[postgis-tickets] [PostGIS] #4474: bessie32 failing
PostGIS trac at osgeo.org
Mon Aug 19 10:20:56 PDT 2019
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.0.0
 Component:  buildbots  |    Version:  2.5.x
Resolution:             |   Keywords:
Comment (by pramsey):
 Well, that missing symbol seems to come from libstdc++, so the fact that
 you're missing it would seem to imply that one of the DLLs you're
 including was compiled against a C++ library that is newer/fancier than
 the one you're bundling into your build.
 https://gcc.gnu.org/onlinedocs/gcc-4.8.1/libstdc++/api/a00533.html
 Maybe include a newer c++ runtime dll?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4474#comment:4>
