/2_queries.sql,
+ extras/ogc_test_suite/Makefile: Update OGC certification scripts
+ to match new SFSQL 1.2 signatures
2019-02-11 17:20 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17239] Add generated file
+ * [r17239] liblwgeom/lwin_wkt_lex.c: Add generated file
- * [r17238] Add lexer initialization
+ * [r17238] liblwgeom/lwin_wkt_lex.l: Add lexer initialization
References #4017
2019-01-31 15:51 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17225] PostgreSQL 12 compatibility
+ * [r17225] NEWS, libpgcommon/lwgeom_cache.c,
+ libpgcommon/lwgeom_cache.h,
+ postgis/geography_measurement_trees.c,
+ postgis/geography_measurement_trees.h,
+ postgis/gserialized_estimate.c, postgis/lwgeom_accum.c,
+ postgis/lwgeom_geos_prepared.c, postgis/lwgeom_geos_prepared.h,
+ postgis/lwgeom_rtree.c, postgis/lwgeom_rtree.h,
+ raster/rt_pg/rtpg_mapalgebra.c: PostgreSQL 12 compatibility
Initial patch by Laurenz Albe
Closes #4313
@@ -41,7 +242,8 @@
2019-01-22 09:07 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17205] Partially revert r17179
+ * [r17205] extensions/postgis_extension_helper.sql,
+ postgis/postgis.sql.in: Partially revert r17179
It changed the behaviour of _postgis_pgsql_version
Now uses the appropiate 5-6 digit version from server_version_num
@@ -51,80 +253,98 @@
2019-01-21 19:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17198] Sync generated files to parser file
+ * [r17198] liblwgeom/lwin_wkt_parse.c, liblwgeom/lwin_wkt_parse.h:
+ Sync generated files to parser file
2019-01-21 19:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17197] Put fix for parser into y file
+ * [r17197] liblwgeom/lwin_wkt_parse.y: Put fix for parser into y
+ file
References #4273
2019-01-18 20:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17187] Avoid final point duplicates for circle stroking
+ * [r17187] NEWS, liblwgeom/lwstroke.c: Avoid final point duplicates
+ for circle stroking
References #4283
2019-01-18 18:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17183] Geodetic tolerance issue in 32-bit
+ * [r17183] NEWS, liblwgeom/lwgeodetic.c: Geodetic tolerance issue
+ in 32-bit
References #4298
2019-01-18 17:24 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17179] Use `server_version_num` instead of parsing `version()`
+ * [r17179] NEWS, extensions/postgis_extension_helper.sql,
+ postgis/postgis.sql.in: Use `server_version_num` instead of
+ parsing `version()`
References #4296
2019-01-18 16:06 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17176] Avoid passing a NULL pointer to GEOSisEmpty
+ * [r17176] NEWS, liblwgeom/lwgeom_geos_clean.c,
+ liblwgeom/lwgeom_geos_cluster.c: Avoid passing a NULL pointer to
+ GEOSisEmpty
References #4275
2019-01-18 11:56 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17171] Correct issue reference from previous commit
+ * [r17171] NEWS: Correct issue reference from previous commit
References #4289
2019-01-18 11:52 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17169] ST_AsMVTGeom: Transform coordinates space before
- clipping
+ * [r17169] NEWS, postgis/mvt.c, regress/mvt.sql,
+ regress/mvt_expected: ST_AsMVTGeom: Transform coordinates space
+ before clipping
References #4300
2019-01-11 21:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17141] More robust geography distance
+ * [r17141] NEWS, liblwgeom/cunit/cu_tree.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic_tree.c, liblwgeom/lwgeodetic_tree.h,
+ postgis/geography_measurement_trees.c: More robust geography
+ distance
References #4290
2019-01-11 13:50 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17136] ST_AsMVT: parse JSON numeric values with decimals as
- doubles
+ * [r17136] NEWS, postgis/mvt.c, regress/mvt_jsonb.sql,
+ regress/mvt_jsonb_expected: ST_AsMVT: parse JSON numeric values
+ with decimals as doubles
Closes #4292
2019-01-10 18:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17133] Fix memory leak in case where valid WKT is
+ * [r17133] liblwgeom/lwin_wkt_parse.c: Fix memory leak in case
+ where valid WKT is
followed by garbage content
Closes #4273
2019-01-09 20:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17130] Tighter parsing of WKT
+ * [r17130] NEWS, liblwgeom/cunit/cu_in_wkt.c,
+ liblwgeom/cunit/cu_out_x3d.c, liblwgeom/lwin_wkt_parse.c,
+ postgis/lwgeom_ogc.c: Tighter parsing of WKT
References #4273
2018-12-26 04:08 Regina Obe <lr at pcorp.us>
- * [r17120] Fix so custom --with-projdir= configure switch works
- again.
+ * [r17120] configure.ac: Fix so custom --with-projdir= configure
+ switch works again.
References #4279 for PostGIS 2.4
2018-12-17 10:38 Darafei Praliaskouski <me at komzpa.net>
- * [r17110] Support Proj 6. Support is via legacy API.
+ * [r17110] NEWS, configure.ac, liblwgeom/liblwgeom.h.in,
+ macros/ac_proj4_version.m4, raster/macros/ac_proj4_version.m4:
+ Support Proj 6. Support is via legacy API.
Closes #4254
Closes https://github.com/postgis/postgis/pull/354
@@ -131,12 +351,17 @@
2018-11-27 00:15 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r17079] Change test conditions to explicit empty test
+ * [r17079] regress/tickets.sql, regress/tickets_expected: Change
+ test conditions to explicit empty test
References #4245
2018-11-25 19:32 Darafei Praliaskouski <me at komzpa.net>
- * [r17075] Stabilize GiST ND indexes for mixed dimensions
+ * [r17075] NEWS, postgis/gserialized_gist_nd.c,
+ regress/Makefile.in, regress/regress_gist_index_nd.data,
+ regress/regress_gist_index_nd.sql,
+ regress/regress_gist_index_nd_expected: Stabilize GiST ND indexes
+ for mixed dimensions
Patch by Darafei Praliaskouski
@@ -149,62 +374,74 @@
2018-11-24 05:35 Regina Obe <lr at pcorp.us>
- * [r17069] Flip to 2.4.7dev
+ * [r17069] Version.config, extensions/upgradeable_versions.mk: Flip
+ to 2.4.7dev
2018-11-24 05:31 Regina Obe <lr at pcorp.us>
- * [r17067] Prepping for 2.4.6 release and update docs to reflect
- 2.4 only supported up to PostgreSQL 10
+ * [r17067] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ Version.config, doc/installation.xml, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Prepping for 2.4.6 release
+ and update docs to reflect 2.4 only supported up to PostgreSQL 10
2018-11-22 16:15 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17057] Avoid unaligned memory access in BOX2D_out
+ * [r17057] NEWS, postgis/lwgeom_box.c: Avoid unaligned memory
+ access in BOX2D_out
References #4244
2018-11-22 13:41 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17051] Fix undefined behaviour in ST_3DDistance
+ * [r17051] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.h, liblwgeom/measures3d.c,
+ regress/measures.sql, regress/measures_expected: Fix undefined
+ behaviour in ST_3DDistance
References #4246
2018-11-21 14:11 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17041] Fix undefined behaviour in raster intersection
+ * [r17041] NEWS, raster/rt_core/rt_spatial_relationship.c: Fix
+ undefined behaviour in raster intersection
References #4249
2018-11-21 11:43 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17036] Avoid undefined behaviour in next_float functions (Raúl
- Marín)
+ * [r17036] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/lwgeom_api.c: Avoid undefined behaviour in next_float
+ functions (Raúl Marín)
References #4247
2018-11-15 16:07 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17020] Avoid undefined behaviour in gserialized_estimate
+ * [r17020] NEWS, postgis/gserialized_estimate.c: Avoid undefined
+ behaviour in gserialized_estimate
References #4190
2018-11-15 09:06 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r17017] Allocate enough memory in gidx_to_string
+ * [r17017] NEWS, libpgcommon/gserialized_gist.c: Allocate enough
+ memory in gidx_to_string
References #4236
2018-11-07 15:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16990] Honestly, spaces?
+ * [r16990] liblwgeom/lwgeodetic.h: Honestly, spaces?
2018-11-06 22:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16986] Add name to NEWS
+ * [r16986] NEWS: Add name to NEWS
2018-11-05 22:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16979] Patch over bad behaviour for near-parallel boxes and
- distancetree.
+ * [r16979] liblwgeom/cunit/cu_geodetic.c,
+ liblwgeom/cunit/cu_tree.c, liblwgeom/lwgeodetic.h: Patch over bad
+ behaviour for near-parallel boxes and distancetree.
Unfortunately, this "fix" is probably breakable, just put the
boxes closer and closer together until we get "close enough to be
the same" results from the edge normal comparison again. Only way
@@ -216,35 +453,48 @@
2018-11-05 18:27 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16978] Remove clang warnings
+ * [r16978] postgis/lwgeom_geos.c, postgis/lwgeom_window.c,
+ raster/rt_pg/rtpg_mapalgebra.c, raster/rt_pg/rtpostgis.c: Remove
+ clang warnings
2018-11-05 17:57 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16977] Proper repeated point removal for small polygons
+ * [r16977] NEWS, liblwgeom/ptarray.c: Proper repeated point removal
+ for small polygons
Closes #4136
2018-11-01 19:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16972] Update NEWS for #2416
+ * [r16972] NEWS: Update NEWS for #2416
2018-11-01 19:40 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16971] Remove use of variable length arrays
+ * [r16971] NEWS, raster/rt_pg/rtpg_band_properties.c,
+ raster/rt_pg/rtpg_gdal.c, raster/rt_pg/rtpg_geometry.c,
+ raster/rt_pg/rtpg_mapalgebra.c, raster/rt_pg/rtpg_pixel.c,
+ raster/rt_pg/rtpg_raster_properties.c,
+ raster/rt_pg/rtpg_statistics.c: Remove use of variable length
+ arrays
References #4177
2018-11-01 19:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16970] Remove use of VLA from geography centroid
+ * [r16970] postgis/geography_centroid.c: Remove use of VLA from
+ geography centroid
References #4059
2018-10-31 22:02 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16969] Revert change to avoid slicing on box access.
+ * [r16969] liblwgeom/g_serialized.c, postgis/gserialized_gist_2d.c:
+ Revert change to avoid slicing on box access.
References #4216
2018-10-24 14:04 Darafei Praliaskouski <me at komzpa.net>
- * [r16948] [raster] Use GDALFPolygonize unconditionally
+ * [r16948] .gitignore, NEWS, configure.ac, postgis_config.h.in,
+ raster/raster_config.h.in, raster/rt_core/rt_geometry.c,
+ raster/test/cunit/cu_gdal.c: [raster] Use GDALFPolygonize
+ unconditionally
GDAL 1.10 is already required and 1.9 contains it, so no check
needed.
@@ -253,7 +503,8 @@
2018-10-23 13:05 Darafei Praliaskouski <me at komzpa.net>
- * [r16942] [raster] Fix envelope Contains shortcut in ST_Clip
+ * [r16942] NEWS, raster/rt_pg/rtpostgis.sql.in: [raster] Fix
+ envelope Contains shortcut in ST_Clip
Patch by Sai-bot
@@ -261,7 +512,8 @@
2018-10-17 14:27 Sandro Santilli <strk at kbt.io>
- * [r16919] Fix support for PostgreSQL-12 ("getrelid" macro removed)
+ * [r16919] NEWS, postgis/gserialized_estimate.c: Fix support for
+ PostgreSQL-12 ("getrelid" macro removed)
The call is replaced with its expansion which should work
as back as PostgreSQL-9.1 which is before the oldest version
@@ -275,30 +527,34 @@
2018-10-15 11:47 Sandro Santilli <strk at kbt.io>
- * [r16911] Only drop function IF EXISTS ...
+ * [r16911] topology/topology_drop_before.sql.in: Only drop function
+ IF EXISTS ...
2018-10-15 11:31 Sandro Santilli <strk at kbt.io>
- * [r16906] [topology] properly drop removed internal functions on
- upgrade
+ * [r16906] NEWS, topology/topology_drop_before.sql.in: [topology]
+ properly drop removed internal functions on upgrade
References #4202 in 2.4 branch
2018-10-02 11:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16869] Fix undefined behaviour in ptarray_clone_deep
+ * [r16869] NEWS, liblwgeom/ptarray.c: Fix undefined behaviour in
+ ptarray_clone_deep
References #4191
2018-10-02 09:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16864] Fix undefined behaviour in SADFWrite
+ * [r16864] NEWS, loader/safileio.c: Fix undefined behaviour in
+ SADFWrite
References #4189
2018-10-01 13:44 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16858] St_AsMVTGeom: Drop invalid geometries after
+ * [r16858] NEWS, postgis/mvt.c, regress/mvt.sql,
+ regress/mvt_expected: St_AsMVTGeom: Drop invalid geometries after
simplification
Closes #4183
@@ -305,90 +561,110 @@
2018-09-24 10:06 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16839] St_AsMVTGeom: Avoid type changes due to validation
+ * [r16839] NEWS, postgis/mvt.c, regress/mvt.sql,
+ regress/mvt_expected: St_AsMVTGeom: Avoid type changes due to
+ validation
Closes #4181
2018-09-16 03:51 Regina Obe <lr at pcorp.us>
- * [r16804] Change windows to build and regress against geos 3.7.0
+ * [r16804] ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh:
+ Change windows to build and regress against geos 3.7.0
2018-09-14 18:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16803] rt_pg: Fix build issue with LVM jit
+ * [r16803] raster/rt_pg/Makefile.in: rt_pg: Fix build issue with
+ LVM jit
References #4094
2018-09-14 15:38 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16800] Use qualified names in topology extension install
+ * [r16800] NEWS,
+ extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in:
+ Use qualified names in topology extension install
References #4160
2018-09-13 20:38 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16787] Handle almost-infinite features when building table
- statistics in ANALYZE
+ * [r16787] postgis/gserialized_estimate.c, regress/tickets.sql,
+ regress/tickets_expected: Handle almost-infinite features when
+ building table statistics in ANALYZE
References #4144
2018-09-13 19:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16783] Avoid array overflow in ANALYZE (References #2985)
+ * [r16783] postgis/gserialized_estimate.c: Avoid array overflow in
+ ANALYZE (References #2985)
2018-09-13 13:34 Sandro Santilli <strk at kbt.io>
- * [r16774] Typo fix
+ * [r16774] NEWS: Typo fix
[ci skip]
2018-09-12 16:50 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16766] Push version number forward one
+ * [r16766] NEWS, Version.config: Push version number forward one
2018-09-12 16:39 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16765] Change warning message
+ * [r16765] configure.ac: Change warning message
2018-09-12 16:22 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16762] Preparation for 2.4.5 release
+ * [r16762] Version.config: Preparation for 2.4.5 release
- * [r16761] Preparation for 2.4.5 release
+ * [r16761] ChangeLog, NEWS, README.postgis, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Preparation for 2.4.5 release
2018-08-29 09:17 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16708] MVT: Fix resource leak when the first geometry is NULL
+ * [r16708] NEWS, postgis/mvt.c: MVT: Fix resource leak when the
+ first geometry is NULL
References #4163
2018-07-24 20:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16669] Ensure index filters on expanded boxes are large enough
- to encompass
+ * [r16669] NEWS, postgis/geography_measurement.c,
+ regress/tickets.sql, regress/tickets_expected: Ensure index
+ filters on expanded boxes are large enough to encompass
the radii they are searching, references #4081
2018-07-24 13:34 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16666] Revert mistaken commit of lexer generated file
+ * [r16666] liblwgeom/lwin_wkt_lex.c: Revert mistaken commit of
+ lexer generated file
2018-07-24 13:33 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16665] Better parallel build, closes #4105
+ * [r16665] NEWS, extensions/address_standardizer/Makefile.in,
+ extensions/postgis/Makefile.in,
+ extensions/postgis_tiger_geocoder/Makefile.in,
+ extensions/postgis_topology/Makefile.in,
+ liblwgeom/lwin_wkt_lex.c: Better parallel build, closes #4105
2018-07-24 13:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16664] Harmonize doco with existing behaviour
+ * [r16664] doc/reference_accessor.xml: Harmonize doco with existing
+ behaviour
2018-07-04 21:20 Regina Obe <lr at pcorp.us>
- * [r16635] reenable sfcgal tests for debbie.
+ * [r16635] ci/debbie/postgis_regress.sh: reenable sfcgal tests for
+ debbie.
Closes #4068 for PostGIS 2.4
2018-06-15 22:23 Sandro Santilli <strk at kbt.io>
- * [r16619] Fix infinite loop in linearization of a big radius small
- arc
+ * [r16619] NEWS, liblwgeom/cunit/cu_lwstroke.c,
+ liblwgeom/lwstroke.c: Fix infinite loop in linearization of a big
+ radius small arc
Closes #4058 in 2.4 branch (2.4.5dev)
Includes unit test
@@ -395,32 +671,36 @@
2018-06-13 14:53 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16617] Travis: Install all required dependencies for MVT tests
+ * [r16617] .travis.yml: Travis: Install all required dependencies
+ for MVT tests
Closes #4106
2018-06-12 12:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16613] Fix flags in case where a boxless geom comes in with a
- "has box" set of flags.
+ * [r16613] liblwgeom/g_serialized.c: Fix flags in case where a
+ boxless geom comes in with a "has box" set of flags.
References #4077
2018-05-23 09:40 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16590] Trailing blank
+ * [r16590] liblwgeom/measures.c: Trailing blank
2018-05-23 09:30 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16588] Avoid segfault in median test (32bits)
+ * [r16588] liblwgeom/lwgeom_median.c: Avoid segfault in median test
+ (32bits)
2018-05-22 19:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16584] Inconsistent results from qsort callback (yugr)
+ * [r16584] NEWS, liblwgeom/effectivearea.c, liblwgeom/measures.c:
+ Inconsistent results from qsort callback (yugr)
References #4093
2018-05-21 10:59 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16579] Fix bug in lwgeom_median and avoid division by zero
+ * [r16579] NEWS, liblwgeom/lwgeom_median.c: Fix bug in
+ lwgeom_median and avoid division by zero
References #3997
Closes https://github.com/postgis/postgis/pull/244
@@ -427,7 +707,8 @@
2018-05-21 10:41 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16578] Fix PG 9.5 build in 2.4
+ * [r16578] NEWS, extensions/address_standardizer/std_pg_hash.c,
+ libpgcommon/lwgeom_transform.c: Fix PG 9.5 build in 2.4
References #4090
Applies the same fix as #3950
@@ -435,8 +716,9 @@
2018-05-20 14:46 Sandro Santilli <strk at kbt.io>
- * [r16577] Survive to big max deviation values passed to
- ST_CurveToLine
+ * [r16577] NEWS, liblwgeom/cunit/cu_lwstroke.c,
+ liblwgeom/lwstroke.c: Survive to big max deviation values passed
+ to ST_CurveToLine
When using "max-deviation" tolerance type, passing a tolerance
bigger than twice the radius of any arc resulted in entering
@@ -450,7 +732,13 @@
2018-05-18 09:10 Raúl Marín Rodríguez <rmrodriguez at carto.com>
- * [r16576] Backport PG 11 compatibility
+ * [r16576] .gitignore,
+ extensions/address_standardizer/std_pg_hash.c,
+ libpgcommon/lwgeom_transform.c, postgis/Makefile.in,
+ raster/test/regress/check_gdal.sql,
+ raster/test/regress/check_gdal_expected: Backport PG 11
+ compatibility
Closes #4090
Closes https://github.com/postgis/postgis/pull/242
@@ -457,139 +745,164 @@
2018-05-16 21:38 Nicklas Avén <nicklas.aven at jordogskog.no>
- * [r16573] Fixes bounding box handling in twkb_input #4089
+ * [r16573] liblwgeom/lwin_twkb.c, regress/tickets.sql,
+ regress/tickets_expected: Fixes bounding box handling in
+ twkb_input #4089
2018-05-07 18:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16564] Delay freeing input until processing is complete. From
- lucasvr.
+ * [r16564] NEWS, postgis/lwgeom_sfcgal.c: Delay freeing input until
+ processing is complete. From lucasvr.
Closes #3980
2018-05-07 18:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16562] Emit a cancellation error code on GEOS
- interruptedExceptions, for consistency
+ * [r16562] NEWS, postgis/lwgeom_geos.c: Emit a cancellation error
+ code on GEOS interruptedExceptions, for consistency
with internal interruptions.
Closes #4070
2018-05-07 18:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16559] Update NEWS re #4079
+ * [r16559] NEWS: Update NEWS re #4079
2018-05-07 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16558] ensure that polygons are CW coming out of the ASMVTGEOM
- process
+ * [r16558] postgis/mvt.c: ensure that polygons are CW coming out of
+ the ASMVTGEOM process
Closes #4079
2018-04-21 13:20 Darafei Praliaskouski <me at komzpa.net>
- * [r16550] ST_ClusterKMeans crash on NULL and EMPTY
+ * [r16550] NEWS, liblwgeom/lwkmeans.c, regress/lwgeom_regress.sql,
+ regress/lwgeom_regress_expected: ST_ClusterKMeans crash on NULL
+ and EMPTY
Closes #4071
2018-04-16 17:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16543] Guard against lookup failure, to avoid segfault in
- internally called case (closes #4067)
+ * [r16543] NEWS, libpgcommon/lwgeom_transform.c: Guard against
+ lookup failure, to avoid segfault in internally called case
+ (closes #4067)
2018-04-10 02:34 Regina Obe <lr at pcorp.us>
- * [r16536] Disable sfcgal in make dist
+ * [r16536] ci/debbie/postgis_make_dist.sh: Disable sfcgal in make
+ dist
References #4068 for PostGIS 2.4
2018-04-10 02:31 Regina Obe <lr at pcorp.us>
- * [r16535] Disable sfcgal testing until sfcgal 1.3.3 / CGAL 4.11
- issue is resolved.
+ * [r16535] ci/debbie/postgis_regress.sh: Disable sfcgal testing
+ until sfcgal 1.3.3 / CGAL 4.11 issue is resolved.
2018-04-09 17:26 Regina Obe <lr at pcorp.us>
- * [r16534] revise debbie to build against master sfcgal
+ * [r16534] ci/debbie/postgis_regress.sh: revise debbie to build
+ against master sfcgal
2018-04-09 15:11 Regina Obe <lr at pcorp.us>
- * [r16533] missed some spots where source_folder variable is used
+ * [r16533] ci/winnie/build_postgis.sh,
+ ci/winnie/package_postgis.sh: missed some spots where
+ source_folder variable is used
2018-04-09 01:41 Regina Obe <lr at pcorp.us>
- * [r16532] switch to test against GEOS 3.6.2
+ * [r16532] ci/winnie/regress_postgis.sh: switch to test against
+ GEOS 3.6.2
2018-04-06 09:06 Regina Obe <lr at pcorp.us>
- * [r16529] fix path setting
+ * [r16529] ci/winnie/regress_postgis.sh: fix path setting
2018-04-06 05:21 Regina Obe <lr at pcorp.us>
- * [r16527] Flip version to 2.4.5dev, revise winnie to be able to
- use source_folder if passed in (will allow tagged builds to be
- built from dev branch for testing)
+ * [r16527] Version.config, ci/winnie/build_postgis.sh,
+ ci/winnie/regress_postgis.sh, extensions/upgradeable_versions.mk:
+ Flip version to 2.4.5dev, revise winnie to be able to use
+ source_folder if passed in (will allow tagged builds to be built
+ from dev branch for testing)
2018-04-02 06:54 Regina Obe <lr at pcorp.us>
- * [r16520] fix date typo in release notes
+ * [r16520] doc/release_notes.xml: fix date typo in release notes
- * [r16519] Fix typo in release notes
+ * [r16519] doc/release_notes.xml: Fix typo in release notes
2018-04-02 04:57 Regina Obe <lr at pcorp.us>
- * [r16517] Update in prep for 2.4.7
+ * [r16517] ChangeLog, HOWTO_RELEASE, NEWS, README.postgis,
+ Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Update in prep for 2.4.7
2018-03-28 08:53 Regina Obe <lr at pcorp.us>
- * [r16504] Fix crasher in raster when fed an empty raster (note was
- tempted to change the def of empty raster to include raster with
- no bands but not sure where else that is used, so just revised
- the clip check to not try to clip if no bands).
+ * [r16504] NEWS, doc/reference_raster.xml,
+ raster/rt_pg/rtpg_mapalgebra.c, raster/test/regress/tickets.sql,
+ raster/test/regress/tickets_expected: Fix crasher in raster when
+ fed an empty raster (note was tempted to change the def of empty
+ raster to include raster with no bands but not sure where else
+ that is used, so just revised the clip check to not try to clip
+ if no bands).
References #3055 for PostGIS 2.4.4,
also minor doc fix references #2925 for PostGIS 2.4.4
2018-03-27 17:36 Darafei Praliaskouski <me at komzpa.net>
- * [r16500] ST_CPAWithin precision fix
+ * [r16500] NEWS, liblwgeom/lwlinearreferencing.c: ST_CPAWithin
+ precision fix
Closes #4032
2018-03-25 03:33 Regina Obe <lr at pcorp.us>
- * [r16498] upgrade support for PostgreSQL 11
+ * [r16498] NEWS, extensions/postgis_extension_helper.sql: upgrade
+ support for PostgreSQL 11
closes #4044 for PostGIS 2.4.4
2018-03-24 03:01 Regina Obe <lr at pcorp.us>
- * [r16496] change sorting of tickets to be nuermic by ticket
+ * [r16496] NEWS: change sorting of tickets to be nuermic by ticket
number. Add in missing tickets
2018-03-24 02:17 Regina Obe <lr at pcorp.us>
- * [r16495] note in docs about soft upgrade that legacy.sql must be
- rerun for each minor.
+ * [r16495] doc/installation.xml: note in docs about soft upgrade
+ that legacy.sql must be rerun for each minor.
Closes #2960 for PostGIS 2.4.4
2018-03-24 00:00 Daniel Baston <dbaston at gmail.com>
- * [r16491] Avoid dropping SRID in ST_ClusterIntersecting
+ * [r16491] liblwgeom/lwgeom_geos_cluster.c, regress/tickets.sql,
+ regress/tickets_expected: Avoid dropping SRID in
+ ST_ClusterIntersecting
References #4055
2018-03-23 06:35 Regina Obe <lr at pcorp.us>
- * [r16484] change to use GDAL 2.2.4, 3.6.2 (for packaging) but keep
- 3.7.0dev for regress testing
+ * [r16484] ci/winnie/build_postgis.sh,
+ change to use GDAL 2.2.4, 3.6.2 (for packaging) but keep 3.7.0dev
+ for regress testing
2018-03-23 00:09 Regina Obe <lr at pcorp.us>
- * [r16482] schema qualify geography functions (including ST_Buffer)
+ * [r16482] NEWS, postgis/geography.sql.in: schema qualify geography
+ functions (including ST_Buffer)
References #4052 for PostGIS 2.4.4
2018-03-18 22:43 Regina Obe <lr at pcorp.us>
- * [r16477] Seems sometimes the postgis_svn_revision.h gets wiped
- out, so end up with no svn number.
+ * [r16477] ci/debbie/postgis_release_docs.sh: Seems sometimes the
+ postgis_svn_revision.h gets wiped out, so end up with no svn
+ number.
Explicitly call svn_repo_revision.pl to ensure we have an svn
number to read
References #4047 for PostGIS 2.4
@@ -596,42 +909,44 @@
2018-03-18 09:10 Regina Obe <lr at pcorp.us>
- * [r16474] this for sure will fix revision # this time I tested
- before hand
+ * [r16474] ci/debbie/postgis_release_docs.sh: this for sure will
+ fix revision # this time I tested before hand
2018-03-18 05:16 Regina Obe <lr at pcorp.us>
- * [r16472] variable typo
+ * [r16472] ci/debbie/postgis_release_docs.sh: variable typo
2018-03-18 05:12 Regina Obe <lr at pcorp.us>
- * [r16470] Add logic to show git log timestamp in UTC instead of
- Unix timestamp and put in svn revision number
+ * [r16470] ci/debbie/postgis_release_docs.sh: Add logic to show git
+ log timestamp in UTC instead of Unix timestamp and put in svn
+ revision number
2018-02-26 20:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16425] Update lexer generated file
+ * [r16425] liblwgeom/lwin_wkt_lex.c: Update lexer generated file
References #4017
2018-02-26 20:03 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16424] Fix memory corruption in case where lexer is interrupted
- mid-process
+ * [r16424] NEWS, liblwgeom/lwin_wkt_lex.l: Fix memory corruption in
+ case where lexer is interrupted mid-process
References #4017
For 2.4 branch
2018-02-26 18:25 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16420] Use more precise bounds when testing overlap of temporal
- ranges.
+ * [r16420] NEWS, liblwgeom/lwlinearreferencing.c: Use more precise
+ bounds when testing overlap of temporal ranges.
For 2.4, references #4025
2018-02-25 14:54 Sandro Santilli <strk at kbt.io>
- * [r16417] Do not include private header for json-c >= 0.13
+ * [r16417] NEWS, liblwgeom/lwin_geojson.c: Do not include private
+ header for json-c >= 0.13
Patch by Björn Esser
@@ -641,7 +956,8 @@
2018-02-22 11:13 Darafei Praliaskouski <me at komzpa.net>
- * [r16406] Fix cast from box3d to geometry
+ * [r16406] NEWS, postgis/lwgeom_box3d.c, regress/regress_expected,
+ regress/sfcgal/regress_expected: Fix cast from box3d to geometry
Patch by Matthias Bay
@@ -650,39 +966,44 @@
2018-02-21 14:31 Sandro Santilli <strk at kbt.io>
- * [r16401] [gitlab-ci] Switch to PostgreSQL 9.6 and libjson-c-dev
+ * [r16401] .gitlab-ci.yml: [gitlab-ci] Switch to PostgreSQL 9.6 and
+ libjson-c-dev
Fixes gitlab-ci build for 2.4, references #4023
2018-02-21 09:05 Sandro Santilli <strk at kbt.io>
- * [r16399] Lowercase Algunenano
+ * [r16399] authors.git, authors.svn: Lowercase Algunenano
All LDAP account names are lowercase
2018-02-20 22:38 Regina Obe <lr at pcorp.us>
- * [r16398] Add Raúl Marín Rodríguez to developers list
+ * [r16398] authors.git, authors.svn: Add Raúl Marín Rodríguez to
+ developers list
2018-02-20 22:35 Regina Obe <lr at pcorp.us>
- * [r16397] backport regress changes from 2.5
+ * [r16397] ci/winnie/build_postgis.sh,
+ backport regress changes from 2.5
2018-01-26 14:55 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16362] lwpoly_construct_circle: Avoid division by zero (Raúl
- Marín Rodríguez)
+ * [r16362] NEWS, liblwgeom/lwpoly.c: lwpoly_construct_circle: Avoid
+ division by zero (Raúl Marín Rodríguez)
References #4003
2018-01-26 12:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16361] Avoid memory exhaustion when building a btree index
- (references #4004)
+ * [r16361] NEWS, postgis/geography_btree.c: Avoid memory exhaustion
+ when building a btree index (references #4004)
From Edmund Horner
2018-01-22 14:15 Sandro Santilli <strk at kbt.io>
- * [r16358] Set availability of support function for KNN index
+ * [r16358] NEWS, postgis/geography.sql.in: Set availability of
+ support function for KNN index
Fixes upgrade from 2.1 to 2.2+
Closes #3978 in 2.4 branch (2.4.4)
@@ -689,8 +1010,8 @@
2018-01-22 12:35 Sandro Santilli <strk at kbt.io>
- * [r16353] [drone] Use trisquel2 image, test all pgsql versions and
- upgrades
+ * [r16353] .drone.yml: [drone] Use trisquel2 image, test all pgsql
+ versions and upgrades
The new docker image also uses newer GEOS (3.6.2).
References #3813 for 2.4 branch
@@ -698,35 +1019,39 @@
2018-01-22 11:30 Sandro Santilli <strk at kbt.io>
- * [r16350] backport run_test.pl fixes from trunk
+ * [r16350] regress/run_test.pl: backport run_test.pl fixes from
+ trunk
2018-01-21 07:12 Regina Obe <lr at pcorp.us>
- * [r16347] change scripts back to versions of things to compile
- against (GDAL, PROJ, SCGAL, GEOS) being set at job level until we
- have the stop and start postgres in repo as well.
+ * [r16347] ci/winnie/build_postgis.sh,
+ change scripts back to versions of things to compile against
+ (GDAL, PROJ, SCGAL, GEOS) being set at job level until we have
+ the stop and start postgres in repo as well.
2018-01-20 12:58 Sandro Santilli <strk at kbt.io>
- * [r16346] Have Debbie test all available upgrades
+ * [r16346] ci/debbie/postgis_regress.sh: Have Debbie test all
+ available upgrades
References #2676 for 2.4 branch
2018-01-18 21:46 Sandro Santilli <strk at kbt.io>
- * [r16336] Forgot to add pkg.m4 macro in r16324
+ * [r16336] macros/pkg.m4: Forgot to add pkg.m4 macro in r16324
See #3992
2018-01-17 23:23 Regina Obe <lr at pcorp.us>
- * [r16328] Move PgSQL 11 support note to 2.4.4
+ * [r16328] NEWS: Move PgSQL 11 support note to 2.4.4
It was put in after 2.4.3 was already tagged and tarred.
2018-01-16 20:54 Sandro Santilli <strk at kbt.io>
- * [r16325] Use PKG_PROG_PKG_CONFIG macro from pkg.m4 to detect
- pkg-config
+ * [r16325] NEWS, configure.ac: Use PKG_PROG_PKG_CONFIG macro from
+ pkg.m4 to detect pkg-config
Patch by Bas Couwenberg
Closes #3992 in 2.4 branch (for 2.4.4)
@@ -733,58 +1058,72 @@
2018-01-16 14:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16321] Updates news re pg11 support
+ * [r16321] NEWS: Updates news re pg11 support
2018-01-16 14:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16320] Backport support for Pg11 to 2.4 branch. Closes #3946
+ * [r16320] libpgcommon/lwgeom_pg.h, libpgcommon/lwgeom_transform.c,
+ postgis/lwgeom_geos_prepared.c: Backport support for Pg11 to 2.4
+ branch. Closes #3946
2018-01-16 07:06 Regina Obe <lr at pcorp.us>
- * [r16315] flip version to 2.4.4dev, add 2.4.3 to upgrade versions
+ * [r16315] Version.config, ci/debbie/postgis_doc_translations.sh,
+ ci/debbie/postgis_make_dist.sh,
+ ci/debbie/postgis_release_docs.sh,
+ extensions/upgradeable_versions.mk: flip version to 2.4.4dev, add
+ 2.4.3 to upgrade versions
add timestamp to dev docs
closes #3991 for PostGIS 2.4.4dev
2018-01-15 21:38 Regina Obe <lr at pcorp.us>
- * [r16305] Get rid of SVN number and revise to not build local html
- except for trunk
+ * [r16305] ci/debbie/postgis_release_docs.sh: Get rid of SVN number
+ and revise to not build local html except for trunk
2018-01-15 20:47 Regina Obe <lr at pcorp.us>
- * [r16301] more clearifying notes on HOWTO_RELEASE
+ * [r16301] HOWTO_RELEASE, Version.config: more clearifying notes on
+ HOWTO_RELEASE
change version to 2.4.3 in prep for tagging tomorrow or
Wednesday.
2018-01-15 00:50 Regina Obe <lr at pcorp.us>
- * [r16299] update ChangeLog
+ * [r16299] ChangeLog, Version.config,
+ ci/debbie/postgis_make_dist.sh: update ChangeLog
flip Version.config to rc2
revise make dist to output branch reading from
2018-01-15 00:24 Regina Obe <lr at pcorp.us>
- * [r16298] with_interrupt_tests using non-standard extension
+ * [r16298] NEWS, configure.ac, doc/release_notes.xml:
+ with_interrupt_tests using non-standard extension
Closes #3988 for PostGIS 2.4.3
2018-01-14 15:42 Regina Obe <lr at pcorp.us>
- * [r16294] in prep for release Wednesday, flip back to dev, stamp
- expected date of release in news
+ * [r16294] NEWS, Version.config,
+ extensions/upgradeable_versions.mk: in prep for release
+ Wednesday, flip back to dev, stamp expected date of release in
+ news
Add 2.3.6 upgrade path
2018-01-14 15:35 Regina Obe <lr at pcorp.us>
- * [r16292] fix missed edit.
+ * [r16292] HOWTO_RELEASE: fix missed edit.
References #3985 for PostGIS 2.4
2018-01-13 19:24 Regina Obe <lr at pcorp.us>
- * [r16289] Change release version to 2.4.3rc1
+ * [r16289] Version.config, doc/release_notes.xml: Change release
+ version to 2.4.3rc1
2018-01-13 19:20 Regina Obe <lr at pcorp.us>
- * [r16288] fix typo in make_dist.sh
+ * [r16288] HOWTO_RELEASE, ci/debbie/postgis_make_dist.sh,
+ ci/debbie/postgis_release_docs.sh, make_dist.sh: fix typo in
+ make_dist.sh
Add doc building,
update How To release to reflect tar ball and docs start building
as soon as work is committed.
@@ -792,51 +1131,60 @@
2018-01-13 18:01 Regina Obe <lr at pcorp.us>
- * [r16284] revise make_dist.sh to allow overriding the package
- name, and create debbie make dist script that calls the main one
+ * [r16284] ci/debbie/postgis_make_dist.sh, make_dist.sh: revise
+ make_dist.sh to allow overriding the package name, and create
+ debbie make dist script that calls the main one
2018-01-13 06:05 Regina Obe <lr at pcorp.us>
- * [r16280] fix typo in release version it's 2.4.3 not 2.4.8
+ * [r16280] doc/release_notes.xml: fix typo in release version it's
+ 2.4.3 not 2.4.8
2018-01-13 05:56 Regina Obe <lr at pcorp.us>
- * [r16279] Add release notes to docs in prep for release. Minor
- reword in NEWs
+ * [r16279] NEWS, doc/release_notes.xml: Add release notes to docs
+ in prep for release. Minor reword in NEWs
2018-01-12 16:50 Regina Obe <lr at pcorp.us>
- * [r16277] revert setting GDAL and GEOS, forgot pg launch script
- needs these which we don't have in repo. Turn on DUMP_RESTORE
- testing
+ * [r16277] ci/debbie/postgis_regress.sh: revert setting GDAL and
+ GEOS, forgot pg launch script needs these which we don't have in
+ repo. Turn on DUMP_RESTORE testing
2018-01-12 16:18 Regina Obe <lr at pcorp.us>
- * [r16276] change to valid GDAL version
+ * [r16276] ci/debbie/postgis_regress.sh: change to valid GDAL
+ version
2018-01-12 15:50 Regina Obe <lr at pcorp.us>
- * [r16275] set to a GEOS debbie doesn't have. Change to GEOS
- 3.7.0dev
+ * [r16275] ci/debbie/postgis_regress.sh: set to a GEOS debbie
+ doesn't have. Change to GEOS 3.7.0dev
2018-01-12 15:38 Regina Obe <lr at pcorp.us>
- * [r16274] more moving of variables to script from job
+ * [r16274] ci/debbie/postgis_regress.sh,
+ ci/winnie/package_postgis.sh: more moving of variables to script
+ from job
2018-01-12 15:25 Regina Obe <lr at pcorp.us>
- * [r16273] change to hard-code GDAL, GEOS, and MAKE_EXTENSION and
- dump so easier for people to set without changing the job.
+ * [r16273] ci/winnie/regress_postgis.sh: change to hard-code GDAL,
+ GEOS, and MAKE_EXTENSION and dump so easier for people to set
+ without changing the job.
2018-01-12 13:47 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16271] 2.4 fix, st_transform does not qualify query to
- spatial_ref_sys (references #3975)
+ * [r16271] NEWS, libpgcommon/lwgeom_pg.h,
+ libpgcommon/lwgeom_transform.c, libpgcommon/lwgeom_transform.h:
+ 2.4 fix, st_transform does not qualify query to spatial_ref_sys
+ (references #3975)
2018-01-12 08:48 Darafei Praliaskouski <me at komzpa.net>
- * [r16264] Encoded Polyline of EMPTY
+ * [r16264] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
+ liblwgeom/lwout_encoded_polyline.c: Encoded Polyline of EMPTY
Pull in from trunk
Closes #3982
@@ -843,26 +1191,27 @@
2018-01-09 18:36 Sandro Santilli <strk at kbt.io>
- * [r16241] Simplify syntax for brin opclasses so upgrade script
- recognizes it
+ * [r16241] NEWS, postgis/geography_brin.sql.in,
+ postgis/postgis_brin.sql.in: Simplify syntax for brin opclasses
+ so upgrade script recognizes it
Fixes #3956 in 2.4 branch
- * [r16240] Do not assume CREATE OPERATOR CLASS needs to end with
+ * [r16240] utils/postgis_proc_upgrade.pl: Do not assume CREATE
+ OPERATOR CLASS needs to end with ');'
A single ending semicolon is enough to terminate the statement
- * [r16239] Upgrade SFCGAL too when requested
+ * [r16239] regress/run_test.pl: Upgrade SFCGAL too when requested
2018-01-02 14:06 Darafei Praliaskouski <me at komzpa.net>
- * [r16213] Fix KMeans initialization issue that lost clusters
- sometimes.
+ * [r16213] NEWS, liblwgeom/lwkmeans.c: Fix KMeans initialization
+ issue that lost clusters sometimes.
Closes #3965
Closes https://github.com/postgis/postgis/pull/179
@@ -869,41 +1218,45 @@
2018-01-02 13:50 Darafei Praliaskouski <me at komzpa.net>
- * [r16211] Drag in authors mapping from trunk.
+ * [r16211] authors.git, authors.svn: Drag in authors mapping from
+ trunk.
2018-01-01 19:58 Regina Obe <lr at pcorp.us>
- * [r16204] switch to have version of libs used be defined in script
- rather than the jenkins job
+ * [r16204] ci/winnie/build_postgis.sh,
+ switch to have version of libs used be defined in script rather
+ than the jenkins job
2017-12-24 19:06 Regina Obe <lr at pcorp.us>
- * [r16185] copy over 2.3.4 and 2.3.5 notes
+ * [r16185] doc/release_notes.xml: copy over 2.3.4 and 2.3.5 notes
2017-12-20 23:09 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16176] Change syscache stats lookup to use STATRELATTINH key
- and three parameters in all cases for 2.4 branch. Closes #3904
+ * [r16176] postgis/gserialized_estimate.c: Change syscache stats
+ lookup to use STATRELATTINH key and three parameters in all cases
+ for 2.4 branch. Closes #3904
2017-12-20 14:30 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16166] Bring epsilon fix to minimum bounding circle back to 2.4
- (closes #3930)
+ * [r16166] NEWS, liblwgeom/lwboundingcircle.c: Bring epsilon fix to
+ minimum bounding circle back to 2.4 (closes #3930)
2017-12-18 23:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16163] Use original vertex values where available in
- contructing new pointarray (references #3941)
+ * [r16163] liblwgeom/lwgeodetic.c: Use original vertex values where
+ available in contructing new pointarray (references #3941)
2017-12-18 14:54 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16159] Manual fixes from PostGIS users (not many left now) to
- EPSG file
+ * [r16159] spatial_ref_sys.sql: Manual fixes from PostGIS users
+ (not many left now) to EPSG file
References #3944
2017-12-18 09:20 Sandro Santilli <strk at kbt.io>
- * [r16157] Update SRS to EPSG 9.2
+ * [r16157] NEWS, spatial_ref_sys.sql: Update SRS to EPSG 9.2
Patch by Even Rouault
Ref #3944 for 2.4 branch
@@ -910,16 +1263,19 @@
2017-12-12 17:59 Regina Obe <lr at pcorp.us>
- * [r16146] add in verbose and logic to drop test database if it
- exists. Switch to using BRANCH instead of TAG
+ * [r16146] ci/bessie/postgis_regress.sh,
+ ci/bessie32/postgis_regress.sh: add in verbose and logic to drop
+ test database if it exists. Switch to using BRANCH instead of TAG
2017-12-10 01:54 Regina Obe <lr at pcorp.us>
- * [r16139] use new osgeo project logo
+ * [r16139] doc/html/images/osgeo_logo.png: use new osgeo project
+ logo
2017-12-06 20:00 Regina Obe <lr at pcorp.us>
- * [r16135] Turn off interrupt tests in configure by default.
+ * [r16135] NEWS, configure.ac: Turn off interrupt tests in
+ configure by default.
Also added a section in configure output to note if interrupt
tests are enabled or not
Closes #3827 for PostGIS 2.4.3
@@ -926,54 +1282,62 @@
2017-11-30 21:41 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16131] Support google line encodings that include a backslash
- character (References #3713)
+ * [r16131] NEWS, liblwgeom/cunit/cu_out_encoded_polyline.c,
+ liblwgeom/lwout_encoded_polyline.c, postgis/lwgeom_export.c:
+ Support google line encodings that include a backslash character
+ (References #3713)
2017-11-29 00:18 Regina Obe <lr at pcorp.us>
- * [r16123] Explicitly specify $(PERL) to call create_unpackaged.pl
- otherwise at least on freebsd it fails
+ * [r16123] extensions/postgis_sfcgal/Makefile.in: Explicitly
+ specify $(PERL) to call create_unpackaged.pl otherwise at least
+ on freebsd it fails
Also get rid of 9.1 check, we don't support 9.1 anymore.
References #3938 for PostGIS 2.4.3
2017-11-28 23:41 Regina Obe <lr at pcorp.us>
- * [r16122] Add the freebsd bot scripts -- the svn hook change
- should make these fire right away
+ * [r16122] ci/bessie, ci/bessie/postgis_regress.sh, ci/bessie32,
+ ci/bessie32/postgis_regress.sh: Add the freebsd bot scripts --
+ the svn hook change should make these fire right away
2017-11-15 18:18 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16114] push version numbers forward
+ * [r16114] NEWS, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk: push
+ version numbers forward
2017-11-15 18:11 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16112] Prepare for 2.4.2
+ * [r16112] ., ChangeLog, NEWS, README.postgis, Version.config,
+ extensions/upgradeable_versions.mk: Prepare for 2.4.2
2017-11-14 05:42 Regina Obe <lr at pcorp.us>
- * [r16108] note about enhanced feature in reverse_geocode when
- zcta5 data is loaded.
+ * [r16108] doc/extras_tigergeocoder.xml: note about enhanced
+ feature in reverse_geocode when zcta5 data is loaded.
2017-11-09 09:06 Regina Obe <lr at pcorp.us>
- * [r16102] Add missing 2.3.4 upgrade path (as provided by Muhammad
- Usama)
+ * [r16102] NEWS, extensions/upgradeable_versions.mk: Add missing
+ 2.3.4 upgrade path (as provided by Muhammad Usama)
Also remove 2.3 and 2.4 dev releases and add missing 2.2.6
Closes #3926 for PostGIS 2.4.2
2017-11-09 08:53 Regina Obe <lr at pcorp.us>
- * [r16099] fix spacing
+ * [r16099] NEWS: fix spacing
2017-11-09 08:52 Regina Obe <lr at pcorp.us>
- * [r16098] Add missing release notes for ST_Segmentize geography
- fix.
+ * [r16098] NEWS: Add missing release notes for ST_Segmentize
+ geography fix.
References #3667 for PostGIS 2.4.2
2017-11-07 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16094] Replace project-and-entend logic with
+ * [r16094] liblwgeom/cunit/cu_geodetic.c, liblwgeom/lwgeodetic.c,
+ regress/geography_expected: Replace project-and-entend logic with
bisect-and-recurse in geography segmentization.
Preserves "mostly equal" segment lengths, and
should be more numerically stable.
@@ -982,8 +1346,8 @@
2017-10-31 15:15 Sandro Santilli <strk at kbt.io>
- * [r16086] Make sure target directories are created before copying
- files to them
+ * [r16086] configure.ac, liblwgeom/Makefile.in: Make sure target
+ directories are created before copying files to them
References #3912 for 2.4 branch
References #3916 for 2.4 branch
@@ -990,17 +1354,21 @@
2017-10-26 01:07 Regina Obe <lr at pcorp.us>
- * [r16061] Fix zcta5 load - NEWS item
+ * [r16061] NEWS: Fix zcta5 load - NEWS item
References #3917 for PostGIS 2.4.2
2017-10-26 01:06 Regina Obe <lr at pcorp.us>
- * [r16060] Fix zcta5 load
+ * [r16060] extras/tiger_geocoder/tiger_loader_2017.sql: Fix zcta5
+ load
2017-10-21 09:02 Sandro Santilli <strk at kbt.io>
- * [r16029] Put build AUX files under build-aux
+ * [r16029] .gitignore, GNUmakefile.in, configure.ac,
+ liblwgeom/Makefile.in, loader/Makefile.in, raster/install-sh,
+ raster/loader/Makefile.in, utils/Makefile.in: Put build AUX files
+ under build-aux
Cleans and ignore build aux files from new location,
and remove spurious install-sh from repository.
@@ -1009,47 +1377,59 @@
2017-10-20 13:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16018] Reflect CFLAGS passed into core
+ * [r16018] raster/rt_pg/Makefile.in: Reflect CFLAGS passed into
+ core
2017-10-20 13:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16017] Reflect CFLAGS passed into configure
+ * [r16017] postgis/Makefile.in: Reflect CFLAGS passed into
+ configure
2017-10-18 19:28 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16014] Quiet compile warnings
+ * [r16014] liblwgeom/lwgeom_geos.c, postgis/geobuf.c,
+ postgis/geography_centroid.c, postgis/gserialized_gist_2d.c,
+ postgis/lwgeom_functions_basic.c, postgis/mvt.c: Quiet compile
+ warnings
2017-10-18 18:46 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16013] Bump forward versions
+ * [r16013] HOWTO_RELEASE, NEWS, README.postgis, Version.config,
+ extensions/upgradeable_versions.mk: Bump forward versions
2017-10-18 18:32 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r16011] Prepare for 2.4.1 release
+ * [r16011] ChangeLog, NEWS, README.postgis, Version.config,
+ doc/release_notes.xml: Prepare for 2.4.1 release
2017-10-17 18:23 Regina Obe <lr at pcorp.us>
- * [r16001]
+ * [r16001] doc/introduction.xml:
2017-10-17 16:53 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15997] Allocate enough space for all possible GBOX string
- outputs (Raúl Marín Rodríguez)
+ * [r15997] NEWS, liblwgeom/cunit/cu_geodetic.c, liblwgeom/g_box.c:
+ Allocate enough space for all possible GBOX string outputs (Raúl
+ Marín Rodríguez)
References #3907
2017-10-17 14:36 Regina Obe <lr at pcorp.us>
- * [r15995] Add Darafei Praliaskouski to authors lists and core
- developers list and make up responsibilities for him.
+ * [r15995] authors.git, authors.svn, doc/introduction.xml: Add
+ Darafei Praliaskouski to authors lists and core developers list
+ and make up responsibilities for him.
2017-10-16 14:59 Regina Obe <lr at pcorp.us>
- * [r15992] Fix xml parse error in docs
+ * [r15992] doc/using_postgis_dataman.xml: Fix xml parse error in
+ docs
References #3902 for PostGIS 2.4.1
2017-10-16 09:35 Regina Obe <lr at pcorp.us>
- * [r15991] Backport geography changes to PostGIS 2.4.1
+ * [r15991] doc/extras_tigergeocoder.xml,
+ doc/using_postgis_dataman.xml: Backport geography changes to
+ PostGIS 2.4.1
Closes #3902
Changed Changed to Enhanced for tiger zcta
References #3815 for PostGIS 2.4.1
@@ -1056,22 +1436,29 @@
2017-10-15 17:53 Regina Obe <lr at pcorp.us>
- * [r15987] Tiger 2017 and zcta load support for PostGIS 2.4.1
+ * [r15987] NEWS, doc/extras_tigergeocoder.xml,
+ doc/installation.xml, doc/xsl/postgis_aggs_mm.xml.xsl,
+ extras/tiger_geocoder/tiger_loader_2017.sql: Tiger 2017 and zcta
+ load support for PostGIS 2.4.1
Closes #3815
2017-10-11 14:05 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15965] Fix rare missing boxes in geometry subdivision
+ * [r15965] NEWS, liblwgeom/lwgeom_geos.c: Fix rare missing boxes in
+ geometry subdivision
References #3886
2017-10-11 13:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15964] PgSQL 11 support for 2.4 branch (DatumGetJsonbP macro)
+ * [r15964] postgis/mvt.c: PgSQL 11 support for 2.4 branch
+ (DatumGetJsonbP macro)
Closes #3867
2017-10-10 22:45 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15960] Throw error on malformed WKB input (2.4 branch)
+ * [r15960] NEWS, liblwgeom/lwin_wkb.c: Throw error on malformed WKB
+ input (2.4 branch)
Credit to OSS-Fuzz:
https://bugs.chromium.org/p/oss-fuzz/issues/detail?id=2589
Credit to OSS-Fuzz:
@@ -1084,124 +1471,145 @@
2017-10-10 18:04 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15955] Undefined behaviour in pointarray_to_encoded_polyline
- (2.4 branch)
+ * [r15955] NEWS, liblwgeom/lwout_encoded_polyline.c: Undefined
+ behaviour in pointarray_to_encoded_polyline (2.4 branch)
(References #3891)
2017-10-10 16:58 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15948] Fix undefined behaviour in zigzag with negative inputs
- (2.4 branch)
+ * [r15948] NEWS, liblwgeom/cunit/cu_varint.c, liblwgeom/varint.c,
+ liblwgeom/varint.h: Fix undefined behaviour in zigzag with
+ negative inputs (2.4 branch)
(References #3882)
2017-10-10 16:36 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15945] lw_dist2d_pt_arc division by zero (References #3874)
+ * [r15945] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: lw_dist2d_pt_arc division by zero
+ (References #3874)
2017-10-09 18:54 Regina Obe <lr at pcorp.us>
- * [r15939] Update geocode batch update example to use LATERAL now
- that PostgreSQL 9.3 is minimum supported.
+ * [r15939] doc/extras_tigergeocoder.xml: Update geocode batch
+ update example to use LATERAL now that PostgreSQL 9.3 is minimum
+ supported.
2017-10-06 13:31 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15923] Performance improvements for b-tree geometry sorts
+ * [r15923] NEWS, liblwgeom/g_serialized.c,
+ postgis/geography_btree.c: Performance improvements for b-tree
+ geometry sorts
References #3864
2017-10-06 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15919] geohash_point_as_int: Fix undefined behaviour in shift
- operation
+ * [r15919] NEWS, liblwgeom/lwalgorithm.c: geohash_point_as_int: Fix
+ undefined behaviour in shift operation
References #3875
2017-10-06 13:17 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15915] Undefined behaviour in TYPMOD_GET_SRID
+ * [r15915] NEWS, liblwgeom/cunit/cu_libgeom.c,
+ liblwgeom/liblwgeom.h.in: Undefined behaviour in TYPMOD_GET_SRID
References #3880
2017-10-05 13:21 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15902] Combine multiple signum definitions (2.4)
+ * [r15902] NEWS, liblwgeom/cunit/cu_geodetic.c,
+ liblwgeom/cunit/cu_libgeom.c, liblwgeom/liblwgeom_internal.h,
+ liblwgeom/lwalgorithm.c, liblwgeom/lwgeodetic.c,
+ liblwgeom/lwgeodetic.h, liblwgeom/lwspheroid.c: Combine multiple
+ signum definitions (2.4)
(References #3878)
2017-10-05 13:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15897] division by zero in lw_dist2d_arc_arc
+ * [r15897] NEWS, liblwgeom/cunit/cu_measures.c,
+ liblwgeom/measures.c: division by zero in lw_dist2d_arc_arc
References #3879
2017-10-02 22:29 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15877] Fix union issue (References #3871)
+ * [r15877] liblwgeom/g_serialized.c: Fix union issue (References
+ #3871)
2017-10-02 22:00 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15874] Use type-pun to avoid memcpy in building morton key
- (References #3871)
+ * [r15874] NEWS, liblwgeom/g_serialized.c: Use type-pun to avoid
+ memcpy in building morton key (References #3871)
2017-10-02 12:51 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15872] Gracefully handle short-measure issue (Closes #3845)
+ * [r15872] NEWS, liblwgeom/lwlinearreferencing.c: Gracefully handle
+ short-measure issue (Closes #3845)
2017-10-02 06:17 Sandro Santilli <strk at kbt.io>
- * [r15866] Add -lm to liblwgeom link line
+ * [r15866] NEWS, liblwgeom/Makefile.in: Add -lm to liblwgeom link
+ line
References #3869 for 2.4 branch
2017-10-01 18:31 Sandro Santilli <strk at kbt.io>
- * [r15865] Fix memory leaks in BTREE operators
+ * [r15865] NEWS, postgis/lwgeom_btree.c: Fix memory leaks in BTREE
+ operators
References #3864 for 2.4 branch
2017-09-30 17:45 Sandro Santilli <strk at kbt.io>
- * [r15860] Fix yaml syntax in drone config
+ * [r15860] .drone.yml: Fix yaml syntax in drone config
2017-09-30 06:38 Regina Obe <lr at pcorp.us>
- * [r15856] Bump version to 2.4.1dev, get rid of alpha, beta too
+ * [r15856] README.postgis, Version.config,
+ extensions/upgradeable_versions.mk: Bump version to 2.4.1dev, get
+ rid of alpha, beta too
2017-09-29 14:11 Regina Obe <lr at pcorp.us>
- * [r15852] update README to reflect that 3.4 or higher is required
- and 3.6+ is recommended.
+ * [r15852] README.postgis: update README to reflect that 3.4 or
+ higher is required and 3.6+ is recommended.
Closes #3868 for PostGIS 2.4
2017-09-28 06:50 Regina Obe <lr at pcorp.us>
- * [r15849] Soft launch PostGIS 2.4.0
+ * [r15849] NEWS, Version.config, doc/release_notes.xml,
+ extensions/upgradeable_versions.mk: Soft launch PostGIS 2.4.0
2017-09-27 06:13 Regina Obe <lr at pcorp.us>
- * [r15846] Update change log with latest changes
+ * [r15846] ChangeLog: Update change log with latest changes
2017-09-27 04:13 Regina Obe <lr at pcorp.us>
- * [r15843] it's already 9/27 update date.
+ * [r15843] NEWS: it's already 9/27 update date.
2017-09-27 04:05 Regina Obe <lr at pcorp.us>
- * [r15842] update changes done since 2.4.0rc3 in prep for tagging
+ * [r15842] NEWS: update changes done since 2.4.0rc3 in prep for
+ tagging
2017-09-26 16:59 Paul Ramsey <pramsey at cleverelephant.ca>
- * [r15834] Allow triangles unclosed in M to be WKT parsed
- (References #3818)
+ * [r15834] liblwgeom/lwin_wkb.c, liblwgeom/lwin_wkt.c: Allow
+ triangles unclosed in M to be WKT parsed (References #3818)
2017-09-26 16:23 Sandro Santilli <strk at kbt.io>
- * [r15832] Ignore vector_tile.pb-c when checking for trailing
- blanks
+ * [r15832] GNUmakefile.in: Ignore vector_tile.pb-c when checking
+ for trailing blanks
- * [r15831] Remove trailing blank from postgis_config.h.in, prevent
- them
+ * [r15831] GNUmakefile.in, postgis_config.h.in: Remove trailing
+ blank from postgis_config.h.in, prevent them
2017-09-26 13:57 Sandro Santilli <strk at kbt.io>
- * [r15828] Do not use .gitignore for checking trailing blank spaces
+ * [r15828] GNUmakefile.in: Do not use .gitignore for checking
+ trailing blank spaces
Manually ignore files instead. Re-using .gitignore patterns
isn't easy for grep.
@@ -1208,16 +1616,18 @@
2017-09-26 13:56 Sandro Santilli <strk at kbt.io>
- * [r15827] Remove trailing blanks
+ * [r15827] loader/pgsql2shp-cli.c, raster/loader/raster2pgsql.c:
+ Remove trailing blanks
2017-09-26 13:35 Sandro Santilli <strk at kbt.io>
- * [r15824] Make check-no-trailing-blanks implementation POSIX
- compliant
+ * [r15824] GNUmakefile.in: Make check-no-trailing-blanks
+ implementation POSIX compliant
2017-09-26 08:26 Sandro Santilli <strk at kbt.io>
- * [r15822] Ignore generated files in check-no-trailing-blanks
+ * [r15822] GNUmakefile.in: Ignore generated files in
+ check-no-trailing-blanks
Also be forgiving of a missing .gitignore (but then tests will
fail due to generated files possibly having trailing blanks)
@@ -1224,11 +1634,13 @@
2017-09-26 01:50 Regina Obe <lr at pcorp.us>
- * [r15820] update badges to point at 2.4, update to 2.4.0rc3
+ * [r15820] NEWS, README.md, README.postgis, Version.config,
+ doc/release_notes.xml, extensions/upgradeable_versions.mk: update
+ badges to point at 2.4, update to 2.4.0rc3
2017-09-26 01:09 Regina Obe <lr at pcorp.us>
- * [r15818] Branch 2.4 in prep for release Thursday
+ * [r15818] .: Branch 2.4 in prep for release Thursday
2017-09-25 20:48 Nicklas Avén <nicklas.aven at jordogskog.no>
Modified: branches/2.4/NEWS
--- branches/2.4/NEWS 2019-08-11 04:16:40 UTC (rev 17692)
+++ branches/2.4/NEWS 2019-08-11 04:20:40 UTC (rev 17693)
@@ -1,5 +1,5 @@
PostGIS 2.4.8
-2019/08/1X
+2019/08/11
* Bug Fixes and Enhancements *
@@ -14,7 +14,7 @@
- #4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)
- #4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)
- #4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)
- - #4461, ST_AsTWKB doesn't always remove duplicate points (Nik Aven)
+ - #4461, ST_AsTWKB doesn't always remove duplicate points (Nicklas Avén)
- #4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)
- #4420, update path does not exists for address_standardizer extension (Regina Obe)
Modified: branches/2.4/Version.config
--- branches/2.4/Version.config 2019-08-11 04:16:40 UTC (rev 17692)
+++ branches/2.4/Version.config 2019-08-11 04:20:40 UTC (rev 17693)
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=8dev
+POSTGIS_MICRO_VERSION=8
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
Modified: branches/2.4/doc/release_notes.xml
--- branches/2.4/doc/release_notes.xml 2019-08-11 04:16:40 UTC (rev 17692)
+++ branches/2.4/doc/release_notes.xml 2019-08-11 04:20:40 UTC (rev 17693)
@@ -3,6 +3,28 @@
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
<sect1>
+ <title>Release 2.4.8</title>
+ <para>Release date: 2019/08/11</para>
+ <para>This is a bug fix and performance improvement release.</para>
+ <simplesect><title>Bug Fixes and Enhancements</title>
+ <para>#4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)</para>
+ <para>#4326, Fix circular arc distance calculation (Paul Ramsey)</para>
+ <para>#4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)</para>
+ <para>#4327, Avoid pfree'ing the result of getenv (Raúl Marín)</para>
+ <para>#4406, Throw on invalid characters when decoding geohash (Raúl Marín)</para>
+ <para>#4440, Internal type lookups fail over FDW (Paul Ramsey)</para>
+ <para>#4445, Fix bug in lwgeom_le (Raúl Marín)</para>
+ <para>#4466, Fix undefined behaviour in _postgis_gserialized_stats (Raúl Marín)</para>
+ <para>#4209, Handle NULL geometry values in pgsql2shp (Paul Ramsey)</para>
+ <para>#4419, Use protobuf version to enable/disable mvt/geobuf (Paul Ramsey)</para>
+ <para>#4437, Handle POINT EMPTY in shape loader/dumper (Paul Ramsey)</para>
+ <para>#4461, ST_AsTWKB doesn't always remove duplicate points (Nicklas Avén)</para>
+ <para>#4470, ST_GeomFromGeoJSON crash on empty rings (Darafei Praliaskouski)</para>
+ <para>#4420, update path does not exists for address_standardizer extension (Regina Obe)</para>
+ </simplesect>
+ </sect1>
+ <sect1>
<title>Release 2.4.7</title>
<para>Release date: 2019/03/11</para>
@@ -455,7 +477,7 @@
<para>This is a new feature release, with new functions, improved performance, and other goodies.</para>
<simplesect>
<title>New Features</title>
- <para>Topology API in liblwgeom (Sandro Santilli / Regione Toscana - SITA)</para>
+ <para>Topology API in liblwgeom (Sandro Santilli / Regione Toscana<para>SITA)</para>
<para>New lwgeom_unaryunion method in liblwgeom</para>
<para>New lwgeom_linemerge method in liblwgeom</para>
<para>New lwgeom_is_simple method in liblwgeom</para>
@@ -535,7 +557,7 @@
<title>Bug Fixes</title>
<para>#3159, do not force a bbox cache on ST_Affine</para>
<para>#3018, GROUP BY geography sometimes returns duplicate rows</para>
- <para>#3084, shp2pgsql - illegal number format when specific system locale set</para>
+ <para>#3084, shp2pgsql<para>illegal number format when specific system locale set</para>
<para>#3094, Malformed GeoJSON inputs crash backend</para>
<para>#3104, st_asgml introduces random characters in ID field</para>
<para>#3155, Remove liblwgeom.h on make uninstall</para>
@@ -761,7 +783,7 @@
<title>Important / Breaking Changes</title>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/1653">#1653</ulink>, Removed srid parameter from ST_Resample(raster) and variants
with reference raster no longer apply reference raster's SRID.</para>
- <para><ulink url="http://trac.osgeo.org/postgis/ticket/1962">#1962</ulink> ST_Segmentize - As a result of
+ <para><ulink url="http://trac.osgeo.org/postgis/ticket/1962">#1962</ulink> ST_Segmentize<para>As a result of
the introduction of geography support, The construct:
<code>SELECT ST_Segmentize('LINESTRING(1 2, 3 4)',0.5);</code>
will result in ambiguous function error</para>
@@ -1205,7 +1227,7 @@
to <xref linkend="hard_upgrade" /> for details on upgrading.
Refer to <xref linkend="NewFunctions_2_0" /> for more details and changed/new functions.</para>
<simplesect>
- <title>Testers - Our unsung heroes</title>
+ <title>Testers<para>Our unsung heroes</title>
<para>We are most indebted to the numerous members in the PostGIS community
who were brave enough to test out the new features in this release.
No major release can be successful without these folk.</para>
@@ -1213,17 +1235,17 @@
and thorough bug reports,
and detailed analysis.</para>
<simplelist>
- <member>Andrea Peri - Lots of testing on topology, checking for correctness</member>
- <member>Andreas Forø Tollefsen - raster testing</member>
- <member>Chris English - topology stress testing loader functions</member>
- <member>Salvatore Larosa - topology robustness testing</member>
- <member>Brian Hamlin - Benchmarking
+ <member>Andrea Peri<para>Lots of testing on topology, checking for correctness</member>
+ <member>Andreas Forø Tollefsen<para>raster testing</member>
+ <member>Chris English<para>topology stress testing loader functions</member>
+ <member>Salvatore Larosa<para>topology robustness testing</member>
+ <member>Brian Hamlin<para>Benchmarking
(also experimental experimental branches
before they are folded into core)
, general testing of various pieces
including Tiger and Topology. Testing on various server VMs</member>
- <member>Mike Pease - Tiger geocoder testing - very detailed reports of issues</member>
- <member>Tom van Tilburg - raster testing</member>
+ <member>Mike Pease<para> Tiger geocoder testing<para>very detailed reports of issues</member>
+ <member>Tom van Tilburg<para>raster testing</member>
</simplelist>
</simplesect>
<simplesect>
@@ -1242,12 +1264,12 @@
for tables created the old way reads (srid, type, dims) constraints
for geometry columns created with type modifiers
reads rom column definition</para>
- <para><ulink url="http://trac.osgeo.org/postgis/ticket/1081">#1081</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1082">#1082</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1084">#1084</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1088">#1088</ulink> - Mangement functions support typmod
+ <para><ulink url="http://trac.osgeo.org/postgis/ticket/1081">#1081</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1082">#1082</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1084">#1084</ulink>, <ulink url="http://trac.osgeo.org/postgis/ticket/1088">#1088</ulink><para>Mangement functions support typmod
geometry column creation functions now default to typmod creation
(Regina Obe)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/1083">#1083</ulink> probe_geometry_columns(), rename_geometry_table_constraints(),
fix_geometry_columns(); removed
- - now obsolete with geometry_column view
+ <para>now obsolete with geometry_column view
(Regina Obe)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/817">#817</ulink> Renaming old 3D functions to the convention ST_3D (Nicklas Avén)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/548">#548</ulink> (sorta), ST_NumGeometries,ST_GeometryN now returns 1 (or the geometry) instead of null
@@ -1260,7 +1282,7 @@
<para><ulink url="http://trac.osgeo.org/postgis/wiki/WKTRaster/PlanningAndFunding">Raster support integrated and documented</ulink>
(Pierre Racine, Jorge Arévalo, Mateusz Loskot, Sandro Santilli, David Zwarg, Regina Obe, Bborie Park)
(Company developer and funding: University Laval, Deimos Space, CadCorp, Michigan Tech Research Institute, Azavea, Paragon Corporation, UC Davis Center for Vectorborne Diseases)</para>
- <para>Making spatial indexes 3D aware - in progress (Paul Ramsey, Mark Cave-Ayland)</para>
+ <para>Making spatial indexes 3D aware<para>in progress (Paul Ramsey, Mark Cave-Ayland)</para>
<para>Topology support improved (more functions), documented, testing (Sandro Santilli / Faunalia for RT-SIGTA), Andrea Peri, Regina Obe, Jose Carlos Martinez Llari</para>
<para>3D relationship and measurement support functions (Nicklas Avén)</para>
<para> ST_3DDistance, ST_3DClosestPoint, ST_3DIntersects, ST_3DShortestLine and more...</para>
@@ -1289,9 +1311,9 @@
(Jeff Adams / Azavea, Mark Cave-Ayland)</para>
<para>pgsql2shp conversion from predefined list
(Loic Dachary / Mark Cave-Ayland)</para>
- <para>Shp-pgsql GUI loader - support loading multiple files at a time. (Mark Leslie)</para>
- <para>Extras - upgraded tiger_geocoder from using old TIGER format to use new TIGER shp and file structure format (Stephen Frost)</para>
- <para>Extras - revised tiger_geocoder to work with TIGER census 2010 data, addition of reverse geocoder function, various bug fixes, accuracy enhancements,
+ <para>Shp-pgsql GUI loader<para>support loading multiple files at a time. (Mark Leslie)</para>
+ <para>Extras<para>upgraded tiger_geocoder from using old TIGER format to use new TIGER shp and file structure format (Stephen Frost)</para>
+ <para>Extras<para>revised tiger_geocoder to work with TIGER census 2010 data, addition of reverse geocoder function, various bug fixes, accuracy enhancements,
limit max result return, speed improvements, loading routines.
(Regina Obe, Leo Hsu / Paragon Corporation / funding provided by Hunter Systems Group)</para>
<para>Overall Documentation proofreading and corrections. (Kasif Rasul)</para>
@@ -1375,7 +1397,7 @@
<para><ulink url="http://trac.osgeo.org/postgis/ticket/441">#441</ulink> ST_AsGeoJson Bbox on GeometryCollection error (Olivier Courtin)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/411">#411</ulink> Ability to backup invalid geometries (Sando Santilli)
Reported by Regione Toscana</para>
- <para><ulink url="http://trac.osgeo.org/postgis/ticket/409">#409</ulink> ST_AsSVG - degraded (Olivier Courtin)
+ <para><ulink url="http://trac.osgeo.org/postgis/ticket/409">#409</ulink> ST_AsSVG<para>degraded (Olivier Courtin)
Reported by Sdikiy</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/373">#373</ulink> Documentation syntax error in hard upgrade (Paul Ramsey)
Reported by psvensso</para>
@@ -1396,7 +1418,7 @@
<para><ulink url="http://trac.osgeo.org/postgis/ticket/393">#393</ulink>, Loader: Add temporary patch for large DBF files (Maxime Guillaud, Paul Ramsey)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/507">#507</ulink>, Fix wrong OGC URN in GeoJSON and GML output (Olivier Courtin)</para>
<para>spatial_ref_sys.sql Add datum conversion for projection SRID 3021 (Paul Ramsey)</para>
- <para>Geography - remove crash for case when all geographies are out of the estimate (Paul Ramsey)</para>
+ <para>Geography<para>remove crash for case when all geographies are out of the estimate (Paul Ramsey)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/469">#469</ulink>, Fix for array_aggregation error (Greg Stark, Paul Ramsey)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/532">#532</ulink>, Temporary geography tables showing up in other user sessions (Paul Ramsey)</para>
<para><ulink url="http://trac.osgeo.org/postgis/ticket/562">#562</ulink>, ST_Dwithin errors for large geographies (Paul Ramsey)</para>
@@ -2419,8 +2441,8 @@
<para>Release date: 2005/08/08</para>
- <para>Contains some bug fixes - <emphasis>including a severe one
- affecting correctness of stored geometries</emphasis> - and a few
+ <para>Contains some bug fixes<para><emphasis>including a severe one
+ affecting correctness of stored geometries</emphasis><para>and a few
improvements.</para>
<simplesect>
Modified: branches/2.4/extensions/upgradeable_versions.mk
--- branches/2.4/extensions/upgradeable_versions.mk 2019-08-11 04:16:40 UTC (rev 17692)
+++ branches/2.4/extensions/upgradeable_versions.mk 2019-08-11 04:20:40 UTC (rev 17693)
@@ -36,6 +36,7 @@
2.3.7 \
2.3.8 \
2.3.9 \
+ 2.3.10 \
2.4.0 \
2.4.1 \
2.4.2 \
