[postgis-tickets] r17719 - Remove SRID error lines because that's a	silly thing to test
    Paul Ramsey
    pramsey at cleverelephant.ca
    Thu Aug 15 12:43:54 PDT 2019
Author: pramsey
Date: 2019-08-15 12:43:53 -0700 (Thu, 15 Aug 2019)
New Revision: 17719
   trunk/raster/test/regress/bug_test_car5.sql
   trunk/raster/test/regress/bug_test_car5_expected
Modified: trunk/raster/test/regress/bug_test_car5.sql
--- trunk/raster/test/regress/bug_test_car5.sql	2019-08-15 17:22:43 UTC (rev 17718)
+++ trunk/raster/test/regress/bug_test_car5.sql	2019-08-15 19:43:53 UTC (rev 17719)
@@ -36,9 +36,9 @@
 -- Raster: 5 x 5 pixels, 3 bands, PT_8BUI pixel type, nodata = 0
-INSERT INTO car5 (rid,rast) VALUES (1, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
-INSERT INTO car5 (rid,rast) VALUES (2, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
-INSERT INTO car5 (rid,rast) VALUES (3, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
+INSERT INTO car5 (rid,rast) VALUES (1, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A4100000000771956410000000000000000000000000000000000000000050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
+INSERT INTO car5 (rid,rast) VALUES (2, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A4100000000771956410000000000000000000000000000000000000000050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
+INSERT INTO car5 (rid,rast) VALUES (3, ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A4100000000771956410000000000000000000000000000000000000000050005000400FDFEFDFEFEFDFEFEFDF9FAFEFEFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster );
 -- Run test
 SELECT rid, st_width(rast), st_height(rast), st_bandpixeltype(rast,1), st_bandpixeltype(rast,2), st_bandpixeltype(rast,3) FROM car5;
Modified: trunk/raster/test/regress/bug_test_car5_expected
--- trunk/raster/test/regress/bug_test_car5_expected	2019-08-15 17:22:43 UTC (rev 17718)
+++ trunk/raster/test/regress/bug_test_car5_expected	2019-08-15 19:43:53 UTC (rev 17719)
@@ -1,6 +1,3 @@
-NOTICE:  SRID value -1 converted to the officially unknown SRID value 0 at character 41
 1|5|5|8BUI|8BUI|8BUI
 2|5|5|8BUI|8BUI|8BUI
 3|5|5|8BUI|8BUI|8BUI
