[postgis-tickets] r17701 - Prep for 3.0.0alpha4 release
Regina Obe lr at pcorp.us
Sat Aug 10 11:15:14 PDT 2019
Author: robe
Date: 2019-08-10 23:15:14 -0700 (Sat, 10 Aug 2019)
New Revision: 17701
   trunk/Version.config
   trunk/doc/release_notes.xml
Modified: trunk/Version.config
--- trunk/Version.config	2019-08-11 06:14:36 UTC (rev 17700)
+++ trunk/Version.config	2019-08-11 06:15:14 UTC (rev 17701)
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=0
-POSTGIS_MICRO_VERSION=0alpha4dev
+POSTGIS_MICRO_VERSION=0alpha4
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
Modified: trunk/doc/release_notes.xml
--- trunk/doc/release_notes.xml	2019-08-11 06:14:36 UTC (rev 17700)
+++ trunk/doc/release_notes.xml	2019-08-11 06:15:14 UTC (rev 17701)
@@ -4,7 +4,7 @@
     <subtitle>Release Notes</subtitle>
     <sect1>
       <title>Release 3.0.0alpha4</title>
-      <para>Release date: 2019/08/10</para>
+      <para>Release date: 2019/08/11</para>
       <para>If compiling with PostgreSQL+JIT, LLVM >= 6 is required</para>
       <para>Supported PostgreSQL versions for this release are:
       PostgreSQL 9.5 - PostgreSQL 12
