[postgis-tickets] [PostGIS] #4482: Missing dependencies
PostGIS trac at osgeo.org
Tue Aug 13 15:16:39 PDT 2019
 Reporter:  joshuabogue  |      Owner:  pramsey
     Type:  defect       |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 2.5.4
Component:  postgis      |    Version:  2.5.x
 Keywords:               |
 I first installed version 11.5 for postgres on Windows 10 x64 version.  I
 installed version 2.5.2 of postgis using the stack builder option.
 Next I tried creating a database and I kept getting the message 'Could not
 load library "C:/Program Files/PostgreSQL/11/lib/rtpostgis-2.5.dll": The
 specified module could not be found.'
 So I spend a good part of the day trying to get the plugin to work.
 Different versions, computers, manual installing postgis, and a lot of
 other things.
 I finally found using a dependency walker replacment from
 "https://github.com/lucasg/Dependencies" that I needed a reference to
 "libeay32.dll" and "ssleay32.dll" so I copied out of the postgisgui folder
 to the posgres bin folder and the command "CREATE EXTENSION posgis"
 succeded.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4482>
