[postgis-tickets] r17708 - Update ST_AsGeoJSON doco to harmonize number of digits default
Paul Ramsey
pramsey at cleverelephant.ca
Tue Aug 13 01:54:19 PDT 2019
Author: pramsey
Date: 2019-08-13 13:54:18 -0700 (Tue, 13 Aug 2019)
New Revision: 17708
trunk/doc/reference_output.xml
Modified: trunk/doc/reference_output.xml
--- trunk/doc/reference_output.xml 2019-08-13 18:00:13 UTC (rev 17707)
+++ trunk/doc/reference_output.xml 2019-08-13 20:54:18 UTC (rev 17708)
@@ -548,19 +548,19 @@
<funcdef>text <function>ST_AsGeoJSON</function></funcdef>
<paramdef><type>record </type> <parameter>feature</parameter></paramdef>
<paramdef choice="opt"><type>text </type> <parameter>geomcolumnname</parameter></paramdef>
- <paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=15</parameter></paramdef>
+ <paramdef choice="opt"><type>integer </type> <parameter>maxdecimaldigits=9</parameter></paramdef>
<paramdef choice="opt"><type>boolean </type> <parameter>pretty_bool=false</parameter></paramdef>
</funcprototype>
<funcprototype>
<paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
<paramdef choice="opt"><type>integer </type> <parameter>options=8</parameter></paramdef>
</funcprototype>
<funcprototype>
<paramdef><type>geography </type> <parameter>geog</parameter></paramdef>
<paramdef choice="opt"><type>integer </type> <parameter>options=0</parameter></paramdef>
</funcprototype>
</funcsynopsis>
@@ -572,7 +572,7 @@
<para>Return the geometry as a GeoJSON "geometry" object, or the row as a GeoJSON "feature" object. (Cf <ulink
url="https://tools.ietf.org/html/rfc7946">GeoJSON specifications RFC 7946</ulink>). 2D and 3D Geometries are both supported. GeoJSON only support SFS 1.1 geometry types (no curve support for example).</para>
- <para>The <varname>maxdecimaldigits</varname> argument may be used to reduce the maximum number of decimal places used in output (defaults to 15). If you are using EPSG:4326 and are outputting the geometry only for display, <varname>maxdecimaldigits</varname>=6 can be a good choice for many maps.</para>
+ <para>The <varname>maxdecimaldigits</varname> argument may be used to reduce the maximum number of decimal places used in output (defaults to 9). If you are using EPSG:4326 and are outputting the geometry only for display, <varname>maxdecimaldigits</varname>=6 can be a good choice for many maps.</para>
<para>The <varname>options</varname> argument could be used to add BBOX or CRS in GeoJSON output:
<itemizedlist>
