[postgis-tickets] r17707 - Lower default precision produced by ST_AsGeoJSON
Paul Ramsey
pramsey at cleverelephant.ca
Tue Aug 13 11:00:13 PDT 2019
Author: pramsey
Date: 2019-08-13 11:00:13 -0700 (Tue, 13 Aug 2019)
New Revision: 17707
trunk/postgis/geography.sql.in
trunk/postgis/postgis.sql.in
References #4468
Modified: trunk/postgis/geography.sql.in
--- trunk/postgis/geography.sql.in 2019-08-13 16:59:20 UTC (rev 17706)
+++ trunk/postgis/geography.sql.in 2019-08-13 18:00:13 UTC (rev 17707)
@@ -466,7 +466,7 @@
-- GeoJson Output
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(geog geography, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 0)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(geog geography, maxdecimaldigits int4 DEFAULT 9, options int4 DEFAULT 0)
RETURNS text
AS 'MODULE_PATHNAME','geography_as_geojson'
LANGUAGE 'c' IMMUTABLE STRICT _PARALLEL
@@ -476,7 +476,7 @@
-- Deprecated in 2.0.0
CREATE OR REPLACE FUNCTION ST_AsGeoJson(text)
RETURNS text AS
- $$ SELECT @extschema at .ST_AsGeoJson($1::@extschema at .geometry,15,0); $$
+ $$ SELECT @extschema at .ST_AsGeoJson($1::@extschema at .geometry, 9, 0); $$
LANGUAGE 'sql' IMMUTABLE STRICT _PARALLEL;
Modified: trunk/postgis/postgis.sql.in
--- trunk/postgis/postgis.sql.in 2019-08-13 16:59:20 UTC (rev 17706)
+++ trunk/postgis/postgis.sql.in 2019-08-13 18:00:13 UTC (rev 17707)
@@ -4602,7 +4602,7 @@
-- ST_AsGeoJson(geom, precision, options) / version=1
-- Changed: 2.0.0 to use default args and named args
-- Changed: 3.0.0 change default args mode
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEFAULT 15, options int4 DEFAULT 8)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(geom geometry, maxdecimaldigits int4 DEFAULT 9, options int4 DEFAULT 8)
RETURNS text
AS 'MODULE_PATHNAME','LWGEOM_asGeoJson'
@@ -4609,7 +4609,7 @@
_COST_LOW;
-- Availability: 3.0.0
-CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 15, pretty_bool bool DEFAULT false)
+CREATE OR REPLACE FUNCTION ST_AsGeoJson(r record, geom_column text DEFAULT '', maxdecimaldigits int4 DEFAULT 9, pretty_bool bool DEFAULT false)
RETURNS text
AS 'MODULE_PATHNAME','ST_AsGeoJsonRow'
LANGUAGE 'c' STABLE STRICT _PARALLEL
