[postgis-tickets] [PostGIS] #4479: geos38: ERROR: lwgeom_pointonsurface: GEOS Error: TopologyException: Input geom 1 is invalid: Self-intersection
PostGIS trac at osgeo.org
Mon Aug 12 05:28:58 PDT 2019
  Reporter:  myon     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 2.5.3
 Component:  postgis  |    Version:  2.5.x
Resolution:           |   Keywords:
Comment (by komzpa):
 Hi! Test that fails is GEOS 3.8 test. According to log, GEOS is
 3.7.2-CAPI-1.11.2. This is expected behavior, as you are seemingly testing
 on non-configured Makefile.in. The Makefile without .in after configure
 run should not have these lines for GEOS 3.7.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4479#comment:1>
