[postgis-tickets] r17698 - Prep for 2.5.3 release
Regina Obe lr at pcorp.us
Sat Aug 10 10:43:01 PDT 2019
Author: robe
Date: 2019-08-10 22:43:01 -0700 (Sat, 10 Aug 2019)
New Revision: 17698
   branches/2.5/ChangeLog
   branches/2.5/NEWS
   branches/2.5/Version.config
   branches/2.5/doc/release_notes.xml
   branches/2.5/extensions/upgradeable_versions.mk
Modified: branches/2.5/ChangeLog
--- branches/2.5/ChangeLog	2019-08-11 05:25:14 UTC (rev 17697)
+++ branches/2.5/ChangeLog	2019-08-11 05:43:01 UTC (rev 17698)
@@ -1,6 +1,250 @@
+2019-08-04 07:36  Darafei Praliaskouski <me at komzpa.net>
+	* [r17669] NEWS, liblwgeom/lwin_geojson.c, regress/in_geojson.sql,
+	  regress/in_geojson_expected: ST_GeomFromGeoJSON crash on empty
+	  rings
+	  Closes #4470
+2019-08-04 07:19  Darafei Praliaskouski <me at komzpa.net>
+	* [r17668] NEWS, liblwgeom/lwgeom.c: ST_Subdivide crash on
+	  intermediate EMPTY fix.
+	  Closes #4459
+2019-08-02 20:02  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17663] regress/tickets.sql, regress/tickets_expected: Remove
+	  test of pointonsurface that has variable behavior based on what
+	  geos (>= 3.8?) is installed
+2019-08-02 16:32  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17661] configure.ac: Fix minor version check issue in protobuf
+	  pkg-config section
+2019-08-02 13:51  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17660] regress/sfcgal/tickets_expected: Fix sfcgal regress
+	  tests
+	  Closes https://github.com/postgis/postgis/pull/451
+2019-08-01 20:15  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17658] regress/estimatedextent.sql,
+	  regress/estimatedextent_expected, regress/sfcgal/tickets.sql,
+	  regress/sfcgal/tickets_expected: Deal with differing behaviour of
+	  subquery planning between Pg versions.
+	  References #4464
+2019-08-01 17:48  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17656] NEWS, liblwgeom/lwout_twkb.c, regress/twkb.sql,
+	  regress/twkb_expected: ST_AsTWKB doesn't always remove duplicate
+	  points
+	  References #4461
+2019-07-31 21:42  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17652] NEWS, loader/pgsql2shp-core.c, loader/shp2pgsql-core.c:
+	  Handle POINT EMPTY in shape loader/dumper
+	  References #4437
+2019-07-30 22:27  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17647] NEWS, configure.ac, postgis/Makefile.in,
+	  postgis/geobuf.c, postgis/geobuf.h, postgis/lwgeom_out_geobuf.c,
+	  postgis_config.h.in, regress/Makefile.in: Use protobuf version to
+	  enable/disable mvt/geobuf
+	  References #4419
+2019-07-29 16:45  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17641] NEWS, loader/pgsql2shp-core.c: Handle NULL geometry
+	  values in pgsql2shp
+	  References #4209
+2019-07-29 16:11  Sandro Santilli <strk at kbt.io>
+	* [r17636] .gitlab-ci.yml: [gitlab-ci] Be explicit about
+	  distribution to use (stretch)
+2019-07-29 15:33  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17634] NEWS, postgis/gserialized_estimate.c: Fix undefined
+	  behaviour in _postgis_gserialized_stats
+	  References #4466
+2019-07-19 05:43  Regina Obe <lr at pcorp.us>
+	* [r17614] doc/installation.xml: Dealing with IGN SRIDs from Michel
+	  Philippenko
+	  references https://github.com/postgis/postgis/pull/448
+	  for PostGIS 2.5
+2019-07-16 08:58  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17608] libpgcommon/Makefile.in, loader/Makefile.in,
+	  raster/loader/Makefile.in: Add CPPFLAGS where missing
+	  Spotted by Debian's build log hardening checker, blhc.
+	  https://salsa.debian.org/debian-gis-team/postgis/-/jobs/222378
+	  Patch by Christoph Berg <myon -at- debian.org>
+2019-07-02 09:48  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17581] regress/sfcgal/tickets_expected: Partially revert
+	  changes in test expected output
+2019-07-02 09:00  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17579] NEWS, postgis/lwgeom_btree.c: Fix bug in lwgeom_le
+	  References #4445
+2019-06-28 17:29  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17568] NEWS, libpgcommon/lwgeom_pg.c, libpgcommon/lwgeom_pg.h,
+	  libpgcommon/lwgeom_transform.c, postgis/geobuf.c,
+	  postgis/gserialized_estimate.c, postgis/gserialized_spgist_2d.c,
+	  postgis/gserialized_spgist_3d.c, postgis/mvt.c: Internal type
+	  lookups fail over FDW
+	  References #4440
+2019-06-25 21:51  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17558] regress/estimatedextent.sql,
+	  regress/sfcgal/tickets_expected: Change tests so that they will
+	  have the same behaviour
+	  on both pg11 and pg12
+2019-06-13 11:56  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17528] NEWS, liblwgeom/cunit/cu_algorithm.c,
+	  liblwgeom/lwalgorithm.c: Throw on invalid characters when
+	  decoding geohash
+	  References #4406
+2019-06-13 07:43  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17523] NEWS, raster/rt_pg/rtpostgis.c: Avoid pfree'ing the
+	  result of getenv
+	  References #4327
+2019-06-12 15:27  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17516] .travis.yml, libpgcommon/gserialized_gist.h,
+	  postgis/gserialized_gist_nd.c: Fix travis build
+	  Closes #4426
+2019-06-12 13:29  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17512] NEWS, raster/rt_pg/rtpostgis.sql.in,
+	  raster/test/regress/tickets.sql,
+	  raster/test/regress/tickets_expected: AddRasterConstraints:
+	  Ignore NULLs when generating constraints
+	  References #4388
+2019-05-14 21:33  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17437] NEWS, liblwgeom/lwgeom.c, postgis/lwgeom_geos.c: Simple
+	  TIN support to allow viz in QGIS
+	  References #4380
+2019-05-02 16:17  Regina Obe <lr at pcorp.us>
+	* [r17426] doc/installation.xml: update CUnit vector tests
+	  (somewhat pointless commit to trigger a run to test dornie)
+2019-04-14 04:56  Regina Obe <lr at pcorp.us>
+	* [r17393] authors.git, authors.svn: Add Martin Davis to authors
+	  list
+2019-04-12 22:16  Paul Ramsey <pramsey at cleverelephant.ca>
+	* [r17386] NEWS, liblwgeom/cunit/cu_measures.c,
+	  liblwgeom/measures.c: Circular string distances have some failure
+	  modes, and test
+	  suite should test everything bi-directionally.
+	  References #4326
+2019-04-08 17:12  Regina Obe <lr at pcorp.us>
+	* [r17378] doc/installation.xml: update the output of postgis and
+	  raster tests -- was based on 2.2 before
+2019-04-08 16:27  Regina Obe <lr at pcorp.us>
+	* [r17377] doc/installation.xml: change to use vacuum (analyze,
+	  verbose) instead of vacuum analyze verbose. The old format got
+	  remove in pg11
+2019-03-29 14:27  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17367] NEWS, postgis/postgis.sql.in,
+	  regress/postgis_type_name.sql,
+	  regress/postgis_type_name_expected: Fix postgis_type_name with
+	  (GEOMETRYM,3)
+	  Patch by Matt Bretl
+	  References #4361
+2019-03-22 11:26  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17355] postgis/mvt.c, regress/mvt.sql, regress/mvt_expected:
+	  MVT Geos: Avoid dereferencing a NULL pointer after validation
+	  References #4348
+2019-03-21 12:09  Raúl Marín Rodríguez <rmrodriguez at carto.com>
+	* [r17352] NEWS, postgis/mvt.c, regress/mvt.sql,
+	  regress/mvt_expected: ST_AsMVTGeom (GEOS): Enforce validation at
+	  all times
+	  Closes #4348
+2019-03-11 17:06  Regina Obe <lr at pcorp.us>
+	* [r17329] Version.config, extensions/upgradeable_versions.mk: Flip
+	  to 2.5.3dev
+2019-03-11 17:03  Regina Obe <lr at pcorp.us>
+	* [r17327] .drone-1.0.yml: Get rid of 11 travis docker build
+	  doesn't work - will revisit later
+2019-03-11 14:30  Regina Obe <lr at pcorp.us>
+	* [r17326] NEWS, doc/release_notes.xml,
+	  extras/tiger_geocoder/tables/lookup_tables_2011.sql: Remove zcta5
+	  geometry constraint
+	  Closes #4086 for PostGIS 2.5.2
+2019-03-11 12:40  Regina Obe <lr at pcorp.us>
+	* [r17323] ChangeLog, NEWS, README.postgis, Version.config,
+	  doc/release_notes.xml, extensions/upgradeable_versions.mk: Prep
+	  for PostGIS 2.5.2 release
 2019-03-10 18:58  Regina Obe <lr at pcorp.us>
-	* [r17321] Make _drop_raster_constraint_spatially_unique and
+	* [r17321] raster/rt_pg/rtpostgis.sql.in,
+	  raster/test/regress/check_raster_columns.sql,
+	  raster/test/regress/check_raster_columns_expected: Make
+	  _drop_raster_constraint_spatially_unique and
 	  _raster_constraint_info_spatially_unique allow for presence or
 	  absense of schema qual on geometry cast.
 	  Was failing before when installed as extension (but not by
@@ -9,62 +253,78 @@
 2019-03-10 09:07  Regina Obe <lr at pcorp.us>
-	* [r17317] Take out schema qualify in constraint see if it resolves
-	  failing check constraint check on bessie and debbie
+	* [r17317] raster/rt_pg/rtpostgis.sql.in: Take out schema qualify
+	  in constraint see if it resolves failing check constraint check
+	  on bessie and debbie
 	  Reference #4291 for PostGIS 2.5.2
 2019-03-10 07:20  Regina Obe <lr at pcorp.us>
-	* [r17316] Schema qualify all geometry casts in raster code,
-	  otherwise materialized views do not resture
+	* [r17316] raster/rt_pg/rtpostgis.sql.in: Schema qualify all
+	  geometry casts in raster code, otherwise materialized views do
+	  not resture
 	  Closes #4291 for PostGIS 2.5.2
 	  Missed some spots in last commit
 2019-03-09 06:54  Regina Obe <lr at pcorp.us>
-	* [r17313] Schema qualify all geometry casts in raster code,
+	* [r17313] NEWS, raster/rt_pg/rtpostgis.sql.in: Schema qualify all
+	  not resture
 2019-03-09 06:29  Regina Obe <lr at pcorp.us>
-	* [r17311] Change de_DE to de. de is the one that is active
+	* [r17311] doc/Makefile.in: Change de_DE to de. de is the one that
+	  is active
 	  References #3848 for PostGIS 2.5
 2019-02-21 20:44  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17270] Add extra_float_digits for pg12
+	* [r17270] regress/run_test.pl: Add extra_float_digits for pg12
 2019-02-15 19:00  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17256] Update test running instructions
+	* [r17256] extras/ogc_test_suite/README: Update test running
+	  instructions
 2019-02-15 18:53  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17253] Update OGC certification scripts to match new SFSQL 1.2
-	  signatures
+	* [r17253] extras/ogc_test_suite/1_schema.sql,
+	  extras/ogc_test_suite/2_queries.sql,
+	  extras/ogc_test_suite/Makefile: Update OGC certification scripts
+	  to match new SFSQL 1.2 signatures
 2019-02-11 17:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17237] Add generated file
+	* [r17237] liblwgeom/lwin_wkt_lex.c: Add generated file
-	* [r17236] Add lexer initialization
+	* [r17236] liblwgeom/lwin_wkt_lex.l: Add lexer initialization
 	  References #4017
 2019-02-05 00:41  Regina Obe <lr at pcorp.us>
-	* [r17230] Get rid of sudo -i on the pg11 docker evidentally not
-	  installed
+	* [r17230] .drone-1.0.yml: Get rid of sudo -i on the pg11 docker
+	  evidentally not installed
 2019-02-04 22:45  Regina Obe <lr at pcorp.us>
-	* [r17228] Fix dronie badge (still need to fix build link)
+	* [r17228] README.md: Fix dronie badge (still need to fix build
+	  link)
 2019-01-31 15:49  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17224] PostgreSQL 12 compatibility
+	* [r17224] NEWS, libpgcommon/lwgeom_cache.c,
+	  libpgcommon/lwgeom_cache.h,
+	  postgis/geography_measurement_trees.c,
+	  postgis/geography_measurement_trees.h,
+	  postgis/gserialized_estimate.c, postgis/lwgeom_accum.c,
+	  postgis/lwgeom_geos_prepared.c, postgis/lwgeom_geos_prepared.h,
+	  postgis/lwgeom_rectree.c, postgis/lwgeom_rtree.c,
+	  postgis/lwgeom_rtree.h, raster/rt_pg/rtpg_mapalgebra.c:
+	  PostgreSQL 12 compatibility
 	  Initial patch by Laurenz Albe
 	  References #4313
@@ -71,20 +331,25 @@
 2019-01-30 19:17  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17221] ST_ClipByBox2D: Do not throw when the geometry is
-	  invalid
+	* [r17221] NEWS, liblwgeom/cunit/cu_clip_by_rect.c,
+	  liblwgeom/lwgeom_geos.c, regress/clipbybox2d.sql,
+	  regress/clipbybox2d_expected, regress/mvt.sql,
+	  regress/mvt_expected: ST_ClipByBox2D: Do not throw when the
+	  geometry is invalid
 	  Closes #4314
 2019-01-25 11:52  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17215] PG12 compat: Remove unnecessary header include (tqual.h)
+	* [r17215] postgis/gserialized_estimate.c: PG12 compat: Remove
+	  unnecessary header include (tqual.h)
 	  Closes #4307
 2019-01-22 09:09  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17206] Partially revert r17180
+	* [r17206] extensions/postgis_extension_helper.sql,
+	  postgis/postgis.sql.in: Partially revert r17180
 	  It changed the behaviour of _postgis_pgsql_version
 	  Now uses the appropiate 5-6 digit version from server_version_num
@@ -94,67 +359,77 @@
 2019-01-21 19:52  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17199] Sync generated parser to y file, using newer bison
-	  version
+	* [r17199] liblwgeom/lwin_wkt_parse.c, liblwgeom/lwin_wkt_parse.h:
+	  Sync generated parser to y file, using newer bison version
 2019-01-21 19:24  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17195] Commit generated code to match parser
+	* [r17195] liblwgeom/lwin_wkt_parse.c, liblwgeom/lwin_wkt_parse.h:
+	  Commit generated code to match parser
-	* [r17194] Actually put fix for #4273 in the right place
+	* [r17194] liblwgeom/lwin_wkt_parse.y: Actually put fix for #4273
+	  in the right place
 	  so it isn't blown away when parser.y is evaluated.
 	  References #4273
 2019-01-18 21:57  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17189] Un space
+	* [r17189] NEWS: Un space
 2019-01-18 20:43  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17186] Avoid final point duplicates for circle stroking
+	* [r17186] NEWS, liblwgeom/lwstroke.c: Avoid final point duplicates
+	  for circle stroking
 	  References #4283
 2019-01-18 18:02  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17182] More robust geography distance
+	* [r17182] liblwgeom/lwgeodetic.c: More robust geography distance
 	  References #4290
 2019-01-18 17:24  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17180] Use `server_version_num` instead of parsing `version()`
+	* [r17180] NEWS, extensions/postgis_extension_helper.sql,
+	  postgis/postgis.sql.in: Use `server_version_num` instead of
+	  parsing `version()`
 	  References #4296
 2019-01-18 16:06  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17175] Avoid passing a NULL pointer to GEOSisEmpty
+	* [r17175] NEWS, liblwgeom/lwgeom_geos_clean.c,
+	  liblwgeom/lwgeom_geos_cluster.c: Avoid passing a NULL pointer to
+	  GEOSisEmpty
 	  References #4275
 2019-01-18 11:56  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17172] Correct issue reference from previous commit
+	* [r17172] NEWS: Correct issue reference from previous commit
 	  References #4289
 2019-01-18 11:53  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17170] ST_AsMVTGeom: Transform coordinates space before
-	  clipping
+	* [r17170] NEWS, postgis/mvt.c, regress/mvt.sql,
+	  regress/mvt_expected: ST_AsMVTGeom: Transform coordinates space
+	  before clipping
 	  References #4300
 2019-01-17 23:22  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17168] Use AccessShareLock in spatial_index_read_extent
+	* [r17168] NEWS, postgis/gserialized_estimate.c: Use
+	  AccessShareLock in spatial_index_read_extent
 	  References #4261
 2019-01-17 11:32  Darafei Praliaskouski <me at komzpa.net>
-	* [r17164] ST_Subdivide endless loop on coordinates near coincident
-	  to bounds
+	* [r17164] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
+	  regress/subdivide_expected: ST_Subdivide endless loop on
+	  coordinates near coincident to bounds
 	  Closes #4301
 	  Closes https://github.com/postgis/postgis/pull/361
@@ -161,59 +436,70 @@
 2019-01-16 10:50  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17161] ST_AsMVTGeom: Always return the simplest geometry
+	* [r17161] NEWS, postgis/mvt.c, regress/mvt_expected: ST_AsMVTGeom:
+	  Always return the simplest geometry
 	  Closes #4300
 2019-01-16 09:04  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17159] Tests: Remove warning when building with 32bit arch
+	* [r17159] liblwgeom/cunit/cu_algorithm.c: Tests: Remove warning
+	  when building with 32bit arch
 	  It appeared when investigating #4298
 2019-01-15 22:16  Regina Obe <lr at pcorp.us>
-	* [r17157] Add dronie.osgeo.org agent config (drone 1.0 standard)
+	* [r17157] .drone-1.0.yml: Add dronie.osgeo.org agent config (drone
+	  1.0 standard)
 2019-01-11 12:37  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17135] ST_AsMVT: parse JSON numeric values with decimals as
-	  doubles
+	* [r17135] NEWS, postgis/mvt.c, regress/mvt_jsonb.sql,
+	  regress/mvt_jsonb_expected: ST_AsMVT: parse JSON numeric values
+	  with decimals as doubles
 	  References #4292
 2019-01-10 16:21  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17131] Remove memory leak in "junky wkt" case
+	* [r17131] liblwgeom/lwin_wkt_parse.c: Remove memory leak in "junky
+	  wkt" case
 	  References #4273
 2019-01-09 20:09  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17129] Move fix further into parser, fix bad test case
+	* [r17129] NEWS, liblwgeom/cunit/cu_in_wkt.c,
+	  liblwgeom/cunit/cu_out_x3d.c, liblwgeom/lwin_wkt_parse.c: Move
+	  fix further into parser, fix bad test case
 	  References #4273
 2018-12-26 04:06  Regina Obe <lr at pcorp.us>
-	* [r17119] Fix so custom --with-projdir= configure switch works
-	  again.
+	* [r17119] configure.ac: Fix so custom --with-projdir= configure
+	  switch works again.
 	  References #4279 for PostGIS 2.5
 2018-12-21 05:38  Darafei Praliaskouski <me at komzpa.net>
-	* [r17115] [doc] ST_AsGeoJSON doc refresh
+	* [r17115] NEWS, doc/reference_output.xml: [doc] ST_AsGeoJSON doc
+	  refresh
 	  Closes #4276
 2018-12-17 10:41  Darafei Praliaskouski <me at komzpa.net>
-	* [r17112] Attribute Raúl Marín for help resolving build issue.
+	* [r17112] NEWS: Attribute Raúl Marín for help resolving build
+	  issue.
 	  References #4254
 2018-12-17 10:34  Darafei Praliaskouski <me at komzpa.net>
-	* [r17109] Support Proj 6. Support is via legacy API, we need to
-	  redesign for non-legacy and Proj 7.
+	* [r17109] NEWS, configure.ac, liblwgeom/liblwgeom.h.in,
+	  macros/ac_proj4_version.m4, raster/macros/ac_proj4_version.m4:
+	  Support Proj 6. Support is via legacy API, we need to redesign
+	  for non-legacy and Proj 7.
 	  Closes #4254
 	  Closes https://github.com/postgis/postgis/pull/354
@@ -220,28 +506,35 @@
 2018-11-30 15:01  Regina Obe <lr at pcorp.us>
-	* [r17089] change winnie to build, test, and package using GEOS
-	  3.7.1 instead of GEOS 3.7.0
+	* [r17089] ci/winnie/build_postgis.sh,
+	  ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh:
+	  change winnie to build, test, and package using GEOS 3.7.1
+	  instead of GEOS 3.7.0
 2018-11-29 11:11  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17088] Correct referenfce in NEWS file
+	* [r17088] NEWS: Correct referenfce in NEWS file
 2018-11-29 09:29  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17085] Document MULTISURFACE compatibility of ST_LineToCurve
-	  (Steven Ottens)
+	* [r17085] NEWS, doc/reference_processing.xml: Document
+	  MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
 	  References #4162
 2018-11-27 00:14  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r17078] Change test conditions to look for empty.
+	* [r17078] regress/tickets.sql, regress/tickets_expected: Change
+	  test conditions to look for empty.
 	  References #4245
 2018-11-25 19:28  Darafei Praliaskouski <me at komzpa.net>
-	* [r17074] Stabilize GiST ND indexes for mixed dimensions
+	* [r17074] NEWS, postgis/gserialized_gist_nd.c,
+	  regress/Makefile.in, regress/regress_gist_index_nd.data,
+	  regress/regress_gist_index_nd.sql,
+	  regress/regress_gist_index_nd_expected: Stabilize GiST ND indexes
+	  for mixed dimensions
 	  Patch by Darafei Praliaskouski
@@ -257,18 +550,23 @@
 2018-11-23 17:56  Regina Obe <lr at pcorp.us>
-	* [r17063] Get rid of use of oids in topology regress was taken out
-	  in PostgreSQL 12.
+	* [r17063] topology/test/hierarchy.sql,
+	  topology/test/load_features.sql, topology/test/more_features.sql,
+	  topology/test/predicates.sql.in,
+	  topology/test/regress/topojson.sql: Get rid of use of oids in
+	  topology regress was taken out in PostgreSQL 12.
 	  Closes #4251 for PostGIS 2.5.2
 2018-11-23 07:49  Regina Obe <lr at pcorp.us>
-	* [r17061] Missed a spot in last commit
+	* [r17061] postgis/postgis.sql.in: Missed a spot in last commit
 	  Closes #4231 for postgis 2.5.2
 2018-11-22 21:10  Regina Obe <lr at pcorp.us>
-	* [r17060] Add 2.2.8 to upgrade targets
+	* [r17060] NEWS, extensions/upgradeable_versions.mk,
+	  postgis/postgis.sql.in, raster/rt_pg/rtpostgis.sql.in,
+	  topology/topology.sql.in: Add 2.2.8 to upgrade targets
 	  Remove using of pg_constraint.consrc to allow support of 12 as
 	  noted by Laurenz Albe (pg_constraint.consrc was removed in
 	  12devel)
@@ -276,79 +574,91 @@
 2018-11-22 16:16  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17058] Avoid unaligned memory access in BOX2D_out
+	* [r17058] NEWS, postgis/lwgeom_box.c: Avoid unaligned memory
+	  access in BOX2D_out
 	  References #4244
 2018-11-22 13:43  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17052] Fix undefined behaviour in ST_3DDistance
+	* [r17052] NEWS, liblwgeom/cunit/cu_measures.c,
+	  liblwgeom/measures.h, liblwgeom/measures3d.c,
+	  regress/measures.sql, regress/measures_expected: Fix undefined
+	  behaviour in ST_3DDistance
 	  References #4246
 2018-11-21 14:13  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17042] Fix undefined behaviour in raster intersection
+	* [r17042] NEWS, raster/rt_core/rt_spatial_relationship.c: Fix
+	  undefined behaviour in raster intersection
 	  References #4249
 2018-11-21 11:45  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17037] Avoid undefined behaviour in next_float functions (Raúl
-	  Marín)
+	* [r17037] NEWS, liblwgeom/cunit/cu_libgeom.c,
+	  liblwgeom/lwgeom_api.c: Avoid undefined behaviour in next_float
+	  functions (Raúl Marín)
 	  References #4247
 2018-11-18 21:32  Regina Obe <lr at pcorp.us>
-	* [r17028] Flip to 2.5.2dev
+	* [r17028] Version.config, extensions/upgradeable_versions.mk: Flip
+	  to 2.5.2dev
 2018-11-18 21:29  Regina Obe <lr at pcorp.us>
-	* [r17026] Prep for 2.5.1 for real this time
+	* [r17026] NEWS, Version.config: Prep for 2.5.1 for real this time
 2018-11-18 09:41  Regina Obe <lr at pcorp.us>
-	* [r17025] Flip back to 2.5.1dev until confirm winnie's issues on
-	  #4242 are just winnie's
+	* [r17025] NEWS, Version.config: Flip back to 2.5.1dev until
+	  confirm winnie's issues on #4242 are just winnie's
 2018-11-18 09:19  Regina Obe <lr at pcorp.us>
-	* [r17024] update change log in prep for 2.5.1 release
+	* [r17024] ChangeLog: update change log in prep for 2.5.1 release
 2018-11-18 08:43  Regina Obe <lr at pcorp.us>
-	* [r17023] Prepping for 2.5.1 release
+	* [r17023] HOWTO_RELEASE, NEWS, Version.config,
+	  Prepping for 2.5.1 release
 2018-11-15 16:08  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17021] Avoid undefined behaviour in gserialized_estimate
+	* [r17021] NEWS, postgis/gserialized_estimate.c: Avoid undefined
+	  behaviour in gserialized_estimate
 	  References #4190
 2018-11-15 09:06  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17018] Allocate enough memory in gidx_to_string
+	* [r17018] NEWS, libpgcommon/gserialized_gist.c: Allocate enough
+	  memory in gidx_to_string
 	  References #4236
 2018-11-13 10:47  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17006] Un-break build with debug logs
+	* [r17006] postgis/gserialized_spgist_2d.c: Un-break build with
+	  debug logs
 	  Related to #4235
 2018-11-12 09:15  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r17003] ST_Scale: Document the availability of the origin
-	  parameter
+	* [r17003] doc/reference_editor.xml: ST_Scale: Document the
+	  availability of the origin parameter
 	  References #4232
 2018-11-08 06:57  Darafei Praliaskouski <me at komzpa.net>
-	* [r16997] Documentation for AddRasterConstraint optional
-	  parameters
+	* [r16997] NEWS, doc/reference_raster.xml: Documentation for
+	  AddRasterConstraint optional parameters
 	  Patch by Sunveer Singh
@@ -357,34 +667,37 @@
 2018-11-07 17:56  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16995] Revert change to avoid slicing on box access.
+	* [r16995] NEWS, liblwgeom/g_serialized.c,
+	  postgis/gserialized_gist_2d.c: Revert change to avoid slicing on
+	  box access.
 	  References #4216
 2018-11-07 16:50  Regina Obe <lr at pcorp.us>
-	* [r16992] Get rid of trailing space
+	* [r16992] liblwgeom/lwgeodetic.h: Get rid of trailing space
 2018-11-07 16:27  Regina Obe <lr at pcorp.us>
-	* [r16991] Schema qualify some missed calls in raster plpgsql/sql
-	  functions
+	* [r16991] NEWS, raster/rt_pg/rtpostgis.sql.in: Schema qualify some
+	  missed calls in raster plpgsql/sql functions
 2018-11-06 22:26  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16985] Add name to NEWS
+	* [r16985] NEWS: Add name to NEWS
 2018-11-06 20:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16984] Move to "postgis blue" #468
+	* [r16984] doc/html/style.css: Move to "postgis blue" #468
 2018-11-05 22:46  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16982] Update news for #4223
+	* [r16982] NEWS: Update news for #4223
 2018-11-05 22:36  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16980] Patch over bad behaviour for near-parallel boxes and
-	  distancetree.
+	* [r16980] liblwgeom/cunit/cu_geodetic.c,
+	  liblwgeom/cunit/cu_tree.c, liblwgeom/lwgeodetic.h: Patch over bad
+	  behaviour for near-parallel boxes and distancetree.
 	  Unfortunately, this "fix" is probably breakable, just put the
 	  boxes closer and closer together until we get "close enough to be
 	  the same" results from the edge normal comparison again. Only way
@@ -394,36 +707,44 @@
 2018-11-02 22:15  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16974] Try for a responsive font size?
+	* [r16974] doc/html/style.css: Try for a responsive font size?
 2018-10-30 20:30  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16966] Update icons to new doco versions
+	* [r16966] doc/html/images/check.png,
+	  doc/html/images/important.png, doc/html/images/warning.png:
+	  Update icons to new doco versions
 2018-10-30 19:50  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16965] Change doc target for debbie to be "html-chunked-web"
-	  for google analytics fragment
+	* [r16965] ci/debbie/postgis_release_docs.sh: Change doc target for
+	  debbie to be "html-chunked-web" for google analytics fragment
 2018-10-30 19:47  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16964] Update HTML document styling to new "standard"
+	* [r16964] doc/Makefile.in, doc/html, doc/html/ga.js,
+	  doc/html/style.css: Update HTML document styling to new
+	  "standard"
 2018-10-29 04:10  Darafei Praliaskouski <me at komzpa.net>
-	* [r16957] Fix typo in r16956
+	* [r16957] liblwgeom/lwgeom.c: Fix typo in r16956
 	  Closes #4217
 2018-10-29 03:22  Darafei Praliaskouski <me at komzpa.net>
-	* [r16956] ST_Subdivide: don't crash if on some iteration you need
-	  to subdivide Empty
+	* [r16956] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
+	  regress/subdivide_expected: ST_Subdivide: don't crash if on some
+	  iteration you need to subdivide Empty
 	  Closes #4217
 2018-10-24 14:03  Darafei Praliaskouski <me at komzpa.net>
-	* [r16947] [raster] Use GDALFPolygonize unconditionally
+	* [r16947] .gitignore, NEWS, configure.ac, postgis_config.h.in,
+	  raster/raster_config.h.in, raster/rt_core/rt_geometry.c,
+	  raster/test/cunit/cu_gdal.c: [raster] Use GDALFPolygonize
+	  unconditionally
 	  GDAL 1.10 is already required and 1.9 contains it, so no check
 	  needed.
@@ -432,7 +753,10 @@
 2018-10-23 13:00  Darafei Praliaskouski <me at komzpa.net>
-	* [r16941] [raster] Fix envelope Contains shortcut in ST_Clip
+	* [r16941] NEWS, raster/rt_pg/rtpostgis.sql.in,
+	  raster/test/regress/tickets_expected: [raster] Fix envelope
+	  Contains shortcut in ST_Clip
 	  Patch by Sai-bot
@@ -440,7 +764,9 @@
 2018-10-22 15:26  Darafei Praliaskouski <me at komzpa.net>
-	* [r16938] ST_Subdivide: support rect hole in rect shell
+	* [r16938] NEWS, liblwgeom/lwgeom.c, regress/subdivide.sql,
+	  regress/subdivide_expected: ST_Subdivide: support rect hole in
+	  rect shell
 	  Closes #4211
 	  Closes https://github.com/postgis/postgis/pull/317
@@ -447,7 +773,8 @@
 2018-10-17 14:25  Sandro Santilli <strk at kbt.io>
-	* [r16918] Fix support for PostgreSQL-12 ("getrelid" macro removed)
+	* [r16918] NEWS, postgis/gserialized_estimate.c: Fix support for
+	  PostgreSQL-12 ("getrelid" macro removed)
 	  The call is replaced with its expansion which should work
 	  as back as PostgreSQL-9.1 which is before the oldest version
@@ -461,35 +788,39 @@
 2018-10-15 11:46  Sandro Santilli <strk at kbt.io>
-	* [r16910] Only drop function IF EXISTS ...
+	* [r16910] topology/topology_drop_before.sql.in: Only drop function
+	  IF EXISTS ...
 2018-10-15 10:38  Sandro Santilli <strk at kbt.io>
-	* [r16901] [topology] properly drop removed internal functions on
-	  upgrade
+	* [r16901] NEWS, topology/topology_drop_before.sql.in: [topology]
+	  properly drop removed internal functions on upgrade
 	  References #4202 in 2.5 branch
 2018-10-08 23:19  Regina Obe <lr at pcorp.us>
-	* [r16879] Fix packaging, was copying over old extension files
+	* [r16879] ci/winnie/package_postgis.sh: Fix packaging, was copying
+	  over old extension files
 2018-10-03 11:11  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16877] St_AsMVTGeom: Handle type changes in geometry
-	  collections
+	* [r16877] postgis/mvt.c, regress/mvt.sql, regress/mvt_expected:
+	  St_AsMVTGeom: Handle type changes in geometry collections
 	  References #4181
 2018-10-02 11:41  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16870] Fix undefined behaviour in ptarray_clone_deep
+	* [r16870] NEWS, liblwgeom/ptarray.c: Fix undefined behaviour in
+	  ptarray_clone_deep
 	  References #4191
 2018-10-02 09:37  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16862] Fix undefined behaviour in SADFWrite
+	* [r16862] NEWS, liblwgeom/lwutil.c, loader/pgsql2shp-core.c,
+	  loader/safileio.c: Fix undefined behaviour in SADFWrite
 	  Also addresses several gcc warnings
 	  References #4189
@@ -496,17 +827,20 @@
 2018-10-02 07:23  Regina Obe <lr at pcorp.us>
-	* [r16861] Fix packaging link - broke it on last change
+	* [r16861] ci/winnie/package_postgis.sh: Fix packaging link - broke
+	  it on last change
 2018-10-01 15:55  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16859] Avoid division by zero in kmeans
+	* [r16859] NEWS, liblwgeom/lwkmeans.c: Avoid division by zero in
+	  kmeans
 	  References #4188
 2018-10-01 13:31  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16857] St_AsMVTGeom: Drop invalid geometries after
+	* [r16857] NEWS, postgis/mvt.c, regress/mvt.sql,
+	  regress/mvt_expected: St_AsMVTGeom: Drop invalid geometries after
 	  simplification
 	  References #4183
@@ -513,20 +847,23 @@
 2018-10-01 06:05  Regina Obe <lr at pcorp.us>
-	* [r16853] fix windows links should point at postgis.net and not
-	  postgis.org
+	* [r16853] doc/installation.xml: fix windows links should point at
+	  postgis.net and not postgis.org
 2018-09-26 12:18  Regina Obe <lr at pcorp.us>
-	* [r16843] fix packaging so doesn't include old extension files
+	* [r16843] ci/winnie/package_postgis.sh: fix packaging so doesn't
+	  include old extension files
 2018-09-24 01:07  Regina Obe <lr at pcorp.us>
-	* [r16837] flip to 2.5.1dev
+	* [r16837] Version.config, extensions/upgradeable_versions.mk: flip
+	  to 2.5.1dev
 2018-09-23 20:04  Regina Obe <lr at pcorp.us>
-	* [r16835] Stamp date of release.
+	* [r16835] NEWS, doc/release_notes.xml, raster/rt_pg/rtpg_inout.c:
+	  Stamp date of release.
 	  Put in legacy stub function for RASTER_to_binary to allow pg
 	  upgrade (newer lib)
 	  Closes #4097
@@ -533,22 +870,27 @@
 2018-09-23 15:03  Regina Obe <lr at pcorp.us>
-	* [r16834] update changelog in prep for PostGIS 2.5.0 release
+	* [r16834] ChangeLog: update changelog in prep for PostGIS 2.5.0
+	  release
 2018-09-23 01:07  Regina Obe <lr at pcorp.us>
-	* [r16833] Prep for 2.5.0 release
+	* [r16833] NEWS, Version.config, doc/release_notes.xml,
+	  extensions/upgradeable_versions.mk: Prep for 2.5.0 release
 2018-09-22 13:06  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16832] St_AsMVTGeom: Avoid type changes due to validation
+	* [r16832] NEWS, postgis/mvt.c, regress/mvt.sql,
+	  regress/mvt_expected: St_AsMVTGeom: Avoid type changes due to
+	  validation
 	  References #4181
 2018-09-21 13:20  Darafei Praliaskouski <me at komzpa.net>
-	* [r16827] ST_ChaikinSmoothing: also smooth start/end point of
-	  polygon by default
+	* [r16827] doc/reference_processing.xml, postgis/postgis.sql.in:
+	  ST_ChaikinSmoothing: also smooth start/end point of polygon by
+	  default
 	  Closes #4156
 	  Closes https://github.com/postgis/postgis/pull/305
@@ -555,37 +897,44 @@
 2018-09-17 05:05  Regina Obe <lr at pcorp.us>
-	* [r16823] Flip version to 2.5.0rc3dev
+	* [r16823] Version.config, extensions/upgradeable_versions.mk: Flip
+	  version to 2.5.0rc3dev
 2018-09-17 03:01  Regina Obe <lr at pcorp.us>
-	* [r16821] Add upgrade path from 2.4.5
+	* [r16821] extensions/upgradeable_versions.mk: Add upgrade path
+	  from 2.4.5
 2018-09-17 02:44  Regina Obe <lr at pcorp.us>
-	* [r16819] Fix parse errors in po files. Update ChangeLog in prep
-	  for release
+	* [r16819] ChangeLog, doc/po/es/extras_topology.xml.po,
+	  doc/po/ko_KR/reference_raster.xml.po: Fix parse errors in po
+	  files. Update ChangeLog in prep for release
 2018-09-16 23:58  Regina Obe <lr at pcorp.us>
-	* [r16816] Replace long tag with short-tag for xref ST_MemSize. Was
-	  causing problems with po conversion.
+	* [r16816] doc/po/templates/postgis.xml.pot,
+	  doc/po/templates/reference_editor.xml.pot,
+	  doc/reference_editor.xml: Replace long tag with short-tag for
+	  xref ST_MemSize. Was causing problems with po conversion.
 	  Update pots (including getting rid of SVN)
 2018-09-16 21:52  Regina Obe <lr at pcorp.us>
-	* [r16815] Prepping for 2.5.0 release
+	* [r16815] NEWS, Version.config: Prepping for 2.5.0 release
 2018-09-16 21:36  Regina Obe <lr at pcorp.us>
-	* [r16814] Move geofromjson test from tickets to in_geojson so
-	  JSON-C guard can be applied.
+	* [r16814] regress/in_geojson.sql, regress/in_geojson_expected,
+	  regress/tickets.sql, regress/tickets_expected: Move geofromjson
+	  test from tickets to in_geojson so JSON-C guard can be applied.
 	  Closes #4178 for PostGIS 2.5.0
 2018-09-16 20:24  Regina Obe <lr at pcorp.us>
-	* [r16813] Try to force liblwgeom source include to be referenced
-	  first before the installed locations.
+	* [r16813] doc/html/image_src/Makefile.in,
+	  raster/rt_pg/Makefile.in: Try to force liblwgeom source include
+	  to be referenced first before the installed locations.
 	  When installed, the installed one sometimes gets picked up
 	  instead of the source one.
 	  References #4180
@@ -592,40 +941,96 @@
 2018-09-16 18:51  Regina Obe <lr at pcorp.us>
-	* [r16811] remove de_DE, it's redundant with de which is more
-	  complete.
+	* [r16811] ci/debbie/postgis_doc_translations.sh,
+	  doc/po/de/reference_editor.xml.po,
+	  doc/po/de/reference_type.xml.po, doc/po/de/reporting.xml.po,
+	  doc/po/de_DE, doc/po/es/extras_historytable.xml.po,
+	  doc/po/es/extras_tigergeocoder.xml.po,
+	  doc/po/es/extras_topology.xml.po, doc/po/es/faq.xml.po,
+	  doc/po/es/faq_raster.xml.po, doc/po/es/installation.xml.po,
+	  doc/po/es/introduction.xml.po, doc/po/es/postgis.xml.po,
+	  doc/po/es/reference_accessor.xml.po,
+	  doc/po/es/reference_constructor.xml.po,
+	  doc/po/es/reference_editor.xml.po,
+	  doc/po/es/reference_lrs.xml.po,
+	  doc/po/es/reference_management.xml.po,
+	  doc/po/es/reference_measure.xml.po,
+	  doc/po/es/reference_misc.xml.po,
+	  doc/po/es/reference_operator.xml.po,
+	  doc/po/es/reference_output.xml.po,
+	  doc/po/es/reference_processing.xml.po,
+	  doc/po/es/reference_raster.xml.po,
+	  doc/po/es/release_notes.xml.po, doc/po/fr/installation.xml.po,
+	  doc/po/fr/postgis.xml.po, doc/po/fr/reference_editor.xml.po,
+	  doc/po/fr/reference_measure.xml.po,
+	  doc/po/fr/reference_misc.xml.po,
+	  doc/po/it_IT/installation.xml.po, doc/po/it_IT/postgis.xml.po,
+	  doc/po/it_IT/reference_editor.xml.po,
+	  doc/po/it_IT/reference_measure.xml.po,
+	  doc/po/it_IT/reference_misc.xml.po,
+	  doc/po/ja/installation.xml.po, doc/po/ja/postgis.xml.po,
+	  doc/po/ja/reference_editor.xml.po,
+	  doc/po/ja/reference_measure.xml.po,
+	  doc/po/ja/reference_misc.xml.po,
+	  doc/po/ko_KR/installation.xml.po, doc/po/ko_KR/postgis.xml.po,
+	  doc/po/ko_KR/reference_editor.xml.po,
+	  doc/po/ko_KR/reference_measure.xml.po,
+	  doc/po/ko_KR/reference_misc.xml.po,
+	  doc/po/pl/installation.xml.po, doc/po/pl/postgis.xml.po,
+	  doc/po/pl/reference_editor.xml.po,
+	  doc/po/pl/reference_measure.xml.po,
+	  doc/po/pl/reference_misc.xml.po,
+	  doc/po/pt_BR/installation.xml.po, doc/po/pt_BR/postgis.xml.po,
+	  doc/po/pt_BR/reference_editor.xml.po,
+	  doc/po/pt_BR/reference_measure.xml.po,
+	  doc/po/pt_BR/reference_misc.xml.po, doc/release_notes.xml,
+	  extensions/upgradeable_versions.mk: remove de_DE, it's redundant
+	  with de which is more complete.
 	  Update all the po files (pulled from transifex)
 	  References #3848
 2018-09-16 16:18  Regina Obe <lr at pcorp.us>
-	* [r16809] Update pot files
+	* [r16809] doc/po/templates/installation.xml.pot,
+	  doc/po/templates/postgis.xml.pot,
+	  doc/po/templates/reference_measure.xml.pot,
+	  doc/po/templates/reference_misc.xml.pot: Update pot files
 2018-09-16 05:12  Regina Obe <lr at pcorp.us>
-	* [r16806] Document that LLV >= 6 is required for JIT compiles.
+	* [r16806] NEWS, doc/installation.xml: Document that LLV >= 6 is
+	  required for JIT compiles.
 	  Closes #4125 for PostGIS 2.5.0
 2018-09-14 16:13  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16802] Use qualified names in topology extension install
+	* [r16802] NEWS,
+	  extensions/postgis_topology/sql_bits/mark_editable_objects.sql.in:
+	  Use qualified names in topology extension install
 	  References #4160
 2018-09-13 20:28  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16786] Handle almost-infinite features when building table
-	  statistics in ANALYZE
+	* [r16786] postgis/gserialized_estimate.c, regress/tickets.sql,
+	  regress/tickets_expected: Handle almost-infinite features when
+	  building table statistics in ANALYZE
 	  References #4144
 2018-09-13 19:25  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16784] Avoid array overflow in ANALYZE (References #2985)
+	* [r16784] postgis/gserialized_estimate.c: Avoid array overflow in
+	  ANALYZE (References #2985)
 2018-09-13 17:25  Darafei Praliaskouski <me at komzpa.net>
-	* [r16779] Postgres 12 disallows variable length arrays in C,
-	  raster part
+	* [r16779] raster/rt_pg/rtpg_band_properties.c,
+	  raster/rt_pg/rtpg_gdal.c, raster/rt_pg/rtpg_geometry.c,
+	  raster/rt_pg/rtpg_mapalgebra.c, raster/rt_pg/rtpg_pixel.c,
+	  raster/rt_pg/rtpg_raster_properties.c,
+	  raster/rt_pg/rtpg_statistics.c: Postgres 12 disallows variable
+	  length arrays in C, raster part
 	  Patch by Laurenz Albe
@@ -633,7 +1038,8 @@
 2018-09-13 14:57  Darafei Praliaskouski <me at komzpa.net>
-	* [r16778] Postgres 12 disallows variable length arrays in C
+	* [r16778] NEWS, postgis/gserialized_estimate.c: Postgres 12
+	  disallows variable length arrays in C
@@ -641,7 +1047,9 @@
 2018-09-13 13:29  Darafei Praliaskouski <me at komzpa.net>
-	* [r16773] ST_Interscts support GEOMETRYCOLLECTION
+	* [r16773] NEWS, doc/reference_measure.xml, postgis/lwgeom_geos.c,
+	  regress/tickets.sql, regress/tickets_expected: ST_Interscts
+	  support GEOMETRYCOLLECTION
 	  By some overlook ST_Intersects has a guard against
 	  GEOMETRYCOLLECTION, while GEOS can handle it.
@@ -651,47 +1059,56 @@
 2018-09-13 13:25  Darafei Praliaskouski <me at komzpa.net>
-	* [r16772] Add NEWS entry.
+	* [r16772] NEWS: Add NEWS entry.
 	  References #4164
 2018-09-11 06:07  Regina Obe <lr at pcorp.us>
-	* [r16728] Get rid of note that 3.7.0 is not released. Switch
+	* [r16728] ci/winnie/build_postgis.sh,
+	  ci/winnie/package_postgis.sh, ci/winnie/regress_postgis.sh,
+	  configure.ac: Get rid of note that 3.7.0 is not released. Switch
 	  winnie to test and packaged released 3.7.0
 2018-09-10 22:27  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16726] NL warning and add regression test
+	* [r16726] liblwgeom/cunit/cu_in_geojson.c,
+	  liblwgeom/lwin_geojson.c, regress/tickets.sql,
+	  regress/tickets_expected: NL warning and add regression test
 	  References #4164
 2018-09-10 22:18  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16724] Parse error on incorrectly nested GeoJSON input
+	* [r16724] liblwgeom/cunit/cu_in_geojson.c,
+	  liblwgeom/lwin_geojson.c: Parse error on incorrectly nested
+	  GeoJSON input
 	  References #4164
 2018-09-07 10:57  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16721] Fix memory leak in lwgeom_offsetcurve
+	* [r16721] NEWS, liblwgeom/lwgeom_geos.c: Fix memory leak in
+	  lwgeom_offsetcurve
 	  References #4172
 2018-09-06 20:17  Paul Ramsey <pramsey at cleverelephant.ca>
-	* [r16716] Increase double printing buffer, and strip out assertion
-	  that buffer is never filled
+	* [r16716] liblwgeom/lwout_wkt.c, liblwgeom/lwprint.c: Increase
+	  double printing buffer, and strip out assertion that buffer is
+	  never filled
 	  (References #4165)
 2018-08-29 09:28  Raúl Marín Rodríguez <rmrodriguez at carto.com>
-	* [r16709] MVT: Fix resource leak when the first geometry is NULL
+	* [r16709] NEWS, postgis/mvt.c: MVT: Fix resource leak when the
+	  first geometry is NULL
 	  References #4163
 2018-08-28 07:51  Darafei Praliaskouski <me at komzpa.net>
-	* [r16707] Clarify ST_DWithin usage when table stores a point and a
-	  radius.
+	* [r16707] NEWS, doc/reference_measure.xml: Clarify ST_DWithin
+	  usage when table stores a point and a radius.
 	  Added after IRC discussion.
 	  Thanks github user Boscop for questions and review.
@@ -701,17 +1118,142 @@
 2018-08-28 07:25  Regina Obe <lr at pcorp.us>
-	* [r16705] Move ST_QuantizeCoordinates from miscellaneous to
-	  Editors and fix the first example
+	* [r16705] doc/reference_editor.xml, doc/reference_misc.xml: Move
+	  ST_QuantizeCoordinates from miscellaneous to Editors and fix the
+	  first example
 2018-08-19 22:16  Regina Obe <lr at pcorp.us>
-	* [r16700] update translation files, bump version to 2.5.0rc2dev,
-	  update badges
+	* [r16700] README.md, Version.config,
+	  doc/po/de_DE/extras_topology.xml.po, doc/po/de_DE/faq.xml.po,
+	  doc/po/de_DE/faq_raster.xml.po, doc/po/de_DE/installation.xml.po,
+	  doc/po/de_DE/introduction.xml.po,
+	  doc/po/de_DE/reference_accessor.xml.po,
+	  doc/po/de_DE/reference_constructor.xml.po,
+	  doc/po/de_DE/reference_editor.xml.po,
+	  doc/po/de_DE/reference_lrs.xml.po,
+	  doc/po/de_DE/reference_management.xml.po,
+	  doc/po/de_DE/reference_measure.xml.po,
+	  doc/po/de_DE/reference_misc.xml.po,
+	  doc/po/de_DE/reference_processing.xml.po,
+	  doc/po/de_DE/reference_raster.xml.po,
+	  doc/po/de_DE/release_notes.xml.po,
+	  doc/po/fr/extras_address_standardizer.xml.po,
+	  doc/po/fr/extras_historytable.xml.po,
+	  doc/po/fr/extras_tigergeocoder.xml.po,
+	  doc/po/fr/extras_topology.xml.po, doc/po/fr/faq.xml.po,
+	  doc/po/fr/faq_raster.xml.po, doc/po/fr/installation.xml.po,
+	  doc/po/fr/introduction.xml.po,
+	  doc/po/fr/reference_accessor.xml.po,
+	  doc/po/fr/reference_constructor.xml.po,
+	  doc/po/fr/reference_editor.xml.po,
+	  doc/po/fr/reference_lrs.xml.po,
+	  doc/po/fr/reference_management.xml.po,
+	  doc/po/fr/reference_processing.xml.po,
+	  doc/po/fr/reference_raster.xml.po,
+	  doc/po/fr/release_notes.xml.po,
+	  doc/po/it_IT/extras_address_standardizer.xml.po,
+	  doc/po/it_IT/extras_historytable.xml.po,
+	  doc/po/it_IT/extras_tigergeocoder.xml.po,
+	  doc/po/it_IT/extras_topology.xml.po, doc/po/it_IT/faq.xml.po,
+	  doc/po/it_IT/faq_raster.xml.po, doc/po/it_IT/installation.xml.po,
+	  doc/po/it_IT/introduction.xml.po,
+	  doc/po/it_IT/reference_accessor.xml.po,
+	  doc/po/it_IT/reference_constructor.xml.po,
+	  doc/po/it_IT/reference_guc.xml.po,
+	  doc/po/it_IT/reference_lrs.xml.po,
+	  doc/po/it_IT/reference_processing.xml.po,
+	  doc/po/it_IT/reference_raster.xml.po,
+	  doc/po/it_IT/release_notes.xml.po, doc/po/ja/faq.xml.po,
+	  doc/po/ja/faq_raster.xml.po, doc/po/ja/installation.xml.po,
+	  doc/po/ja/introduction.xml.po,
+	  doc/po/ja/reference_accessor.xml.po,
+	  doc/po/ja/reference_constructor.xml.po,
+	  doc/po/ja/reference_guc.xml.po, doc/po/ja/reference_lrs.xml.po,
+	  doc/po/ja/reference_management.xml.po,
+	  doc/po/ja/reference_output.xml.po,
+	  doc/po/ja/reference_processing.xml.po,
+	  doc/po/ja/reference_raster.xml.po,
+	  doc/po/ja/reference_sfcgal.xml.po,
+	  doc/po/ja/reference_type.xml.po, doc/po/ja/release_notes.xml.po,
+	  doc/po/ko_KR/extras_address_standardizer.xml.po,
+	  doc/po/ko_KR/extras_historytable.xml.po,
+	  doc/po/ko_KR/extras_tigergeocoder.xml.po,
+	  doc/po/ko_KR/extras_topology.xml.po, doc/po/ko_KR/faq.xml.po,
+	  doc/po/ko_KR/faq_raster.xml.po, doc/po/ko_KR/installation.xml.po,
+	  doc/po/ko_KR/introduction.xml.po,
+	  doc/po/ko_KR/reference_accessor.xml.po,
+	  doc/po/ko_KR/reference_constructor.xml.po,
+	  doc/po/ko_KR/reference_exception.xml.po,
+	  doc/po/ko_KR/reference_guc.xml.po,
+	  doc/po/ko_KR/reference_lrs.xml.po,
+	  doc/po/ko_KR/reference_management.xml.po,
+	  doc/po/ko_KR/reference_operator.xml.po,
+	  doc/po/ko_KR/reference_output.xml.po,
+	  doc/po/ko_KR/reference_processing.xml.po,
+	  doc/po/ko_KR/reference_raster.xml.po,
+	  doc/po/ko_KR/reference_sfcgal.xml.po,
+	  doc/po/ko_KR/reference_transaction.xml.po,
+	  doc/po/ko_KR/reference_type.xml.po,
+	  doc/po/ko_KR/release_notes.xml.po,
+	  doc/po/pl/extras_address_standardizer.xml.po,
+	  doc/po/pl/extras_historytable.xml.po,
+	  doc/po/pl/extras_tigergeocoder.xml.po,
+	  doc/po/pl/extras_topology.xml.po, doc/po/pl/faq.xml.po,
+	  doc/po/pl/faq_raster.xml.po, doc/po/pl/installation.xml.po,
+	  doc/po/pl/introduction.xml.po,
+	  doc/po/pl/reference_accessor.xml.po,
+	  doc/po/pl/reference_constructor.xml.po,
+	  doc/po/pl/reference_guc.xml.po, doc/po/pl/reference_lrs.xml.po,
+	  doc/po/pl/reference_management.xml.po,
+	  doc/po/pl/reference_output.xml.po,
+	  doc/po/pl/reference_processing.xml.po,
+	  doc/po/pl/reference_raster.xml.po,
+	  doc/po/pl/reference_sfcgal.xml.po,
+	  doc/po/pl/reference_transaction.xml.po,
+	  doc/po/pl/reference_type.xml.po, doc/po/pl/release_notes.xml.po,
+	  doc/po/pl/using_postgis_app.xml.po,
+	  doc/po/pl/using_postgis_dataman.xml.po,
+	  doc/po/pt_BR/extras_address_standardizer.xml.po,
+	  doc/po/pt_BR/extras_tigergeocoder.xml.po,
+	  doc/po/pt_BR/extras_topology.xml.po, doc/po/pt_BR/faq.xml.po,
+	  doc/po/pt_BR/faq_raster.xml.po, doc/po/pt_BR/installation.xml.po,
+	  doc/po/pt_BR/introduction.xml.po,
+	  doc/po/pt_BR/reference_accessor.xml.po,
+	  doc/po/pt_BR/reference_constructor.xml.po,
+	  doc/po/pt_BR/reference_exception.xml.po,
+	  doc/po/pt_BR/reference_lrs.xml.po,
+	  doc/po/pt_BR/reference_management.xml.po,
+	  doc/po/pt_BR/reference_operator.xml.po,
+	  doc/po/pt_BR/reference_output.xml.po,
+	  doc/po/pt_BR/reference_processing.xml.po,
+	  doc/po/pt_BR/reference_raster.xml.po,
+	  doc/po/pt_BR/reference_sfcgal.xml.po,
+	  doc/po/pt_BR/reference_type.xml.po,
+	  doc/po/pt_BR/release_notes.xml.po,
+	  doc/po/pt_BR/using_postgis_dataman.xml.po,
+	  doc/po/templates/reference_accessor.xml.pot,
+	  doc/po/templates/reference_processing.xml.pot,
+	  doc/po/templates/reference_raster.xml.pot,
+	  doc/po/templates/release_notes.xml.pot: update translation files,
+	  bump version to 2.5.0rc2dev, update badges
 2018-08-19 21:41  Regina Obe <lr at pcorp.us>
-	* [r16698] Branch 2.5
+	* [r16698] .: Branch 2.5
 2018-08-19 15:09  Regina Obe <lr at pcorp.us>
Modified: branches/2.5/NEWS
--- branches/2.5/NEWS	2019-08-11 05:25:14 UTC (rev 17697)
+++ branches/2.5/NEWS	2019-08-11 05:43:01 UTC (rev 17698)
@@ -1,5 +1,5 @@
 PostGIS 2.5.3
-2019/08/xx
+2019/08/11
  * Bug fixes *
Modified: branches/2.5/Version.config
--- branches/2.5/Version.config	2019-08-11 05:25:14 UTC (rev 17697)
+++ branches/2.5/Version.config	2019-08-11 05:43:01 UTC (rev 17698)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=2
 POSTGIS_MINOR_VERSION=5
-POSTGIS_MICRO_VERSION=3dev
+POSTGIS_MICRO_VERSION=3
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: branches/2.5/doc/release_notes.xml
--- branches/2.5/doc/release_notes.xml	2019-08-11 05:25:14 UTC (rev 17697)
+++ branches/2.5/doc/release_notes.xml	2019-08-11 05:43:01 UTC (rev 17698)
@@ -5,7 +5,7 @@
     <sect1>
       <title>Release 2.5.3</title>
-      <para>Release date: 2019/08/10</para>
+      <para>Release date: 2019/08/11</para>
       <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
       <para>Supported PostgreSQL versions for this release are:
       PostgreSQL 9.4 - PostgreSQL 11, GEOS >= 3.5</para>
Modified: branches/2.5/extensions/upgradeable_versions.mk
--- branches/2.5/extensions/upgradeable_versions.mk	2019-08-11 05:25:14 UTC (rev 17697)
+++ branches/2.5/extensions/upgradeable_versions.mk	2019-08-11 05:43:01 UTC (rev 17698)
@@ -36,6 +36,7 @@
 	2.3.7 \
 	2.3.8 \
 	2.3.9 \
+	2.3.10 \
 	2.4.0 \
 	2.4.1 \
 	2.4.2 \
@@ -44,6 +45,7 @@
 	2.4.5 \
 	2.4.6 \
 	2.4.7 \
+	2.4.8 \
 	2.5.0 \
 	2.5.1 \
 	2.5.2
