[postgis-tickets] [PostGIS] #4478: dronie has a bad bot
trac at osgeo.org
Sun Aug 11 13:16:38 PDT 2019
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: Management 2.0
Component: buildbots | Version: 2.5.x
Keywords: |
I haven't looked at the sql table to see what bad actor is causing this:
pg-9.5: Error response from daemon: OCI runtime create failed:
container_linux.go:345: starting container process caused
"process_linux.go:430: container init caused \"join session keyring:
create session key: disk quota exceeded\"": unknown
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4478>
