[postgis-tickets] [PostGIS] #4483: Can't upgrade from PostGIS 3.0.0alpha3 to 3.0.0alpha4 ST_AsGeoJSON
trac at osgeo.org
Tue Aug 13 17:02:46 PDT 2019
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: postgis | Version: trunk
Keywords: |
CREATE EXTENSION postgis VERSION "3.0.0alpha3";
ALTER EXTENSION postgis UPDATE;
Get error -- velix mentioned this in IRC -
ERROR: cannot change name of input parameter "pretty_print"
HINT: Use DROP FUNCTION st_asgeojson(record,text,integer,boolean) first.
it apppears someone decided to rename the last param and did not add the
necessary drop logic;
To work around the issue I had to do:
ALTER EXTENSION postgis DROP FUNCTION
st_asgeojson(record,text,integer,boolean);
DROP FUNCTION st_asgeojson(record,text,integer,boolean);
Then
works. strk I thought our upgrade tests are supposed to catch these no?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4483>
