[postgis-tickets] r17725 - Try and harmonize function parameter names for ST_AsGEoJSON(record)
Paul Ramsey
pramsey at cleverelephant.ca
Fri Aug 16 02:26:05 PDT 2019
Author: pramsey
Date: 2019-08-16 14:26:05 -0700 (Fri, 16 Aug 2019)
New Revision: 17725
trunk/postgis/postgis_before_upgrade.sql
References #4483
Modified: trunk/postgis/postgis_before_upgrade.sql
--- trunk/postgis/postgis_before_upgrade.sql 2019-08-16 21:01:48 UTC (rev 17724)
+++ trunk/postgis/postgis_before_upgrade.sql 2019-08-16 21:26:05 UTC (rev 17725)
@@ -144,6 +144,14 @@
'geom1 geometry, geom2 geometry'
+-- FUNCTION ST_AsGeoJson changed argument names
+-- (pretty_print => pretty_bool) in 3.0alpha4
+SELECT _postgis_drop_function_if_needed
+ '@extschema@',
+ 'ST_AsGeoJson',
+ 'r record, geom_column text, maxdecimaldigits int4, pretty_print bool'
-- FUNCTION ST_LineCrossingDirection changed argument names in 3.0
-- Was (geom1 geometry, geom2 geometry) and now (line1 geometry, line2 geometry)
